    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 05-30-2016, 09:03 AM   #3721
JoeRC123's Avatar
Originally Posted by HoldDaMayo View Post
broke my first thing on the SCT410.3... and it's a strange one... shock bladder! Somehow got a hole in the middle... was very small, hard to notice until you kind of stretched it out, but it was leaking a good amount of oil because of the hole... a bit messy and annoying, but at least the truck still actually drove pretty well for about 6 packs after I noticed the leak, just filled a little oil every once in a while.
Question, I ran the stock vented setup, if i were running the emulsion setup I wouldn't have to deal with holes in bladders... think it's worth making the change for?
Thanks.
Dude, you are my hero on Memorial day. Luckily today I found your post in a search of this thread. I had oil oozing out of the top of one of my rear shock's vent hole. This morning I must have re-filled and bled out the oil a half dozen times and it still leaked. I thought maybe the bladder wasn't sealing right, in there crooked. Then I read your post and decided to stretch out the bladder to look for a hole. It was exactly as you found. There was a defect in the bladder and it was right in the top middle of the dome. Like where the rubber was poured in the mold at the factory that made the bladders. Man this was driving me nuts. All I need is a new bladder. Heads up to others with this problem!!!
JoeRC123 is offline   Reply With Quote
Old 05-30-2016, 09:36 AM   #3722
Originally Posted by weedsnager View Post
Twice I've been at the track and I've realized that my 4wd truck was really only a 2wd truck.
The diff. Coupler was not tightened down, it was just spinning. I'm putting lock tight on the treads and tightening what am I doing wrong ?
I ordered longer set screws off a machine shop website. Or grub screws as they also call them, I bought 8mm or 10mm length, but basically doubled the length and the cone tip bit in way better. Replaced all the shitty stock ones after it kept my motor gear locked in better and doesn't cause any clearance issues anywhere I have seen. 10 or 8mm grub screw m5, google that, lol. Your welcome in advance! Been awhile since I have been on here, it's nitro season so I haven't run my electric sc in a long time since all the servo issues I had with Protek my Tekno never got off the ground.
Billthebutcher is offline   Reply With Quote
Old 05-30-2016, 10:13 AM   #3723
JoeRC123's Avatar
This is totally stupid question but you are tightening the set screw onto the flat correct? If so is the set screw backing out that far with the lock-tite on it?
Old 05-30-2016, 07:56 PM   #3724
Kremzeek's Avatar
Ugh.. looks like the rear driveshafts are bent a little too.
Kremzeek is offline   Reply With Quote
Old 05-31-2016, 01:14 AM   #3725
What is the best servo for 410.3
4rd4 is offline   Reply With Quote
Old 05-31-2016, 04:23 AM   #3726
JoeRC123's Avatar
Protek 130T in mine and works awesome. Comes with an aluminum servo arm. Gobs of torque.
jpcopeland1 likes this.
Old 05-31-2016, 06:20 AM   #3727
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Sounds like you guys may be running a fair amount of rebound in your vented bladders and hydraulically forcing the bladder through the vent hole on hard suspension compression. It has nothing to do with the build of the bladders. Also, Kyosho bladders will work along with Serpent bladders and probably tons of other makes as well. I've tried the Kyosho bladders myself and really like them.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-31-2016, 08:39 AM   #3728
JoeRC123's Avatar
Interesting. Thanks for the input. I didn't know that was possible. So the fix would be build the shock better or use a different bladder? Only one of my rear shocks did this. I try to to build the shocks dead, with very little rebound. But it always seems to rebound very slowly no matter how I do it (plunger all the way in).
Old 05-31-2016, 08:54 AM   #3729
ryan432greening's Avatar
How do the folks over at Team Psycho Dog build a bladder shock with less rebound?
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 05-31-2016, 09:17 AM   #3730
8ight-e's Avatar
Trader Rating: 57 (100%+)
Not hard to set rebound on bladder shocks.
Move the piston to where you want it to rebound (push it all the way in for zero rebound), make sure to cap off the oil, push the bladder down so the excess comes out. At that point pull the shock shaft down a smidge so the bladder stays in place and screw on the top cap.. easy and done. Best way to run shocks. Typically around 30% in the front and 10% in the rear is nice, just an opinion though.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 05-31-2016, 09:21 AM   #3731
What do you figure this is doing to the bladder as you extend the shock fully. It would be pulling down on the bladder with decent force at this point, would it not?
B-Main Racing
GFRP M1
Old 05-31-2016, 09:28 AM   #3732
Also, what's the fix for those darned leaky diffs right from the kit build these days?
B-Main Racing
GFRP M1
Old 05-31-2016, 09:40 AM   #3733
8 kits later, I've only had one leaky diff..And tightened the diff screws a little more, and never an issue since. So not sure what leaky diffs your talking about. You do have to torque the screws down a bit, and always do a star pattern when doing so to tighten evenly.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 05-31-2016, 10:53 AM   #3734
Kremzeek's Avatar
What sort of grease do you guys recommend for the gear boxes? I have some black grease from AE and Durango. Will that work okay?
Old 05-31-2016, 12:09 PM   #3735
That will work just fine. You don't want to gob it on, just enough to put some there.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
