    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 11-21-2016, 02:27 PM   #4366
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Originally Posted by Malazan View Post
So I have a 3000kv on 3s, and a 3500kv on 2s
What pinion should I try first for each of these,
LOL, is a 20t to much for the 3000kv?
I see 16-18 on the 4000-4700kv motors, wouldnt a lower Kv motor necessitate a larger pinion?
use one of the common speed calculators out there and shoot for a theoretical speed of 35 to 40mph.
If you have someone who can suggest gearing at your track for a 4000kv to 4700kv motor, then just determine that theoretical speed for a starting point and find what achieves this with your current KV motors. From there, watch temps.
That will in general get you in the ball part.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 11-21-2016, 02:44 PM   #4367
justpoet's Avatar
Trader Rating: 16 (100%+)
A 16t should be a good place to start with the 3000kv on 3s.
A 21t should be a good place to start with the 3500kv on 2s.
You're correct in that a lower KV motor would normally run a larger pinion, but only if the voltage is the same. Since your 3000 is running 3s, the higher voltage actually cancels the need for a larger pinion out, since the motor will be spinning faster than it would be on 2s.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 11-21-2016, 03:06 PM   #4368
Lowe's48's Avatar
Originally Posted by sct_shift View Post
Hi folks,
I've been following this forum for a bit and I'm a big fan of Tekno.
Just about to pull the trigger on a sct410.3 and would thought i'll ask for opinions about the electronics.
I'm planning to use it for casual racing at outdoor loose coarse dirt BMX tracks some the size of 1/8 and some 1/10th. It's mostly going to be fun with friends and no RC clubs so no requirements for ROAR legal electronics.
I'm leaning towards Hobbywing for the ESC + Motor. Should I be looking at 3400, 4000 or 4700 KV for these sort of tracks?
My budget is up to $200 for ESC & Motor and I'm open to other suggestions besides HW
Cheers!
HW 4000 kv paired with this esc !!! You'll love it.
http://www.hobbywingdirect.com/produ...r8-sct-pro-esc
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 11-21-2016, 03:26 PM   #4369
Lowe's48's Avatar
Great coupons from Hobbywing !!
http://www.hobbywingdirect.com/collections/new-arrivals
Old 11-21-2016, 04:34 PM   #4370
Thank you
Malazan is offline   Reply With Quote
Old 11-21-2016, 04:35 PM   #4371
Thank you, that makes more sense, with the higher voltage
Old 11-21-2016, 05:16 PM   #4372
Just ordered! Thanks a lot Lowe. Can't wait now
sct_shift is offline   Reply With Quote
Old 11-21-2016, 05:46 PM   #4373
Lowe's48's Avatar
Glad I can help.
Old 11-21-2016, 08:14 PM   #4374
Trader Rating: 114 (100%+)
I was curious what setup people are using indoors, we are running slicks on a tight track with small jumps. I am traction rolling like crazy right now. I was going to try emulation shocks and I have the hrc rear hubs
Breeze is offline   Reply With Quote
Old 11-21-2016, 08:22 PM   #4375
Lowe's48's Avatar
Where are you racing? Got pics?
Old 11-22-2016, 07:41 AM   #4376
http://www3.towerhobbies.com/cgi-bin...8&I=LXFSFP&P=K
Has anyone raced the Flo-Tek Fusion?
Usually i dont go pre cut but thus one isnt that much more expensive then a shell.
caffeine357 is offline   Reply With Quote
Old 11-22-2016, 08:10 AM   #4377
Tech Legend
Cain's Avatar
post your setup.
When you say slicks, are you saying super soft or clay?
Out here the fast tekno guys are running on extremely high traction carpet with slicks clay compound. Some even use the harder proline tires like street fighters. Common things I can tell are they:
- Go with heavy sway bars
- stiffer springs
- Limit droop alot . Not uncommon to see the front come off of a jump with little droop, almost arms level.
That just from what I can tell visually. I am also assuming they are using smaller hole pistons, heavier shock oil, and heavier diff fluid too.
Old 11-22-2016, 08:25 AM   #4378
skinned's Avatar
there are a lot of these at the track I race...lots of speed holes...I would recommened...
skinned is offline   Reply With Quote
Old 11-22-2016, 08:27 AM   #4379
Yup, works fine. And the precut is perfect. I hate trimming bodies and putting holes in them.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 11-22-2016, 04:46 PM   #4380
I use a 17t on 3000kv on 3s. This is about the same as 17t on 4300, maybe 1 or so mph faster.
qstorm777 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
