    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 01-01-2017, 03:59 PM   #4591
Originally Posted by Matthew_Armeni View Post
It only comes with the pinch bolt, not the bolt to tighten it to the servo.
Don't worry about posting here, glad to help, but I would still tighten your servo saver back up .
Ok, cool! I just know some forums aren't as tolerant!
Ok, I thought that the bolt included with the horn must be the pinch bolt, but the way it's designed doesn't actually allow it to "pinch" the horn together. The bolt bottoms out on the horn as it's not recessed like the 23T and 24T versions. I've stripped 2 aluminum servo horns at this point so I'll tighten the saver back up and see if the 3rd time's a charm.
Thanks for the help!
Theoldguy is offline   Reply With Quote
Old 01-01-2017, 04:15 PM   #4592
Originally Posted by weedsnager View Post
Ok, so what parts (tekno part numbers ) do I need to adjust the toe to 0 ? The original set up sheet has the front toe at .5
There that much off a difference in the .5 to the new recommended 0 , that we have to cut something ?
Someone please explain this to me like I'm a six year old , cause I don't understand.
And what method do you guys use to measure toe?
This only applies if you have the new steering system: TKR8100, TKR8104 and TKR1403. The new ackerman bar (TKR8100) is longer than the original ackerman bar. To compensate, either the original steering links (TKR5123) need to be cut down to 50mm (3mm from each side) or buy a set of 50mm turnbuckles with 4mm thread. Associated, Lunsford and Kyosho makes a turnbuckle this size. Seems like there was one more on Amain.
qstorm777 is offline   Reply With Quote
Old 01-01-2017, 04:26 PM   #4593
Thank you for the detailed help !
weedsnager is offline   Reply With Quote
Old 01-01-2017, 04:43 PM   #4594
No problem. I hope that helps clarify things.
Old 01-01-2017, 08:00 PM   #4595
jason07's Avatar
Here are some 4x50 Turnbuckles that I found to make it easy on everyone.
https://www.amainhobbies.com/kyosho-...441-50/p492587
https://www.amainhobbies.com/kyosho-...oif489/p492606
https://www.amainhobbies.com/team-as...c89526/p144553
question about these though with regards to mounting. The Tekno turnbuckles have a notch that goes on the left side of the buggy. There are no notches on these, how would they be orientated on the truck?
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 01-02-2017, 06:42 AM   #4596
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Looking at this new recommended setup sheet that was posted a few days ago and I have a question.
The notes mention using the TKR6051 which is the 8x1.3 conical but it says to drill them to 1.4. Why wouldn't you just use the TKR6053 that is already 8x1.4? Is there something else different between them?
TAW is offline   Reply With Quote
Old 01-02-2017, 07:21 AM   #4597
I would make sure the thread is going the same way.
Old 01-02-2017, 10:16 PM   #4598
Hey guys for anyone running the Tekin RX8 gen 2 and Pro4 hd 4300 what setting are best for the ESC and motor. ? Thanks
brandon32689 is offline   Reply With Quote
Old 01-03-2017, 11:45 AM   #4599
Originally Posted by Cain View Post
As for the different roll center hubs, would it be possible to do a hub that has a insert that allows you to adjust the pin height similar to say the Associated B6 hub?
Please no. I can't stand how quickly they slop out.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 01-03-2017, 12:43 PM   #4600
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
I am assuming the Tekno material would be better, just whatever the hub is made of placed there instead. Then, just replacing the insert versus the whole hub.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-03-2017, 10:20 PM   #4601
I don't think they make those anymore.
Old 01-03-2017, 10:23 PM   #4602
Originally Posted by MattDub View Post
Weedsnager,
We have extensively tested this setup at our local indoor (SDRC Raceway) and outdoor track (heritage RC park) and we're surprised to find it worked well at both locations. Neither track is anything alike, SDRC is a medium size clay track and Heritage is a huge outdoor nitro track.
Only real change was to lower ride height to 19mm for indoor. Highly recommend this to be used as a base setup as it's easy to drive and jumps well.
So what ride height did you use outdoors?
Old 01-03-2017, 10:43 PM   #4603
https://www.amainhobbies.com/tekno-r...kr6053/p246472
Old 01-04-2017, 12:12 AM   #4604
shadaloo's Avatar
$22 for just 4 pistons, times like this I hate that I like to keep my 3 kits upgraded and whatnot.. I remember when I got the delrin inserts, tini shafts, and springs and was shocked at the total when you get everything in 3's lol.
shadaloo is offline   Reply With Quote
Old 01-04-2017, 02:27 AM   #4605
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
I had 8x1.3m pistons in my tool box & used mini metric bit to make 8x1.4mm pistons.
I used the new recommended setup with 10x1.2mm pistons and older steering parts this weekend; my sct was very easy to drive.
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
