    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree81Likes
Old 06-27-2016, 11:43 AM   #3886
Originally Posted by Matthew_Armeni View Post
Trying lowering your anti-squat to 1 degree, really helps the truck jump level as well as give it more rear/side grip into turns.
I can't for the life of me figure out these pill placements and what they do. It just doesn't register.
What combination are you using for 1 degree antiquat?
Thanks in advance.
shanondink is offline   Reply With Quote
Old 06-27-2016, 12:14 PM   #3887
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Thanks in advance.
If you use the center pills in the A and B block you get 10 of kickup and no arm sweep. If you use the center pills in the aluminum C and D blocks you get 3 of toe in and 2 of antisquat. To get 1 of antisquat we typically go to center dot down on the C block. Alternatively you can go to double dot down on the C block and double dot up on the D (this should keep your roll center is the same location as running center center), or you go to center dot up on the D block which also slightly raises your roll center. The plastic C block moves the pills up one degree so center C / center D would give you 3 of toe and 3 of antisquat.
Basically, you need to just remember what the center dot pills give you then add or subtract degrees based on what pills you change to. Here's a chart showing all the possible pill locations -
[IMG][/IMG]
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 06-28-2016, 02:12 AM   #3888
[IMG][/IMG]
Awesome. Thank you!
Tibbar110 is offline   Reply With Quote
Old 06-28-2016, 08:31 AM   #3889
MeasuresMicrons's Avatar
Body question, after this weekend my 410.3 ran amazing. I need to tweak her a lil bit but she was just plain insane. My question is, are there any other body options for this? I would entertain anything but the SCT body, I was curious about a truggy body or even a buggy body. Our 1/10 class is sort of open to SCT's and 4WD 1/10's, sort of a free for all. But our 1/8's and 1/10 2WD's are legit. Any thoughts?
MeasuresMicrons is offline   Reply With Quote
Old 06-28-2016, 10:29 AM   #3890
Any body for the Team Associated, Losi, and Slash 44 will fit the Tekno SCT410 with minor changes to the body hole locations. The only direct fit body is the Losi SCTE body and it come pre-cut and the body post holes already reamed out.
All of these bodies
https://www.prolineracing.com/teckno...0-sc40-bodies/
weedsnager is offline   Reply With Quote
Old 06-28-2016, 02:03 PM   #3891
Suspended
Trader Rating: 17 (100%+)
I've seen the Losi truggy body fit
AC500 is offline   Reply With Quote
Old 06-28-2016, 09:06 PM   #3892
wrightcs77's Avatar
Trader Rating: 520 (100%+)
8th scale buggy body. This basically turns it into a eb48sl
wrightcs77 is offline   Reply With Quote
Old 06-28-2016, 09:11 PM   #3893
Thank you.....I like the idea of that also. I had a body lying around for my 22T I fit today, I ordered the front bumper, wing and wing mount for it. Thought about doing the 17mm hub kit and going buggy tires. Like I mentioned this is a balls out class we run for fun, anything 1/10 4WD goes. lol. Thanks again
Old 06-29-2016, 09:19 AM   #3894
so heres another body question, the 410.3 sores threw the air like an acrobat and sticks the landing like an Olympic Gymnast, if I did decide to change to a buggy body (like the idea) will this change the characteristics of the way she handles and jumps?
Old 06-29-2016, 10:02 AM   #3895
mkl
I would say it will jump even better. Big SCT bodies don't do much for airborne aerodynamics.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 06-29-2016, 10:29 AM   #3896
I do believe she may, but for some reason that big turtle shell sores over the triple as smooth as my TLR 4.0, I'd almost say with a slight advantage to the 410.3. I have everything on order so I'll try the buggy body first.
Old 06-29-2016, 10:41 AM   #3897
mkl
That is great that it is jumping so well for you. I have an EB48 and it jumps great. It does have the wing though, that helps I'm sure.
Old 06-29-2016, 10:47 AM   #3898
I'm going to put the wing on and run it too, I'm actually going to drop my 4.0 body on it and see if she can handle running with the 8's lol.
Old 06-29-2016, 11:32 AM   #3899
mkl
If you are going to be running in the 1/8 class and have wheels/tires, I would suggest getting these-
http://www.teknorc.com/shop/tkr5570-...gy-width-2pcs/
They allow you to run 1/8 wheels which are stronger and it brings the buggy to proper 1/8 width. And the axles are much stronger
Old 06-29-2016, 03:09 PM   #3900
yea thanks, I've been checking those out
Tags
sct410, sct410.3, short course, short course 4x4, tekno
