    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree81Likes
Old 06-16-2016, 03:47 AM   #3841
Default cap
no worries, happy racing!
szymanski2oo1 is offline   Reply With Quote
Old 06-17-2016, 01:30 PM   #3842
Lowe's48's Avatar
Originally Posted by Jordan Anderson View Post
I'm considering adding the HW cap pack just as a precaution. Haven't had any problems, but can't hurt right? Question is, where do you put the cap pack? Space is tight on these cars. Just zip-tie / shrink wrap it on the battery lead?
I know I put the ESC backwards from the way most of you do...
Shrink wrap mine...no room back there !!
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 06-17-2016, 03:02 PM   #3843
MeasuresMicrons's Avatar
I ran my SCT for the first time.....I was eFF'n blown away how fast this thing was. I bought it off a member here, HW SCT Pro ESC w/ SMC4500KV, this thing screws and handles like its on rails. very surprised, not to mention so were the other guys lol. Not the SCT I was expecting.
MeasuresMicrons is offline   Reply With Quote
Old 06-17-2016, 06:10 PM   #3844
Kremzeek's Avatar
I've got a bunch of tires left over from my SC10. I tried them on my SCT410 and they almost work but in some cases they rub a little. It looks like TKR1654X adds another 1mm of offset. Any idea if this will give me enough clearance to run my old tires? I really don't care about being ROAR legal.
Kremzeek is online now   Reply With Quote
Old 06-17-2016, 07:20 PM   #3845
Lowe's48's Avatar
These might work ??
http://www.avidrc.com/product/5/acce...cessories.html
Old 06-17-2016, 08:14 PM   #3846
Kremzeek's Avatar
Originally Posted by Lowe's48 View Post
I didn't realize that something like that existed. I might have to give them a try.
Old 06-17-2016, 08:25 PM   #3847
I've heard of these.......my only concern is that your pulling the wheel hub further away from the hex, causing less area for hub/hex grip, possibly resulting in stripping the hub. No?
Old 06-17-2016, 10:40 PM   #3848
Kremzeek's Avatar
Yeah, I thought of that. For $5 more I'll probably just get the wider hexes.
It looks like the hinge pins are rubbing on the inside webbing of the wheels (Proline F11). I may just take a dremel to the pins and cut off the excess threads.
Old 06-18-2016, 06:55 AM   #3849
Lowe's48's Avatar
I think dremel is a better way to go.
Old 06-18-2016, 07:12 AM   #3850
Taking meat off the bone? Wouldn't this ruin the structure, integrity and rigidity of the wheel? Why not just get what fits? I have a set of wheels that came with the truck that rub the back arms, I wouldn't think to modify the wheel, I would think this only weakens a very crucial part of the truck?
I may be wrong, and I'm sure I am if you ask my 2 ex wives, lol. Just my .02's
Old 06-18-2016, 07:30 AM   #3851
Lowe's48's Avatar
Ha ha poor guy....2 ex
Not saying taking a whole lot out of the wheels...just enough not to rub. I personally don't use those F11 anyway , to me they are too soft and too inconsistent for my racing application. DE wheels are the ones I like
Old 06-18-2016, 07:45 AM   #3852
Yea I purchased the DE Speedlines thats recommended for the SCT410.3. Picking them up today.
Old 06-18-2016, 07:50 AM   #3853
Kremzeek's Avatar
I was going to dremel the hinge pins. Not the wheels.
Old 06-18-2016, 12:12 PM   #3854
I had the same issue with different brand and style wheels, i installed the +1 tekno hexes and now most of them fit with just enough clearance
Hope that helps
mikeinsocal is offline   Reply With Quote
Old 06-18-2016, 12:57 PM   #3855
Fader12's Avatar
Ok Thanks that helps!
Fader12 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
