    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 05-04-2016, 05:30 PM   #3571
We got a 2 sets of barcode 3044 from amain 3 months ago that came punched out. Got 3 sets 3044 in the mail today that are not punched out ... Kinda strange goings on here ,, gents..
SerpJimmy is offline   Reply With Quote
Old 05-05-2016, 05:08 AM   #3572
Never seen New Tires come punched out.
Whosold is offline   Reply With Quote
Old 05-05-2016, 05:21 AM   #3573
Yea , they came sealed in the pack from Amain. At the time we just over looked it and just ran'em..
Old 05-05-2016, 08:46 AM   #3574
As per Amain tech today,, Jconcepts just RECENTLY STOPPED punching holes in tires. Reasons-
1. Dirt will get into tire and not escape
2. *Tires tearing out around punched hole..
Old 05-05-2016, 09:02 AM   #3575
mkl
Do it or don't- next topic please.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 05-06-2016, 01:46 AM   #3576
Default Setup help
Anyone got a good indoor high bite clay track setup.
GETDAT is offline   Reply With Quote
Old 05-06-2016, 04:57 AM   #3577
Trader Rating: 16 (100%+)
Start with joes southern nats setup on website, just reduce ride height and droop. Works great.
Steve Downs
Team Kyosho, AKA Tires, COWRC, BOOMrc, Triton RC Engines, FTM Grip, Boca Bearings
steve downs is offline   Reply With Quote
Old 05-06-2016, 05:41 AM   #3578
Josh L's Avatar
Made this Tekno spec work stand for my girlfriend's 410.3.
Fits the trucks chassis like a glove and holds much more steady that any platform I have used before for any vehicle. There are still a lot of little things I am working out, but when I am done it will hold all the Tekno tools and shocks.
They are built from 5mm ply that I cut with a 100 watt Co2 laser from vector files I designed as interlocking parts.
Josh L is offline   Reply With Quote
Old 05-06-2016, 08:11 AM   #3579
mkl
That looks fantastic. Great job. Think about selling them? I bet more than a few people would want them. Post this in the other Tekno threads as it should fit the EB48 as well.
Old 05-06-2016, 08:33 AM   #3580
Does anyone know where this setup is on.
Old 05-06-2016, 08:45 AM   #3581
Teknorc.com scroll to the bottom for filled setup sheets
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 05-06-2016, 11:34 AM   #3582
DirkW's Avatar
Right here: http://www.teknorc.com/setup-sheets/ ?
Dirk
Current cars: Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): (Xray T4'18) | Xray X1'17(8) | Yokomo YZ-2 DTM | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 05-07-2016, 04:27 AM   #3583
Josh L's Avatar
Yes I intend to sell these. I already sell MIP hex driver holders, but I thought making a system that did nearly everything in one unit would be the real winner, so I am going to offer these as another option.
I emailed Tekno about the use of their logo with an item I intended to sell so as to avoid any legal matters and because it just looks right on the stands.
They where very kind and granted me permission.
That being said, these stands are being revised right now to hold not only the truck, but many of Tekno's tools. It will have room of their shock cap 17mm wrench tool, shock pliers, 3 hex drivers - 1.5mm, 2.0mm, 2.5mm, one or two nut drivers, their turnbuckle wrench and will include shock rebuild ports. Will likely have a small screw tray and a 5v LED flex light, and flexable 3rd hand clips for holding wires in place for soldering motor and ESC's.
Can't really think of anything else that could be better.
You can see the hex stand I currently make and sell on my Etsy store here>
MIP Hex Driver Stand
Old 05-07-2016, 04:37 AM   #3584
Hey Josh , Any gains with those rims like that? Those one piece?
Old 05-07-2016, 05:14 AM   #3585
Josh L's Avatar
They are single piece.
These are DE Speedline plus wheels.
In my opinion the very best you can have out of all the types I have tried.
They hold very rigid and have ribs on the inside span of the wheel that keep soft tire foams from rolling out on the side wall as much as they would without them. This is very noticeable with tires and foams like those found on SS Panther Boa's.
They are super easy to glue and have a perfect sized tire bead groove on them.
I never personally liked the look of the solid rims, but the performance gains I feel with them cause me to blind eye the notion of it.
I run them on my SCTE as well
Tags
sct410, sct410.3, short course, short course 4x4, tekno
