    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 04-23-2015, 03:15 PM   #496
Orion_2kTC's Avatar
Finally...let's do this...
Any new tips while I work?
Orion_2kTC is offline   Reply With Quote
Old 04-23-2015, 04:41 PM   #497
Originally Posted by MaX-D View Post
What is the total weight of your truck without the battery?
Mine without the body weighs 5.62 lbs if my scale is right.
ba4ma is offline   Reply With Quote
Old 04-23-2015, 05:26 PM   #498
justpoet's Avatar
Trader Rating: 16 (100%+)
The only thing I'm seeing so far is to not tighten the wheel hex set screws much if using the ones that come with it. Just snug them so you don't stress the axle nor provide more force to crack the hex.
I still plan on using the aluminum hexes instead of these which I think are a cast steel. Shouldn't be much weight difference, but my al ones have been great, so I'll go with them again.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 04-23-2015, 05:35 PM   #499
justpoet's Avatar
Originally Posted by FAO View Post
Finally finished my build.
Seems to be very difficult to install the spacers (0,1mm thick) of the differentials.
Thinking of installing the elektronics i mentioned a lack of weight on the batterie side or to many parts on the right side:
Batterie: 300g left side
Right side: motor 260g, servo 70g, reciever and transponder 30g, controller 80g, plus wires etc. total: ~450g
I will use: Tenshock SC 411 4600kv, LRP IX8, Sanwa SRG BR, Sanwa 451, AMB.
The diff shims can be made a little easier with a small chamfer on the corner of the transmition case to help them slide into place.
For weight, keep in mind the battery sticks further out, so while the side is lighter, more weight further out helps to balance. That being said, you're also using a heavy full 550 length motor and heavy ESC, which help it be more out of balance. It won't get perfect, but it does get a lot closer with lighter electronics and a heavier 325+ 7k+ pack.
I used to be like you and wonder why we didn't always run 10 minute mains. I used maybe 2k on larger outdoor tracks or medium high grip tracks. Then...then I learned to use brake and throttle more aggressively in short burst sections, and I picked up a few tenths but started burning 3700+ in the same truck on the same track. That was back in my pre Tekno days, and if I need to stretch I'll drive like that when not battling to help both electronic heat and mah usage. It is a give and take.
Old 04-23-2015, 05:39 PM   #500
Anyone know what size the shims are that fit behind the aluminum hex nuts on the stub axles?
Old 04-23-2015, 06:15 PM   #501
Trader Rating: 18 (100%+)
While waiting around for tower hobbies I got my new pro-line evo sc body ready.
I won't be winning any awards for my paint skills but I think it looks pretty good
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-23-2015, 06:45 PM   #502
lala4fire's Avatar
I asked the same question a while back and now am able to return the favor.
The answer I got was part# ser600215 from Amain (8x11x0.2mm) and it worked perfectly. Now pay it forward!!!
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 04-23-2015, 06:47 PM   #503
Orion_2kTC's Avatar
Thanks, I bought the solid hexes.
Old 04-23-2015, 06:48 PM   #504
Thank you
Old 04-23-2015, 07:24 PM   #505
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
For the SC and SL, the shims that go behind the hex are PN: TKR1230 and are only needed if you have excessive play between the hex and the bearing.http://www.teknorc.com/shop/tkr1230-...m-shims-10pcs/
I think you might be referring to the shims that you could use on the 8th scale, as they use an 8mm stub axle.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 04-23-2015, 07:58 PM   #506
Slotmachine's Avatar
Send a message via MSN to Slotmachine
6mm
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-23-2015, 07:58 PM   #507
lala4fire's Avatar
That is correct, those are for the1/8 buggy. My bad! Thanks for clarifying.
Old 04-23-2015, 08:02 PM   #508
Bob-Stormer's Avatar
Originally Posted by Shawn_S View Post
Stormer's preposterous $99.95 2nd-day shipping just cost them a sale on the other one... I have no interest in ground from Montana.
I can appreciate your position. but, Preposterous? UPS rates aren't set by us.
Go ahead and type 12x12x24 and 12 pounds, $400 into the UPS calculator. We're at 59230 (how close was it?)
https://wwwapps.ups.com/ctc
standard shipping is the Best bang for the buck, and it always gets there fast, as others have mentioned. We have the SCT410.3 for $387 shipped. We ship every package, every day, no delays.
I suspect if questioned, most people here get there stuff from us in 2-4 days.
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 04-24-2015, 03:07 AM   #509
Here is how I made the truck:
https://www.youtube.com/watch?v=XRiGrqi4zV0
I could not catch the full assembly when Gopro did have lack of charge before starting the job. Anyway, it is a great kitt to mae and my first test drive was awesome.
It feels like the first version of the truck but jumps much better and feels that it is not falling as easy as the old version.
At this point I could not be more positive with my new truck! Great work Tekno!
Tekno RC Team Driver
www.teknorc.fi
mamyllyn is offline   Reply With Quote
Old 04-24-2015, 04:13 AM   #510
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
[QUOTE=justpoet;13975931]The diff shims can be made a little easier with a small chamfer on the corner of the transmition case to help them slide into place [QUOTE]
Thanks, this might have saved me 1h and al lot of fear for damaging the shims. But diffs run perfektly! Inside crown gears seem to be a little heavy.
Bougt new batteries 7500mah (Turnigy Ultimate, 314g).
As a spacer at the rear axle i used 5mm x 0,3mm shims and grinded them to 6mm+ at the inside.
Ordered a scale for 4 weel setup (sky rc), will get it in 14 days to measure every weight of the cars.
I hope to be driving the Tekno on may, 1. (The club is rebuliding the clay-track) Next race (2. and 3. of may) will be on carpet.
This season only a few races are on clay, it is a little bit disapointing here in Germany.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
