    Hide Wikipost
Old 12-23-2016, 03:19 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: MattDub
Welcome to the SCT410.3 Wiki!
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree1Likes
Old 03-19-2015, 03:01 PM   #31
Shawn_S's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Apco1 View Post
I would think that cross pins see a large amount of force. Especially the thicker the fluid is. Under full acceleration all the force in the center diff is being put on the cross pins is it not? Correct me if I'm wrong but if those pins were to sheer off, the diff housing would spin but not the out drives. I just don't see the advantage of a composite cross pin, give me steel.
Over two years with composite crosspins in my Durango truggy, they're showing less wear (absolutely zero) than any metal pin I've used. Guessing Tekno can make the pin as good as Durango, so no fears here.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 03-19-2015, 03:50 PM   #32
justpoet's Avatar
Trader Rating: 16 (100%+)
Originally Posted by jmkalt View Post
So, in a nutshell, regarding the new suspension geometry, how will the new truck drive compared to the old one? In other words, what does the change do to the handling?
I believe the biggest benefits will be seen on rough tracks, as the extra piston speed and further out shocks allow for better control of bump handling and jump landing pack via piston/oil changes more independently, which should lead to more stability. I haven't driven it or played with it yet though ('cause, well, they're not shipping yet), so I can't tell you for sure.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 03-19-2015, 04:33 PM   #33
It looks unavailable for pre order at tower, ive never pre ordered from there before, am i missing something or just to soon? Thanx
mikeinsocal is offline   Reply With Quote
Old 03-19-2015, 04:47 PM   #34
Tech Legend
Cain's Avatar
Trader Rating: 219 (100%+)
That is the main area I had issues with was rough track handling. but if it whole nose down thing is gone, and we get better rough track handling I am fine with whatever for oil and springs lol.
when you click buy, it will take you to a page asking you if you want to preorder. you are not charged till it ships. Coupons work too. Got mine pre-ordered for $339.99 shipped.
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< HB Racing D413 x 2>
Cain is online now   Reply With Quote
Old 03-19-2015, 05:08 PM   #35
GIHOSU's Avatar
It looks like they will have green front springs, black rears and 10 x 1.2s with 2.6mm swaybar up font and 2.4mm rear according to the part list. No new parts show up so we will have to see if/when that changes.
I won't mind having another SCT...
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 ~ RB6 17.5 ~ RB6 ~ RT6 ~ RZ6 ~ SC6 17.5 ~ SC6 ~ ST-RR Evo.2E
TEKNO - SCT-410
GIHOSU is offline   Reply With Quote
Old 03-19-2015, 05:09 PM   #36
Tech Legend
Cain's Avatar
looks like it will be all composite hingepin braces front and rear? Does that look like that for everyone else too?
I am hopeful the include the alloy front one like they did before at least.
Old 03-19-2015, 05:19 PM   #37
Motorman007's Avatar
Trader Rating: 71 (100%+)
Sounds like it's not worth update your kit it will cost to much. Just but new for $400 vs spending maybe $200+
YOU WILL (ALWAYSWIN).....
Motorman007 is online now   Reply With Quote
Old 03-19-2015, 05:30 PM   #38
Trader Rating: 67 (100%+)
Yep, mines officially pre-ordered as well
"Wow he's really fast isn't he????.....Yeah but he's Stupid"
lyork is offline   Reply With Quote
Old 03-19-2015, 05:35 PM   #39
Tech Legend
Cain's Avatar
yeah, if tower does the E-cash thing again, maybe I'll do another order and cancel based on when the season gets going, will see.
One thing I am curious about is with the new bearing setup, it looks like they should be more robust on the carrier side of things.
Would the EB48SL be a good option then now in 1/8 E buggy on 4S? This is more so to share parts I am looking at, so could do 2 the new SCT410.3 and the EB48SL (no .3?) and go from there.
Of course would need longer straps for 4S probably, and then the mount that will work for the larger motor.
Old 03-19-2015, 06:35 PM   #40
hellfire's Avatar
Trader Rating: 80 (100%+)
Originally Posted by lbenton View Post
As many SCT410 owners are looking at this and trying to weigh options. What are the chances that a "geometry update kit" will be released? I know a lot of people that have the lightened drive train, 7075 chassis, and other option parts that have been available. But to bundle up the hinge pin holders with the square pills and the new arms and hubs, or any other newly introduced features would be a nice gesture to support the many 1.0 folks out here.
In the same boat. Pretty much have everything. Split diff,M2C chassis, and BCE chassis. Alm. drive shafts.
~ Scott McTaggart ~ *In Memory Of Shaun Neary*
~ GotNitroOnline.com ~ The home of Radical 621T motors Thanks Dave ~
~MnNitroSeries.com ~ Lucky 13 Speedway ~
hellfire is offline   Reply With Quote
Old 03-19-2015, 07:05 PM   #41
Lexicus's Avatar
Originally Posted by Lexicus View Post
Tower's pre-order is $565.99 but teknorc lists it for $399. That's a pretty big gap, anybody know what the real street price will be? Even with tower discounts it's still $100 over.
Looks like tower fixed their pricing
Lexicus is offline   Reply With Quote
Old 03-19-2015, 07:46 PM   #42
I dont see a "buy" botton, the page i go to says unavailable and only gives option for wish list or email me when available
Old 03-19-2015, 07:48 PM   #43
Tech Legend
Cain's Avatar
you going here?
http://www3.towerhobbies.com/cgi-bin...?&I=LXFEJE&P=7
Old 03-19-2015, 08:01 PM   #44
No, guess my tablet decided where to take me, thanks cain, preorder placed! Looks like my kids gonna be upgrading the ol` sc10 4x4 to my original sct410, with upgrades of course, lucky sucker
Old 03-19-2015, 08:05 PM   #45
Tech Legend
Cain's Avatar
no prob.
heck, you could always turn that SC10 4x4 in a tough 2wd lol.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Flippin 416, suzukipro
