    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 01-04-2017, 07:48 AM   #4606
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Originally Posted by DriveItLikeYSIT View Post
I had 8x1.3m pistons in my tool box & used mini metric bit to make 8x1.4mm pistons.
I used the new recommended setup with 10x1.2mm pistons and older steering parts this weekend; my sct was very easy to drive.
what conditions?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-04-2017, 09:12 AM   #4607
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
Originally Posted by Cain View Post
what conditions?
A large outdoor clay track with 1/8 scale jumps and medium traction. I was using supersoft PL Blockades
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is online now   Reply With Quote
Old 01-04-2017, 10:24 AM   #4608
Originally Posted by weedsnager View Post
I would think that's better. Definitely easier than drilling.
qstorm777 is offline   Reply With Quote
Old 01-04-2017, 10:48 AM   #4609
Tech Legend
Cain's Avatar
cool that sounds like outdoor conditions here.
Old 01-04-2017, 03:41 PM   #4610
Can anyone give me some settings I should set on my tekin rx8 gen 2 with pro 4 HD 4300 on a medium sized outdoor track. Thanks
brandon32689 is offline   Reply With Quote
Old 01-04-2017, 04:13 PM   #4611
I run a 17t pinion.
7 on torque.
I don't remember the freq settings but I think I was probably 75/80 percent on the high frequency side. 100% brake and throttle. I use my radio to turn down my brakes if needed. I don't run drag brake. I don't run any timing and no boost.
Also, I believe if you check the Tekin website, they will have some setups that their drivers run that may give you a better idea of what you want to run.
Old 01-05-2017, 10:30 AM   #4612
Originally Posted by shadaloo View Post
$22 for just 4 pistons, times like this I hate that I like to keep my 3 kits upgraded and whatnot.. I remember when I got the delrin inserts, tini shafts, and springs and was shocked at the total when you get everything in 3's lol.
I feel ya there.. I did it for a while by 4's...Adds up quick.
But once you have something just the way you want it, you stop. (Like my truggy)
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 01-05-2017, 09:35 PM   #4613
Trying to put the new indoor/outdoor setup on my 410.3. The most droop/shock length I can get for the front shocks is 105. For the rear it's 120. Has anybody else tried using the new setup? If so, were you able to get the 107f/121r shock lengths?
Old 01-05-2017, 10:13 PM   #4614
Tech Legend
Cain's Avatar
If I recall correctly, the droop measured would be relative to the positions of the shocks on the arms and towers. So keep that in mind with whatever is being stated, assuming that is the case.
Old 01-06-2017, 01:50 PM   #4615
Josh L's Avatar
^Yep and you actually have a few mm to play with by how far you thread the ends onto the shock shaft.
Josh L is offline   Reply With Quote
Old 01-06-2017, 07:02 PM   #4616
lowspark's Avatar
New parts, new set-up,... all ready to rock and roll.... cept.... It is only 20 something in Dallas tonight with a single digit wind chill factor...... tooooo friggin cold to race tonight
So I have to be patient until Sunday afternoon. I'll report back then on how the set-up worked.
And yes, I have the same issue with the shocks. Full droop at about 105 & 120... I was going to unscrew the shock ends but figured I would leave then for now...
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen2 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 01-06-2017, 09:11 PM   #4617
I have my shock ends threaded all the way in til the ball binds then back it off 1/4 turn which usually unbinds the ball. Max shock length I get this way is 105f/120r. I could back the shock ends off some more I guess.
In general, I mostly like the new setup. I do find it a little loose in the rear on-power. Still testing tho. Could be I'm oversteering. Oops...I forgot to put the three washers and steering stop screws in. Will chg that tomorrow. Right now, I have to be careful with how much power I apply out of a turn.
Old 01-07-2017, 06:53 AM   #4618
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Has anyone had an issue getting good gear mesh with a HW 4700 and a 14 or 15t pinion. Seems I can only get it good with a 16t. Running on a small indoor track and really wanted to go down to 14 but the teeth barely touch.
TAW is offline   Reply With Quote
Old 01-07-2017, 07:03 AM   #4619
Putting the new setup sheet in the truck with the new parts, what's this referring to ? It's not in the old set up sheet
weedsnager is offline   Reply With Quote
Old 01-07-2017, 09:46 AM   #4620
justpoet's Avatar
Trader Rating: 16 (100%+)
This is referring to the ball studs on the spindle. You can adjust the amount of bump steer by moving washers to/from below the ball stud, or flipping the ball stud over to get the ball portion even lower.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
anr211
