Tekno RC SCT410.3 Thread
#4936
That's what I was afraid of
And I try to explain the whole 2s 3s to people but they always seem to think that going to 3s gives you some kind of super power
I'll just get a 4300kv and call it good
By they way, this is for a Tekno SCT 410.3, LOL didn't want anyone to think I was just thread hijacking
#4937
Can someone with the Hobbywing XR8 SCT setup post some photos of how you ran your wires? If I run it this way in the photo the power cable and receiver wire will be rubbing against the drive shaft (even if I pull it really tight under the tray). If I flip it the other way then those wires are hanging out of the truck and won't look as nice. Anyone running this same setup?
#4938
turn it 90 degrees so the switch wire and rx wire is pointing toward the motor. run the motor wires over the fan. If you solder them on straight up and down off the ESC post it will not rest on top of the fan and will still cool plenty fine. That is how most do it and no one ever has complained of problems.
In all actuality, the ESC should really be mounted behind the battery tray much like the SCTE. Those who have done it have found a much better balance and rear end traction/rotation with the 410.3 that way, without the need to add counter weights or buy the popular but expensive M2C 10mm battery back chassis.
#4939
#4942
So if I turn it like this I run into some potential issues.
#1, the power and receiver wire will still butt up agains the motor. While at least this location it won't be rubbing against a moving part, don't I risk heat getting to those wires?
#2, is it okay that this is right up next to the Servo? I don't think it will be an issue as I have clearance in turning both right and left.
#3, is it okay that the ESC won't have as solid a footing on the tray underneath?
#4943
EDIT: and just keep a careful eye when you're soldering next to the SERVO. Don't wanna melt anything lol
#4944
#4950
Alternately you can just bend the exposed wire 90 degrees before you tin the ends. This will cause them to hold the angle, yet keep the wires running vertical from the post just as it would if you soldered them straight up and and down. I hope I am explaining it in a way that you can visualize what I am trying to tell you.
2/3 - you can still afford a few mm of clearance and don't need to butt the ESC right upto the servo bracket. Use grey automotive grade double sided tape. Be sure to clean the bottom of the ESC and the tray with some alcohol real good before you stick the tape to either. This will ensure you get a hard stick to the surfaces. You don't need to cover but about half of the ESC bottom to get it to stay put.
You're going to love that motor ESC combo. Im my opinion it's the best out there at the moment and I personally prefer that combo over the Tekin stuff any day of the week. It's a power house that will stay cool and rip that truck a new one with a good battery behind it.
