    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 12-23-2016, 05:50 PM   #4531
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Originally Posted by weedsnager View Post
How much importance do you guys think a body has to do with handling ? Not talking about jumps...just how the truck handles at speed on straightaways and no grip in the corners.
When I first started with this truck it seemed to handle a lot better then It does now, I was thinking it all could have something to do with the body, these are the first two bodies I used
This is the last body I was using (I never put the number plate on)
Ive made other changes to the truck besides the body, but it seemed like whatever diff fluid, tires, pills, etc I tried the truck handled terrible with the body in the last picture...Could the body play that much of a roll ?
SC bodies play a huge role in how they handle. Best way to confirm is back to back testing.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-23-2016, 06:56 PM   #4532
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
+1 big diff. The whole nissan titan body really helped with the rear end planting.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-23-2016, 07:05 PM   #4533
Tech Legend
Cain's Avatar
Originally Posted by MattDub View Post
Hey Guys,
Wanted to post our new recommended setup for the SCT410.3. This works on most track conditions, indoor and out. Please give it a try and let us know! Thanks!
http://www.teknorc.com/wp-content/up...l%20Tracks.pdf
what would you change on this setup for carpet? Using the really high bite on right now, or I should say, will try it:
As for the different roll center hubs, would it be possible to do a hub that has a insert that allows you to adjust the pin height similar to say the Associated B6 hub?
Old 12-23-2016, 07:51 PM   #4534
No plans for that. It's a little more work to swap out the whole hub versus just an insert but it's a pretty quick adjustment to make.
Tekno RC
Old 12-23-2016, 08:09 PM   #4535
Hi Cain,
You might be talking about an EB48.3 setup. Those have been developed for dirt. I personally dont have experience with carpet but would recommend using heavier springs and swaybars beyond that would roll center and camber link changes. Most likely moving the camber links down on the tower.
Will pass along the idea for the hubs.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 12-23-2016, 11:18 PM   #4536
Trader Rating: 25 (100%+)
Originally Posted by tfrankito View Post
has anyone tried using the old rear shock tower to help calm the rear down and keep it from sliding out?
first run with the old shock tower on the rear, HRC hubs, LFR yellow springs, and the middle hold on the hub and 5 hold on the tower...planted!!!! loose hard packed indoor. Basically running Jeremy's setup. Changed the Rear pill to 2 dot down outside. Running plastic c block and center pill. A block dot up, b block center dot. 15,15,10
LRP America
My RC Depot - myrcdepot.com
tfrankito is offline   Reply With Quote
Old 12-24-2016, 01:15 PM   #4537
lowspark's Avatar
Hey Guys,
Matt, tapers up or down on the shock pistons?
I have some time off next week and will try your suggested set-up and report back.
Cliff
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 12-24-2016, 02:42 PM   #4538
lowspark's Avatar
And, can someone give me a best guess for the shock oil using Associated vs the PT that is listed in the set-up sheet. The PT website compares their product to Losi oil, and then I compared the Losi to the Associated. Below is what I am coming up with.
Cliff
PT 450 front = Associated 35
PT 300 rear = Associated 27.5
Did a little home work reading about the PT oils and looks like it is a 5-star product. I may have to order some in the future... for now, I have Associated to use.
Old 12-24-2016, 02:56 PM   #4539
Here's the shock oil
Does anyone have a chart for Pt vs Assiciated dif oil ?
weedsnager is offline   Reply With Quote
Old 12-24-2016, 07:24 PM   #4540
lowspark's Avatar
Thanks Weed...
and
Merry Christmas to all the Short Course Racers !!!!
Old 12-24-2016, 08:21 PM   #4541
Taper down. Curious what you think. I've had great success with that setup.
Cliff
Matt Wolter
Old 12-24-2016, 08:38 PM   #4542
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
Hi matt. i have 8x1.3mm cnc pistons. would the new setup
work with 1.3 pistons instead of 1.4mm?
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Old 12-25-2016, 07:03 AM   #4543
That body was discontinued, correct ?
Old 12-25-2016, 10:05 AM   #4544
JoeRC123's Avatar
Looks like it was but still have a few on Amazon (from Horizon Hobby):
https://www.amazon.com/Nissan-Titan-.../dp/B00CLAYVLQ
JoeRC123 is offline   Reply With Quote
Old 12-25-2016, 08:31 PM   #4545
Josh L's Avatar
Before being sponsored by Proline, Jeremy McGuigan swore by the Jconcepts Ford F250 Super duty XLT supercab
It's the only body I know of that has as large of a built in wing as significant as it is and he said it really kept the rear down as well.
Josh L is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
