    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 05-26-2016, 07:06 PM   #3691
Originally Posted by mkl View Post
Yep- Tekno is the only company that I know if that is using 5mm axles. The 4mm were breaking a lot so their solution was the 5mm end.
My solution is the SL stub axles with Traxxas 17mm hex. That way I can use my Hudy station.
Also you can use TKR5571-17. It is a plastic hex conversion kit from Tekno. The plastic hex's don't work very well on the truck so throw them out, but you won't use them on the setup station. If you have the Hudy 1/8 set up station, the round parts in the photo in the link below are used to adapt the set up parts to the truck. The step on the round plastic part fits the axle hole on the set up tool, then use your wheel nut to tighten it down. I know it will be difficult to visualize but once you have it you will see what I am saying. You may have to ream out the hole in the round plastic part to fit the 5mm axle (they were designed for the 4mm axle), but the system works, tedious to install, but it works and cheap. I have been using it for a couple years with my SCT and does very well.
http://www.teknorc.com/shop/tkr5571-...ct-width-4pcs/
BTW- how much do you want for the 1/8 Hudy nuts? Not much use to you, but I could use them for my EB and now my SCT. PM me if you are interested in selling.
Gotcha MKL, I was going to pick up an aluminum dowel and cut and tap out my own .. Maybe scrap my idea who knows. Hey , tks for offering but now I gotta buy buy an 1/8 scale buggy to use them wheel nuts ..
SerpJimmy is offline   Reply With Quote
Old 05-27-2016, 11:03 AM   #3692
Kremzeek's Avatar
I recently picked up a used 410.3 and I'm in need of a servo. What's the best bang for your buck as servos go? I'm going to be racing on a large, outdoor 1/8 track.
Also, are there any spare parts, springs, etc. that I should pick up right away? The truck already has a couple aluminum hinge pin blocks (A and D?).
Kremzeek is offline   Reply With Quote
Old 05-27-2016, 01:02 PM   #3693
im using xpert 4431servo its pretty good,..
springs yellow, green,black & pink
a,b,c,d block
shock fluid 30wt +
shock boots
17 pinion
54 spur
Shims
Old 05-27-2016, 06:14 PM   #3694
Is the sct410.3 better then the losi scte 2.0?
proliteandsc is offline   Reply With Quote
Old 05-27-2016, 07:02 PM   #3695
Josh L's Avatar
That's an impossible question to answer. TLR fans will say no, while Tekno fans will say yes. But there are some people like myself who have both to play with.
My SCTE 2.0 is unquestionably lighter and quicker in some aspects, but the tekno stay planted in many scenarios a lot better that the SCTE. The tekno is much easier to tune to a track and over all requires less maintanance over time. They are both very tough trucks, so much so that I don't see any difference in crash durability.
The SCTE can turn in quicker it seems and is well suited to indoor and or smooth high traction tracks, but the tekno is good in any situation it seems. While one has more here the other has more there and vice versa. But as a long time losi fan I honestly feel the 410.3 is over all the better truck with all considered. But that is just my opinion and doesn't stand as fact. Consider the tekno is really the only comp the 2.0 has. You will see the podium with either truck. But it seems easier to get there with the tekno with minimal upgrade needs. You will spend much more on the losi in the end, I can promise you that.
Josh L is offline   Reply With Quote
Old 05-28-2016, 05:35 AM   #3696
Thanks for the input. I have a SCTE 2.0 now. Getting a EB48.3, and was wondering if its worth selling the Losi and getting a SCT410.3.
Old 05-28-2016, 12:30 PM   #3697
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
proliteandsc: I guess the big thing I would see about finding out is if the whole nose down jumping thing has been solved and the rough / loose track handling improved in comparison to the losi.
I am actually curious on that, is the sct410.3 now planted on loose tracks and doesn't have the nose down jumping issue? And if these were fixes done after the sct410.3 was released, what parts / setups have fixed this.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-28-2016, 02:15 PM   #3698
Kremzeek's Avatar
a,b,c,d block
shock fluid 30wt +
shock boots
17 pinion
54 spur
Shims
Thanks Jimmy.
Does anyone have any recommendations for diff fluid? The manual says 7K for front and center and 5K for rear. Is that a good start or should I be going higher?
Old 05-28-2016, 02:21 PM   #3699
mkl
I think that is a good place to start for diff fluids. I run 7/7/3
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 05-28-2016, 02:36 PM   #3700
Lowe's48's Avatar
Originally Posted by Kremzeek View Post
Thanks Jimmy.
What type of track will you be running on?
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 05-28-2016, 04:33 PM   #3701
RCMamba's Avatar
Any used SCT410.3 for sale?
RCMamba is offline   Reply With Quote
Old 05-28-2016, 05:05 PM   #3702
Thanks Jimmy.
our current track is fast with small jumps so I can run very soft springs - black in the front and pink in the rear.. but I use huge 2.7mm swaybar in front and I think 2.6 in the rear? To make this setup work on the high speed high throttle sweepers w/ step downs.. you need thick as hell diff oil.
15k front
10k middle
10k rear.
this allows for serious steering if you encounter body roll - powers out of anything and does not whip around with one wheel holding all traction and the other going pizza cutter mode then landing like that and the pizza'd wheel shoots you sideways.
for a big jump track I had to go back to stiffer springs, smaller bars, and the 7/7/5 diff setup.
Hope that helps - ps I run 1/2 oz of weights at the back speed control area, I have the battery mod, and running a 16 pinon spur helps control the movement in the air (15 tooth was not enough to dig it out of a bad nose over).
Hope that helps.
twistedneck is offline   Reply With Quote
Old 05-28-2016, 05:34 PM   #3703
Kremzeek's Avatar
It's a big 1/8 scale track. It's dirt (real dirt) and conditions can vary a lot. Usually, its dusty with low traction.
https://www.youtube.com/watch?v=v7_80ypwgbc
Old 05-28-2016, 05:42 PM   #3704
Super nice track.. was that an 8min main? Did the orange truck win and was it a Tekno 410.3!!! these things I must know!
Old 05-28-2016, 06:21 PM   #3705
Angle of approach :
Bumpy track & steep angle jumps.
The front bumper needs to be removed to increase angle of approach beyond 50deg. Front bumper seems to be coming in contact with the ground before the wheels. Causing severe nose over by jamming the chassis into the ground.. The bumper lower bolt hole always full of dirt is a tell tail sign. Once removed your still able to run a lower ride height. However , now i'm looking to fit the 1/8 eb 48.3 part# tkr 5166 bumper. Which is much lower profile . Will it fit ? Starting to think this is due to wheels being to small for this rig..
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
