    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 12-08-2016, 12:12 PM   #4426
hoyt1967's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Cain View Post
yeah I figured either maintaining 2 custom vehicles if my daughter really likes RC or 2 vehicles that I know I can easily do that for.
Say it aint so!! Leaving the Durango camp is gonna leave them pretty thin
I'd sure like to have something to run against besides Tekno's. I really cant believe you dont go back to what you were running last year, that truck was fast
hoyt1967 is offline   Reply With Quote
Old 12-08-2016, 02:18 PM   #4427
JoeRC123's Avatar
Originally Posted by hoyt1967 View Post
Thats very odd. I've owned 5 410 sct's .3 and original, eb's, et's, never had a hole poked in a bladder? There has to be something messed up in the way the shock is put together. Have you looked at the stack of orings and spacers in the lower shock body? I'd bet there is something wrong there.
Is it just fronts or rears?? If so maybe the shafts are in the wrong bodies (rear shafts in front bodies?)
You should not have to dremel anything.
I agree, something is not right. The track owner that sold me the kit has never heard of it either. I'm having the problem in all 4 shocks so I don't think I have the shafts reversed front/back. I'm going to take one completely apart tonight and see if I missed anything. Very odd indeed.
JoeRC123 is offline   Reply With Quote
Old 12-08-2016, 02:31 PM   #4428
hoyt1967's Avatar
Yes, make sure the "top hat" inserts are in the right place, I believe there is a long and short and they go in a specific way. Let us know what you find.
Old 12-08-2016, 03:18 PM   #4429
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Yeah. I am looking to get the kids involved and I think I can easier support the tekno than the durango at this point if they take it up more. Plus with durango having company issues not sure what is going on from that front. Heck of a truck though, the desc410v2.
the DESC10 darn fast too and really a tough beast, but, again, same thing, durango support issues
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 12-08-2016, 04:53 PM   #4430
JoeRC123's Avatar
I may have figured it out with the help of Tekno tech support. I drilled holes in the top of my shock caps for vent setup and left a little flashing on every one. The pressure of the oil under the bladder pushed it up under the cap and was cut by this flashing. The shape of the cut matched the drilled hole flashing. So I'm cleaning up the flashing with a large drill bit and hopefully that should fix it. I'll post back after some track time.
Oh by the way the shaft end with lock nut doesn't come anywhere near the bladder at full depth so that was not pushing on the bladder like I thought. Also my shock shafts are correct front and back. Not reversed. Thanks for all the help and tips.
Old 12-08-2016, 05:16 PM   #4431
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
I may have figured it out with the help of Tekno tech support. I drilled holes in the top of my shock caps for vent setup and left a little flashing on every one. The pressure of the oil under the bladder pushed it up under the cap and got cut on this flashing. The shape of the cut matched the drilled hole flashing. So I'm cleaning up the flashing with a large drill bit and hopefully that should fix it. I'll post back after some track time.
Good catch. I wonder if this isn't the problems others have randomly had with this?
TAW is offline   Reply With Quote
Old 12-08-2016, 06:15 PM   #4432
JoeRC123's Avatar
Well funny you should mention that. Both the hobby shop I bought it from and and Tekno say that this is the first they heard of it. Several months back (like last April) I did a search and found a guy had posted in July of 2015 that he had this issue and thought the vent hole was causing it. He said that noticed a hole in the bladder only when he thought to pull on each end and stretch it out. Only then could he see the hole. So people who run vent better make sure this hole is nice and smooth on the inside or plan on buying lots of bladders like me. I hope I fixed it. This is an awesome Truck.
Old 12-08-2016, 06:18 PM   #4433
JoeRC123's Avatar
Originally Posted by HoldDaMayo View Post
broke my first thing on the SCT410.3... and it's a strange one... shock bladder! Somehow got a hole in the middle... was very small, hard to notice until you kind of stretched it out, but it was leaking a good amount of oil because of the hole... a bit messy and annoying, but at least the truck still actually drove pretty well for about 6 packs after I noticed the leak, just filled a little oil every once in a while.
Question, I ran the stock vented setup, if i were running the emulsion setup I wouldn't have to deal with holes in bladders... think it's worth making the change for?
Thanks.
Here is the post of someone else who had this issue.
Old 12-08-2016, 07:07 PM   #4434
hoyt1967's Avatar
Well funny you should mention that. Both the hobby shop I bought it from and and Tekno say that this is the first they heard of it. Several months back (like last April) a guy posted here that he had this issue and thought the vent hole was causing it. He said that noticed a hole in the bladder only when he thought to pull on each end and stretch it out. Only then could he see the hole. So people who run vent better make sure this hole is nice and smooth on the inside or plan on buying lots of bladders like me. I hope I fixed it. This is an awesome Truck.
Good catch!! thats a new one to me, but good to know the fix.
Old 12-08-2016, 07:09 PM   #4435
shadaloo's Avatar
Been trying 15/15/10 from stock and having issues with rear end being very loose now... I also changed servos at the same time from savox 1267 to mks 599 and at first the endpoints were too far but I feel like the servo is causing issues with it being loose tho.. Not sure if its the servo or the diff oil change that's making it a handful. ><
shadaloo is offline   Reply With Quote
Old 12-08-2016, 07:28 PM   #4436
Tech Legend
Cain's Avatar
what were you are before?
Assuming you went heavier all around (say you were at 10-10-5) I can see it being more loose for sure in the rear.
As for the servo, if you mean that it feels like too much throw at too little input, try putting in some negative expo on the steering. I use this on all my fast servos as it calms down the low end response. I run anywhere between 10 - 20% depending on the car and servo.
Old 12-08-2016, 07:43 PM   #4437
shadaloo's Avatar
I believe it was 5/5/5 before. Yeah it had too much throw at first, it actually popped the pin from the cvd it was turning so sharp. I put in steering limiters and adjusted the dual rate and whatnot... The truck was PERFECT before, but I wanted to see the new servo and thicker diffs would feel, and the truck is a mess now.
Old 12-09-2016, 03:08 AM   #4438
shadaloo's Avatar
Also picking the best body for racing is so hard.... My JC Raptor Xflow handles and jumps sooooo much better than my JC Illuzion HF.... In wanting to get another practice body since my HF is shreaded, and I want to use my Raptor for racing only. Thinking about getting another JC Raptor Xflow, or a Proline Flotek Raptor. Not sure how the Proline handles since I haven't owned one. What's everyone's top choices for bodies??
proline flotek raptor
proline flotek fusion
::edit:: after looking a bit more, I feel like the 2 I linked both look nice. I haven't tried proline on sct yet, but the flotek bodies seem legit and worth a try. I want a aggressive front end, and good antiparashute.
Old 12-09-2016, 03:50 AM   #4439
JoeRC123's Avatar
Topic was brought up just a few pages back.
Old 12-09-2016, 04:18 AM   #4440
shadaloo's Avatar
10-4, I was just looking for more opinions since there were only like 2-3 replies. Ill probably try the Proline Flotek Raptor (non-flotek looks awful) body finally, seems like a popular choice.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mike101
