    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 09-16-2016, 12:40 PM   #4021
Suspended
I love my DE wheels, as you can see on my avatar i use them on my EB as well. [:
-Tekno SCT/EB-
deceit is offline   Reply With Quote
Old 09-16-2016, 12:41 PM   #4022
mkl
Yes, the DE 17mm wheels are the ones I use as well. The only other complaint I have about the M2C is the once I started using them, I broke 4 axles. They were the older OG style axles from the original SCT410, not the newer 5mm ones. So I don't think that new new axles will break.
The special nuts are available separately from M2C.
One word of warning, the Tekno 17mm conversion makes the SCT way too wide. SCT are narrower than buggies. Won't be a problem just bashing around but will most likely interfere with the body.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 09-16-2016, 01:17 PM   #4023
Suspended
have you used them? i saw it made it a little wider, but didnt think it would be noticable.
it's still a legal width to race as sct too right? just clips the body?
-Tekno SCT/EB-
Old 09-16-2016, 02:29 PM   #4024
mkl
No, the Tekno 17mm conversion will make your SCT far too wide to be legal.
Tekno SCT410 Thread
Check out the SCT410 thread. There was a lot of discussion there about this. The 48SL axle kit places the hex much farther away from the hubs. The design of the SCT places the hubs at maximum width when the hex is almost flush with the hub. That is why the M2C conversion has no width to it, basically replaces the 12mm hex. Look carefully at the Tekno hex- it is placed far out on the end of the axle.
Hope that makes some sense.
Old 09-16-2016, 02:43 PM   #4025
Suspended
hmm... i was really interested in the tekno version of the 17mm.... im assuming it would be fine for club races, just nothing major. Is it very noticable by looking at it? or does it offer much handling differences being wider?
-Tekno SCT/EB-
Old 09-16-2016, 03:18 PM   #4026
mkl
measure how wide your EB48 is then compare it to your SCT. That will be the difference. The Tekno 17mm EB48SL axle/hex kit was made to make the SCT design (arm length, hubs etc) as wide as the EB48-1/8 scale buggy width
Old 09-18-2016, 07:31 PM   #4027
Suspended
My SCT was surprisingly good today, just wish it was as efficient as my EB.. wish my track would let us use 3s! Love the truck, but anything under 7200mah on 2s seems to die soooo fast.
Also I ordered those 17mm Tekno adapters, so I guess if I ever convert to SL ill use them, (local guy has been doing amazing with his SL). Hoping its not too awkward looking running the SCT wheels on the 17mm for practice.
Also anyone had issues with the front bumper? The screw from the front keeps stripping/falling out, so it flaps around a little... not a big deal, just annoying that I can't carry or grab it from the front without it flopping off...
-Tekno SCT/EB-
Old 09-18-2016, 07:34 PM   #4028
I run 8000 Mah - why not? helps balance the truck side to side.
17mm adapters! blasphemy!
everyone has issues with the front bumper, bent attachment bolts, doesn't fit, etc.. best advice? let it wear down to almost nothing at the skid plate and it will give you faster lap times - does not dig in when this notoriously nose heavy truck noses over landing a jump.
twistedneck is offline   Reply With Quote
Old 09-18-2016, 07:39 PM   #4029
Suspended
i need to get some better 2s. I have some 6000's, 5000's, and 7200's... my 4s 6500's last forever... just not used to my 2's dying so fast! I love my SMC 4's, might try the SMC 2's and see how I like them. What 8000 are you using btw?
Yeah I don't really need the whole bumper out there haha, just nice to have for keeping the body in one piece, that's about it. don't need the extra weight!
-Tekno SCT/EB-
Old 09-18-2016, 07:51 PM   #4030
These trucks like extra weight.. I have 1/2 oz of ballast glued to the rear port side of my 410.3 and it won last weeks indoor clay race.
I use pro-match 2s 8000 100C batteries. super cheap, pick your end type. I've tried to sizzle this and have trouble getting them to puff. for the price you can't beat it and they are lighter weight than most 7200's.
Old 09-20-2016, 06:59 PM   #4031
Any good carpet setup sheet
Tiggahanes is offline   Reply With Quote
Old 09-20-2016, 07:24 PM   #4032
Josh L's Avatar
Sounds like these> Hobbystar 8000 mah battery
Also just to note, the weight adding is fine and all, but have you considered the battery back mod or mounting the ESC behind the battery? This does what your doing now without having to add the weight to the chassis. Seems like that would give you even more of an edge with less over all weight.
Josh L is offline   Reply With Quote
Old 09-21-2016, 07:24 AM   #4033
What does that esc mod where you move it to the rear look like? Do you have to cut out the rear servo mounts? Do you just mount it to the chassis? How big of an impact does the mod have on the truck -seems like left side will become heavy?
Thanks.
qstorm777 is offline   Reply With Quote
Old 09-21-2016, 09:01 AM   #4034
Trader Rating: 18 (100%+)
Anybody use the Jconcepts Rulux wheels on the .3? They seem to be a tad bit bigger in diameter and width then say AKA Cyclone. Would that be an issue racing/rubbing the body? Thx
rcnewbie418 is offline   Reply With Quote
Old 09-21-2016, 09:06 AM   #4035
I wouldn't run them. They were prone to cracking. I don't think they even make them in the right offset for our trucks anymore.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
