    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 11-23-2016, 05:54 AM   #4381
JoeRC123's Avatar
Originally Posted by caffeine357 View Post
http://www3.towerhobbies.com/cgi-bin...8&I=LXFSFP&P=K
Has anyone raced the Flo-Tek Fusion?
Usually i dont go pre cut but thus one isnt that much more expensive then a shell.
I use the Evo SC pre-cut. Really like it.
https://www.prolineracing.com/bodies/evo-sc-clear-body/
JoeRC123 is offline   Reply With Quote
Old 11-23-2016, 11:35 AM   #4382
shadaloo's Avatar
I love my JC Raptor Xflow for racing.. but still trying to find a few random practice bodies... thinking about trying the Proline Baja Buggy body, the JC Bug looks kinda weird... also the Proline Ford Bronco, and possibly if i can find one cheap, the Proline 2012 Ford Focus (since i drive a 2012 Focus Titanium IRL)..... I would love to make some kind of Losi SCBE body, or a Axial Wraith, Yeti, etc rock racer type look... but don't know what all mods it would take to make the Losi SCBE body work...
I was shocked at home much of an improvement the JC Raptor Xflow was compared to my JC Hiflow... it seems like it jumps a lot better and overall is more stable... was shocked at the change to a new body.
shadaloo is offline   Reply With Quote
Old 11-23-2016, 12:59 PM   #4383
Trader Rating: 32 (100%+)
First time i run my local track dang best SCT body that i have with large jump. I've been JC HF2, JC F250, JC illusion, proline evo and my previous body before proline flo-tek was parma SCT body i like the parma SCT body but not durable like proline flo-tek.
raved007 is offline   Reply With Quote
Old 11-23-2016, 05:00 PM   #4384
I too run a Proline Flo-Tek Raptor
Malazan is offline   Reply With Quote
Old 11-26-2016, 08:56 PM   #4385
Lowe's48's Avatar
Ok guys....what's the difference between the stock sct410.3 chassis Tkr5288 and optional chassis Tkr5000fb ??
Stiffness? Weight?
Lowe's48 is offline   Reply With Quote
Old 11-27-2016, 05:27 AM   #4386
mkl
Looks like the difference is in material, and anodizing method.
1. the 5000fb looks to be 7075 and not sure exactly what the 5288 is.
2. the 5000fb is hard anodized which should give you better wear characteristics.
3. the 5000fb front two diff mounting holes are countersunk to allow the bumper mod.
Both appear to be the lightened version
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 11-27-2016, 01:06 PM   #4387
Lowe's48's Avatar
Thx
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Old 11-29-2016, 06:57 AM   #4388
JoeRC123's Avatar
Anybody else popping holes in their shock bladders? Mine did it twice on same shock, rear left. I should do a full rebuild next time. Makes me think an o ring is damaged or missing.
Old 11-29-2016, 07:04 AM   #4389
Switched to emulsion shocks last week, and liked it a lot.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 11-29-2016, 12:00 PM   #4390
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Be sure that you have the shock shaft screwed all the way into the rod end, you might not and as a result the shaft is going too far into the body and able to touch the bladder. If you stop threading the shaft into the rod end when you cover up the last of the threads are no longer visible you should still have more shaft to thread into the shock end. Keep threading until the rod bottoms out in the end. I like to constantly move the ball around and as soon as I feel the ball get tight in the plastic I back the rod off slightly. Also check for burs in the shock cap.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 11-29-2016, 12:44 PM   #4391
JoeRC123's Avatar
Excellent advice. I'll check this. Thanks.
Old 11-29-2016, 04:22 PM   #4392
Trader Rating: 35 (100%+)
There is quite a bit more of the shaft to thread into the rod end, at least with my cars. I've heard this might also help set the ride height a little better (just finished my shock rebuild and haven't tested this yet). The Tekno shock tools help A LOT, to the point where it's actually fun to rebuild the shocks--a first for me.
Stanford55 is offline   Reply With Quote
Old 11-29-2016, 04:36 PM   #4393
I didn't have that problem but mine would suck the bladder in. Could never figure out why so I switched to emulsion. Its ok but I liked it better vented.
4s losi is offline   Reply With Quote
Old 11-29-2016, 04:57 PM   #4394
King DORK's Avatar
I never could get bladder shocks set up in anything except a Slash () that I used to race. Seriously, we had a special class for them. On my last Tekno I could not get the bladders to stay put even after watching tutorials or build advice. I know I'm losing "the touch" that I had many moons ago but emulsion setup is much easier and I do like the handling set up this way.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 11-29-2016, 07:27 PM   #4395
Originally Posted by King DORK View Post
I never could get bladder shocks set up in anything except a Slash () that I used to race. Seriously, we had a special class for them. On my last Tekno I could not get the bladders to stay put even after watching tutorials or build advice. I know I'm losing "the touch" that I had many mlooons ago but emulsion setup is much easier and I do like the handling set up this way.
When I first built it I did vented with no problems. After a couple of rebuilds this started happening. I replaced the bladders twice with no luck that's why I switched to emulsion. I agree it's easier but I like the way it handled better with vented shocks. Just seemed more consistent.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
