    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree71Likes
Old 07-05-2016, 08:54 AM   #3916
Originally Posted by stanton120 View Post
Hey Guys,
I just picked up my new Tekno SCT410.3! I need a little gearing help. I am swapping over the electronics from my Slash 4x4. The motor and ESC are a Castle 2650kv and a Castle Sidewinder 8th ESC. I eventually plan to get a Tekin Setup but for now this is what I have. I run this setup on 3s and I am wondering what you guys think a good pinion to start with is?
Thanks for any help!
That setup is fine if your bashing, 3s isn't allowed for racing though. If you plan to race, better choose a motor in teh 4000kv-5000kv range and run on 2s.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 07-05-2016, 09:14 AM   #3917
MeasuresMicrons's Avatar
I'm not an expert on the SCT410.3 (or any of cars for that matter) I wouldn't even consider putting that castle system in your truck, I think it'll be a waste of time. I was a Castle fan and ran them for years but theres just way to many better options out there. Build the truck box set-up and save a lil money for the right system. take a look at the HW's, lota guys run em and since I've swapped out my Castle, I've been much smoother and more competitive.I bought mine with the SMC4500 and its a beast, I'm slowly getting her under control.
take a look here
http://www.hobbywingdirect.com/collections/sct8-sct10
Hey Guys, I just picked up my new Tekno SCT410.3! I need a little gearing help. I am swapping over the electronics from my Slash 4x4. The motor and ESC are a Castle 2650kv and a Castle Sidewinder 8th ESC. I eventually plan to get a Tekin Setup but for now this is what I have. I run this setup on 3s and I am wondering what you guys think a good pinion to start with is?
MeasuresMicrons is offline   Reply With Quote
Old 07-05-2016, 11:27 AM   #3918
Originally Posted by qstorm777 View Post
The kit wheel hexes are steel. Some people have tighten the set screw too much breaking the hexes. I would initially stick with the kit wheel hexes.
I would definitely upgrade to aluminum a block.
Those are the aluminum diff pins. Some people have broken the plastic diff pins. That's why I recommended the alum diff pins. I never ran the plastic diff pins - I went straight to the aluminum.
The delrin inserts are smoother than the stock shock inserts. It's not a must. It does improve performance though.
When going to order the aluminum pins http://www.teknorc.com/shop/tkr5149-...uires-tkr5150/
It says they require TKR 5150, do these come in the kit or do i need to order these with the pins.
http://www.teknorc.com/shop/tkr5150-...-tkr5149-pins/
caffeine357 is offline   Reply With Quote
Old 07-05-2016, 12:01 PM   #3919
Thanks for all the suggestions. I'll probably start with the 17t and go up or down from there.
stanton120 is offline   Reply With Quote
Old 07-05-2016, 12:17 PM   #3920
justpoet's Avatar
Trader Rating: 16 (100%+)
The required gears are the ones in the kit. That note is there because the very very original release EB48 had a different set of pins and gears in them. Everything since has had this newer style (easy to tell because of the flat sections at the ends of the pins) and is all cross compatible.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 07-05-2016, 01:07 PM   #3921
great, thanks for the quick reply
Old 07-05-2016, 06:52 PM   #3922
Tkr5149a are the alum cross pins and you don't need anything else. You have the correct diff gears.
qstorm777 is offline   Reply With Quote
Old 07-10-2016, 07:21 PM   #3923
Default Motor Recommendations
I have a trackstar Shortcourse ESC im going to need a motor for.
Since I want to go cheaper then tekin for my first truck and the SMC is on back order. Im deciding between the hobbywing 4700 and Maclan 4200.
Which one would you guys get for a setup that I will be running inside on a 16ish lap time track along with a rather larger outdoor track every once and a while on the weekends.
Ill likely have it turned down so I dont fly off the track indoors but want to make sure i have enough for big straightaways when i run out doors.
https://www.amainhobbies.com/hobbywi...100030/p279101
https://www.amainhobbies.com/maclan-...cl1004/p474295
Old 07-10-2016, 08:49 PM   #3924
Lowe's48's Avatar
I would go with y he Hobbywing 4000 kv motor.
Lowe's48 is offline   Reply With Quote
Old 07-12-2016, 02:18 PM   #3925
justpoet's Avatar
I would probably go HW or wait for the SMC to come off of backorder.
Old 07-12-2016, 07:16 PM   #3926
Anybody try the HW XR8 on 2S on the 410.3? Just want to make sure the 150A is enough especially running at 7.4v on bec.
Old 07-13-2016, 12:25 AM   #3927
gangstafish's Avatar
Get the plus.
craig
SCTE/RX8/Pro4/spectrum6100
IRH/UPURZ Racing/Team Underdo
Losi22/OrionR10pro/savox1258/Reedy17.5
Losi 8ighte 3.0/RX82/T8 1900/spectrum6100
gangstafish is offline   Reply With Quote
Old 07-13-2016, 05:54 AM   #3928
Originally Posted by gangstafish View Post
Get the plus.
Okay. Thats what I believe I have. I don't see just a XR8.
Old 07-13-2016, 06:28 AM   #3929
The XR8 will handle up to 6S in an E-buggy or truggy, you'll be fine.
Tijuana_Taxi is offline   Reply With Quote
Old 07-13-2016, 10:22 PM   #3930
Josh L's Avatar
I run one. Works great. It is large and heavy though, which is exactly why I am getting the Hobbywing XR10 very soon.
As nearly always, regardless of what you run you should implement an extra cap pack to help knock out the voltage ripple that plagues low voltage setups running 2S.
Josh L is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
