    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 02-01-2017, 07:47 AM   #4711
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
I think the motor will work fine geared right. The 4150kv actually does too on the tracks you mentioned when geared right as well.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-01-2017, 12:13 PM   #4712
Originally Posted by jason07 View Post
I have a question about the new steering components that are available.
The TKR 8104 kit comes with the new bell cranks and ackemrman top plate. It also comes with a center diff top plate....why? What is the difference in this plate and how does it affect steering?
I was told the new top plate adds clearance for the ackerman.
qstorm777 is offline   Reply With Quote
Old 02-01-2017, 09:40 PM   #4713
Ruffdog1's Avatar
Has anybody tried the new "Recommended indoor outdoor dirt" setup? I'm curious about the heavy diff oils. 15-15-10 seems really high compared to most setups I have seen and what I have run. Just wondering how it feels compared to lower diff oils like 7-7-5. Does anybody have experience with the heavier diff oil? I have running on a tight indoor track and I'm concerned about not having enough steering with the higher oil. Thanks!!
Ruffdog1 is offline   Reply With Quote
Old 02-02-2017, 06:34 PM   #4714
jason07's Avatar
I meant the top plate over the center diff
jason07 is offline   Reply With Quote
Old 02-02-2017, 08:27 PM   #4715
JoeRC123's Avatar
This is what the fastest guy at our track runs in his. I'm running it too and turning is not an issue. It's a 105 by 50 foot layout. Packed groomed dirt. Lots of turns and junps.
http://tracksideraceway.com/
JoeRC123 is offline   Reply With Quote
Old 02-06-2017, 12:03 PM   #4716
What is the most durable and best flying bodies you guys have found to work for use on a big outdoor track? im looking at the flotek fusion or the jconcepts raptor. I have the sc10 one on my car now and it falls apart fast.
Im ready to spend some extra money on the next one to make sure its quality.
caffeine357 is offline   Reply With Quote
Old 02-06-2017, 01:11 PM   #4717
Tech Legend
Cain's Avatar
from a durability perspective from what I recall, I really liked the Jconcepts Nissan Titan body. And I think it has like a built in rear that acts somewhat like a wing. This was used indoors small track and large outdoor 1/8 track.
Right now, I am running the Dodge Ram body from proline. I am liking it so far, the material is more flexible than the jconcepts so it doesn't seem to damage as easily. Backing it with some fiber reinforced tape helps a lot too. Looking forward to trying it outdoors.
Old 02-06-2017, 02:07 PM   #4718
Josh L's Avatar
The Jconcept 79 Ranger body is a beast as well. I have ran the wheels off my truck with this body and so far it has outlasted everything else I have used.
Josh L is offline   Reply With Quote
Old 02-06-2017, 07:29 PM   #4719
That is awesome. Gonna buy one right now
4s losi is offline   Reply With Quote
Old 02-07-2017, 04:41 PM   #4720
after some research i think im narrowed it down to the proline flotek or the jconcepts hi-flow
Old 02-08-2017, 01:05 PM   #4721
Trader Rating: 15 (100%+)
I had Proline-Flowtek and Jconcepts Hi-Flow.
The bodies got annihilated after one full day at outdoor track.
The bodies were reinforced with shoe-goo and dry-wall tape from the beginning.
The cutouts for the air flow really made the body weaker. Creating more cracks.
I hear the Jconcepts BAJR has the least tendency to crack due to not having any air holes.
Min. K
Fight on-
TEKNO EB48.35 / EB48.3
kms7852 is online now   Reply With Quote
Old 02-08-2017, 01:06 PM   #4722
hoyt1967's Avatar
Trader Rating: 34 (100%+)
Thats pretty cool, always been a fan of that vintage Ford's. How do the rear body posts match up? I cant see them in the photos. I'd be interested in trying this body if the posts are in a place that work well for clips.
hoyt1967 is offline   Reply With Quote
Old 02-08-2017, 01:15 PM   #4723
That ranger body is great, im gonna order one too.
barbwire44 is offline   Reply With Quote
Old 02-08-2017, 01:35 PM   #4724
Tech Legend
Cain's Avatar
I think a guy local runs that. Looks good.
One body I liked but probably isn't a race body was the jconcepts one that had light buckets built in. Made that into a police truck back in the day, was fun
So, any more news on the new starting setup? How has it been running for you, especially in in high traction situations? I am debating making pistons or buying some.
Old 02-08-2017, 06:44 PM   #4725
lowspark's Avatar
Cain
New set-up is working great for me so far. Bested my avg time in the mains (10-min) by a full lap, going from 20 to 21 laps. Not the fastest guy there but if I can finish with-in a lap of the leaders I'm good.
Started to fall off the pace in the last couple of weeks and it is all about tires.... so new rubber for this weekend.
Going to a track in OK Saturday, a different type of track (way more elevation change) and a looser red dirt. The track will develop pot holes and ruts as the day progresses. (good 'ol off-road racing) I'll drop a post on Sunday on how the truck worked.
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
