    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 11-30-2016, 05:27 AM   #4396
JoeRC123's Avatar
Interesting about the bladders not staying put. I wonder if over tightening the caps could cause this. I no longer crank mine down that much. As tight as I can with my hand, then just a little twist more with an adjustable wrench. Like a 16th of a turn, otherwise the cap strips.
JoeRC123 is offline   Reply With Quote
Old 11-30-2016, 06:55 AM   #4397
Can anyone recommend a setup station that would work for a 10th scale short course truck , 8th scale buggy and 10th scale touring car? or do these have to all be bought separately.
caffeine357 is offline   Reply With Quote
Old 11-30-2016, 10:18 AM   #4398
I don't know if the integy one works with touring car, but I use it for the rest.
qstorm777 is offline   Reply With Quote
Old 12-03-2016, 06:42 AM   #4399
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Looking for a Chassis protector, is the chassis on the 410.3 the same as the 410.2?
TAW is offline   Reply With Quote
Old 12-03-2016, 11:39 AM   #4400
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
The shape and hole pattern of all the current chassis are the same, or very close, I think the droop pads might be the only difference.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-03-2016, 01:21 PM   #4401
JoeRC123's Avatar
I've read about some alternative to the Techno shock boots which are $10 a set. I remember a certain type of balloon. Can anyone point me to what worked for them. I just don't want to throw away $10 to something that will tear apart in weeks.
Old 12-03-2016, 01:54 PM   #4402
shannow's Avatar
I'm personally trying at the moment modeling ballon (2inch diameter ones). So far they seem good. They tend not to go back down by themselves after an afternoon of runs. I may try something like a fuel pipeline cut as a ring to hold it at the bottom.
I'm testing them as the moment as I can buy 100's for 10$ or less here (+ you choose whatever color you fancy). At this price even if they only last a couple of race days they'll be very economical.
Yokomo YZ-2 , sanwa M12
Tekno EB 48.3 1900kv Hobbywing XR8+
Tekno NB48.4 Ko propo servo's Alpha dragon III
shannow is offline   Reply With Quote
Old 12-03-2016, 02:16 PM   #4403
shadaloo's Avatar
Qualatex 350q Onyx Black balloons, you can get them cheap on Amazon. 20x$5, 100x$14-16, or you can get any of the other 15+ colors....
shadaloo is offline   Reply With Quote
Old 12-03-2016, 09:32 PM   #4404
JoeRC123's Avatar
Yeah that's what I'm going to try as well. Thanks.
Old 12-03-2016, 09:32 PM   #4405
JoeRC123's Avatar
I ordered some and will try it. Thanks.
Old 12-05-2016, 07:53 AM   #4406
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
well I decided to make another go of it with Tekno to keep things on the up and up with having a supported race vehicle that if I decide to expand with my kids we can share parts, etc.
Anyway, are there any carpet setups out there you guys recommend? This would be high traction carpet, with a tad bit of bumpiness to it in my opinion.
Do Xray springs work on tekno shocks?
For spare shock towers, is it worth it just having a set of the stockers in the box or should I got CNC towers? (will be coming with the graphite ones)
For the whole hingepin blocks, is there an advantage to the C block in plastic or do all the settings in general the C block in aluminum offers are sufficient for a variety of conditions (say carpet to loose dirt)
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 12-05-2016, 07:27 PM   #4407
Cain check out the last setup sheet on the tekno site for astroturf. I use that as my starting point for carpet and I am pretty happy with it. Just have to work on the traction rolling mostly. Tires and ride height. Note the cut springs.
crash n go is offline   Reply With Quote
Old 12-05-2016, 08:07 PM   #4408
Tech Legend
Cain's Avatar
good stuff thanks.
Old 12-06-2016, 03:45 AM   #4409
TAW
My son and I will be racing our new 410's on carpet as well so I checked out that sheet. On the shock setup where it says brand does he mean oil brand or are they running TLR shocks?
Also, the camber.....-4 on the front man thats a lot but I suppose that's to keep the front from grabbing and causing traction rolling.
Old 12-06-2016, 04:59 AM   #4410
celt's Avatar
Default wow...
Just on amain, thinking of refreshing my SCT410.3.
$369.99, with no coupon or special deal...ya know, that's a lot of kit for that money.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
