    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 12-18-2016, 07:42 PM   #4501
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
lol well, worse case it will be spare parts lol.
The youngest though seems to be quite interested and we finally will have a local track for the summer so that can help a lot
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-19-2016, 10:51 AM   #4502
Default Shocks binding
While changing shock oil recently, I noticed that on 2 of my shocks if I twist the shaft 1/4 turn it won't move in and out freely and seems to bind. If I rotate the shaft back about 1/4 turn, the shaft/piston moves in and out like it should. It feels like the piston is rubbing on the inner shock body. The other 2 are fine. Has anyone else experienced this problem? If so, what was the cause and fix? Thanks in advance.
RookieRacer00 is offline   Reply With Quote
Old 12-19-2016, 11:02 AM   #4503
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Bent shock shaft. Replace them and you should be fine. What caused it? Most likely an epic crash that made the crowd go "Ohhhh!!!!"
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 12-19-2016, 11:04 AM   #4504
Tech Legend
Cain's Avatar
hmm, as you are seeing the issue as you turn the shaft it almost seems like a bent shock shaft, but I would think regardless of how you turn it it should be consistent on how its binding. The other thing that may be tied to that as well is could you have both a slightly dented shock body and bend shock shaft? It may be just slight enough that went you turn the shaft a certain way that has this slight bend, it then in turn contacts the slightly dented shock body enough to see the binding. Could also be one of of the shaft guides is off.
I probably woudl try a known good working shock shaft and piston combo first on that shock body with the issue. Confirm you still see it. You could also try the shock shaft guide as well from the good shock body into the questionable one, and see how it goes.
Probably need to isolate the problem that way.
Old 12-19-2016, 11:17 AM   #4505
I'll check for a bent shaft but didn't have any epic, crowd "Ohhhh!!!"ing crashes. Thanks for the help!
Old 12-19-2016, 12:15 PM   #4506
Yup. I've actually made it through a race weekend with that exact symptom. I just managed to rebuild the shock orientated right so that it would work as it should. It worked.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 12-19-2016, 12:49 PM   #4507
Tech Legend
Cain's Avatar
one funny thing I noticed on my rebuild was that the previous owner must have been king of bent hingepins as I saw a whole bunch of them in the spares box. Me being me I just chucked all of those, still a good amount of good ones included but all I could think is man that much be one tough track he races on lol.
Old 12-19-2016, 02:19 PM   #4508
Were you able to figure out what the cause was? Was it a bent shaft?
Old 12-19-2016, 07:21 PM   #4509
jason07's Avatar
I'm not a newb to RC racing but I have a newb question. Why is it that setup sheets for the SCT show the heavier weight shock oil in the front (lighter rear) but the 1/8 scale buggy has heavier rear shock oil but lighter front oil?
Is it because of the weight of the SCT over the buggy?
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 12-20-2016, 06:28 AM   #4510
Tech Legend
Cain's Avatar
got a link to a setup in question?
I remember back in the day with at least the nitro buggies around here some common setups when they ran the same pistons front and rear they had heavier rear oil. Maybe something to do with the weight in the back versus front at the time.
Old 12-20-2016, 06:53 AM   #4511
It sure was
Old 12-20-2016, 06:58 AM   #4512
It's actually due to the abnormal shock package on the .3 (And the new .4) buggies. Our buggies run the same shock package that our truggies do.
If you looked back at the legacy .2 buggies, which shared the shock package with the SCT, you would see the shock weight match to heavier front with lighter rear.
Old 12-20-2016, 08:23 PM   #4513
jason07's Avatar
Oh yes, that makes sense. I didn't think about that. I haven't messed with any of the .2 stuff, its all been the .3 vehicles.
Thank you
Old 12-20-2016, 08:35 PM   #4514
jason07's Avatar
Here are 2 but all of them seem to be this way.
Old 12-21-2016, 03:35 AM   #4515
Goupil's Avatar
hi guys,
I'm thinking about buying a SCT410 and I was wondering if my Tenshock 3500kv would work in it ? (running 3S lipos)
I'm worried it might be too many kv and cause overheating, what do you think?
thanks for your help !
HPI Blitz - HW WP SC8 - Tenshock SC411 3500kv - 3S Lipo
Custom 6x6 SCX10 - Castle Sindewinder 3 - Axial 27T
Goupil is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
