    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 05-24-2016, 07:10 PM   #3676
Lowe's48's Avatar
Originally Posted by Scottysspeedsho View Post
Thank you sir
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 05-24-2016, 07:21 PM   #3677
Lowe's48's Avatar
Originally Posted by SerpJimmy View Post
With those springs I wasnt able to get ride height down that low.. Unless I brought shocks all the way out . Shocks all the way out werent working on tracks with alot of jumps..
Indoor ,high bite, alot of jumps , Fairly smooth: I started with yellow , then to green. These were to high and bouncing around to much. So now using pink. Going to try blk next. But as of now IMO anything heavier then say pink is maybe more for a heavier 1/8 set up. Things might be totally different outdoors ...
Jimmy
I cut one coil of my front/rear springs.I running them at 21mm,fr/22mm,rr with VRP pistons(5x1.5)/Losi oil 20wt front and rear. Works great on indoor high-bite track. I actually run the same combination on my 1/8 super-lite on 4s with the exception of the ride height....22mm,fr/23mm,rr
Old 05-24-2016, 08:00 PM   #3678
Originally Posted by Lowe's48 View Post
Jimmy
Yea bro, it def crossed my mind as far a trimming a set of yellows or greens. But what stopped me is , if its wrong a new set is on the other side of the US & 7 days wait.. Yep , that ride height is pretty much the sweet spot..Indoors anyway..
SerpJimmy is offline   Reply With Quote
Old 05-24-2016, 09:16 PM   #3679
I have a TA SC5M 2WD running on a medium outdoor dusty loose track. They run the 2WD and 4WD's together. My 2WD on that track is like driving on ice. It is a lot of fun, but I can't run with the 4WD's. The Tekno is now on my short list.
I would like to share the same batteries I use for my Losi 1/8 which are 4S 5800's. The Tekno tray is the right size. BTW, the track does not care what batteries you use. Has anyone used a 1/8 ESC and motor in this? In my Losi 1/8, I run the Mamba 2 with Neu 2200KV motor on 4S and 6S and could not be happier. I am open to an ESC and motor combo that is lighter that can run on 4S. Thoughts?
Tower Hobbies has this for $369 with a $60 off coupon if you spend over $379 and free shipping.
Cabledawg is offline   Reply With Quote
Old 05-26-2016, 01:22 PM   #3680
RE: Size of wheel nuts ?
As per Manual:
TKR1215 Wheel nut is a...
Page 12- M4 Nut
Page 25- M5 nut
Anyone know which one it is ? Thread size?
Old 05-26-2016, 01:41 PM   #3681
DirkW's Avatar
As per Manual:
Page 12- M4 Nut
Page 25- M5 nut
Manual says "M4" once, "M5" twice and Google gives you this:
http://www.teknorc.com/shop/tkr1215-...ed-black-4pcs/
So chances are that "M4" is probably just a typo...
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 05-26-2016, 02:03 PM   #3682
The 410.1 uses an M4 and the 410.3 uses an M5.
crash n go is offline   Reply With Quote
Old 05-26-2016, 04:47 PM   #3683
Twice I've been at the track and I've realized that my 4wd truck was really only a 2wd truck.
The diff. Coupler was not tightened down, it was just spinning. I'm putting lock tight on the treads and tightening what am I doing wrong ?
weedsnager is offline   Reply With Quote
Old 05-26-2016, 05:06 PM   #3684
Try cleaning all threads with denatured alcohol or =. Before lock tight..
Old 05-26-2016, 05:18 PM   #3685
Wheel nut - What brought this on was I wanted to purchase Hudy quick wheel nut for there set up station. So I ordered the off road 10 scale nut reverseable,, no good . to small. Then I ordered 8th scale wheel nut ,to big no good again.. Now Im stuck with $60 worth of nuts ... Terrific!. So I called Hudy . Turns out they dont make 5mm which from what they say is kinda limited to the 410.3..
Old 05-26-2016, 06:31 PM   #3686
mkl
like he said clean and lic-tite Blue doc-tite is essential.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 05-26-2016, 06:34 PM   #3687
I have used loc tite from the intital build, just never cleaned. You guys cleaned the screw on the initial build ?
Old 05-26-2016, 06:41 PM   #3688
mkl
Yep- Tekno is the only company that I know if that is using 5mm axles. The 4mm were breaking a lot so their solution was the 5mm end.
My solution is the SL stub axles with Traxxas 17mm hex. That way I can use my Hudy station.
Also you can use TKR5571-17. It is a plastic hex conversion kit from Tekno. The plastic hex's don't work very well on the truck so throw them out, but you won't use them on the setup station. If you have the Hudy 1/8 set up station, the round parts in the photo in the link below are used to adapt the set up parts to the truck. The step on the round plastic part fits the axle hole on the set up tool, then use your wheel nut to tighten it down. I know it will be difficult to visualize but once you have it you will see what I am saying. You may have to ream out the hole in the round plastic part to fit the 5mm axle (they were designed for the 4mm axle), but the system works, tedious to install, but it works and cheap. I have been using it for a couple years with my SCT and does very well.
http://www.teknorc.com/shop/tkr5571-...ct-width-4pcs/
BTW- how much do you want for the 1/8 Hudy nuts? Not much use to you, but I could use them for my EB and now my SCT. PM me if you are interested in selling.
Old 05-26-2016, 06:43 PM   #3689
mkl
damn auto correct- yes, clean and blue loc-tite. You have to let it cure before it is really effective, so do it at least the day before you plan to use the truck. Make sure you have a good sharp tool so you don't strip the screw, and tighten that grub screw nice and tight.
Old 05-26-2016, 06:57 PM   #3690
Default Loc tite alternative
Please stop using loc tite. I've been using this stuff for years, nothing falls off or comes loose in my rigs. This stuff is specifically made for high shock and vibration. I use the 30cc because I use it on more than just RC but the 5ml tube would last a good long time for rc stuff.
https://www.vibra-tite.com/products/threadlockers/vibra-tite-vc-3-threadmate/
jpcopeland1 likes this.
Danger Dietrich is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
