    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 04-16-2015, 02:10 PM   #361
Default Tower Hobbies Order
Has anyone received an informative answer from Tower Hobbies when orders will be filled - is current mid May date for all open back-orders or only new orders? What about orders that were placed in March but are not filled yet? Here is the canned/typical/useless answer I got back:
Dear Tower Hobbies Customer,
Thank you for contacting Tower Hobbies. We apologize for the delay in receiving your back order. We are given estimated times of arrival from the manufacturer and these are subject to change at any time. These types of delays can be attributed to a number of factors, such as manufacturing or shipping problems. These delays can also be attributed to the possibility that we are not receiving sufficient quantities to fulfill all back orders. Our website is consistently updated with any availability changes, so you may check estimated arrival dates for out-of-stock items 24 hours a day. Thank you for your patience in this matter.
We appreciate your time and business.
RC10GT (LRP), T-Maxx, LSP (P5), SC10RS, SC10.2 (Reedy), 8ight-T 2.0 (Maxy's Cinco), 8ight-E 2.0 (Castle), MBX6Eco (Tekin)
vlamimc is offline   Reply With Quote
Old 04-16-2015, 02:13 PM   #362
Default BEC or Direct
On a lighter note, are most planning to run the steering servo off a BEC or go direct to battery? I'm planning to put a HW SCTPro in.
Old 04-16-2015, 02:42 PM   #363
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
from what I was able to find out, sounds like there is a WHOLE LOT OF ORDERS at tower for the vehicle and Tekno is filling these as well as other places as fast as they can, in batches here and there.
So it will be interesting to see how the orders go.
As for servo, will be using the internal BEC, from the RX8 Gen 2.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 04-16-2015, 03:01 PM   #364
vlamimc
You Know I got the exact same email Nice to get that personal touch
jjl1 is offline   Reply With Quote
Old 04-16-2015, 03:58 PM   #365
matlock797952's Avatar
There's one on eBay right now! Better hurry!for $450 though
Matt Naibert
*TEKNO *EB48.3*SCT410.3*
*TEKIN RX8.2 RX8 T8 PRO4 4600
*FHR* SJRC-RIP
"Loose is fast and on the edge of out of control" - Harry
matlock797952 is offline   Reply With Quote
Old 04-16-2015, 04:15 PM   #366
Mikeand22's Avatar
Trader Rating: 23 (100%+)
I can't imagine paying that much for this truck just for convienence.
Mikeand22 is offline   Reply With Quote
Old 04-16-2015, 04:22 PM   #367
I agree. But it is Still cheaper than a losi
Matt Naibert
*FHR* SJRC-RIP
Old 04-16-2015, 04:41 PM   #368
Orion_2kTC's Avatar
So this is going to be my first SCT ever and the first time I've pulled the trigger on a car in a while. My past experience include 2wd stock buggy and 1/8 EBuggy. I intend to set my throttle EPA to 50% for several battery packs just so I can get used to driving again and get a feel for the car. Is there anything else I should expect while driving this thing?
Setup once assembled, if it matters:
Tekin RX8 Gen 2/Tekin 4300 HD
Futaba 4PX
Hitec Servo
SMC batteries
Orion_2kTC is offline   Reply With Quote
Old 04-16-2015, 04:53 PM   #369
Not true, still have to buy a body and wheels
Mdavidson217 is offline   Reply With Quote
Old 04-16-2015, 05:00 PM   #370
Tech Legend
Cain's Avatar
Futaba 4PX
Hitec Servo
SMC batteries
probably the biggest thing I can think of is watch how the vehicle reacts to abrupt jumps relative to nosing down.
Old 04-16-2015, 05:17 PM   #371
fq06's Avatar
Like cain said the jump characteristics of this truck (most 4x sct's) is about the only learning curve coming from those rigs you're used to.
You have to hold a little more throttle in the air than you're used to.
You have the right strategy, build speed up over a few days of running it.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 04-16-2015, 05:29 PM   #372
Tech Legend
Cain's Avatar
one thing I wonder, I know the common attempt to fix is the battery tray mod, but curious what the results were is someone left the battery in stock location, but then added weight to the rear and how much.
Old 04-16-2015, 05:39 PM   #373
fq06's Avatar
I don't really see a big difference in flight attitude with moving the pack. I see more or less rear traction with the shift.
Your season should be starting soon, you should play around with it and see if it is more of getting shock setup right or weight bias.
I think that once you have your suspension setup right for your track moving the pack will be more of front vs rear traction.
I have gone back to a front position pack just to see and really didn't see a huge difference in the air. I do prefer the pack to the back so the forward position was brief.
Old 04-16-2015, 05:47 PM   #374
I have done this on mine and it works great. I added the amount of weight it takes to balance the trucks weight distribution. This will be different for everybody's setup but for me I added 3 oz in the servo bay. I had to use shoe goo to keep it in there.
crash n go is offline   Reply With Quote
Old 04-16-2015, 05:51 PM   #375
fq06's Avatar
Yeah, true crash n go, I have 4 pieces of lead weighs that are... what 7g each or something right in the furthest back and outside corner where the brake servo would be. Have for over a year.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
a1, Bob Barry, celt
