    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 04-25-2016, 10:01 AM   #3481
Originally Posted by FAO View Post
Tekno RC created this layout for a 1/8 scale buggy with 4 cells at the left side. So that΄s nearly double the weight of our batteries with 2 cells.
i dont know about that cause , as per phone conversation with tekno . that truck was tekno balanced & fitted for 2 cells. i just never bothered to ask for the battery weight . due to my set up being 3 cell.
SerpJimmy is offline   Reply With Quote
Old 04-25-2016, 10:08 AM   #3482
Originally Posted by Lowe's48 View Post
It was around 60% right and 40% left. My battery is 331 grams.After the mod the weight bias is now almost 50/50 front to rear and left to right.
Does it jump level with very little throttle input and is easy to correct in the air?
qstorm777 is offline   Reply With Quote
Old 04-25-2016, 12:30 PM   #3483
Lowes48 I will be the next to do this. Been thinking of doing this after I saw a post on a different forum of someone doing this. Did you have to change much on the rear setup with more weight back there. I see you have real short rear links. And if I may ask why do you have your shocks in on the tower in the front. And out on the tower in the rear? I run a track just like that. With that kind of clay and I run M4 primes just like you are.
taz169 is offline   Reply With Quote
Old 04-25-2016, 01:27 PM   #3484
8ight-e's Avatar
Trader Rating: 57 (100%+)
Is there a recent 'pro' setup for this truck. Looking for something on a med bite hard packed dirt.. grooves up in the line a little bit at times w/ some loom on the edges.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 04-25-2016, 01:33 PM   #3485
Look for Jeremy's setup from dirt road stampede. I liked it a lot.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-25-2016, 06:44 PM   #3486
JoeRC123's Avatar
Just picked up a new kit for one of these and found this cool thread. Bought it for indoor dirt track a mile or so from my house. I'll be around.
JoeRC123 is offline   Reply With Quote
Old 04-25-2016, 07:47 PM   #3487
Lowe's48's Avatar
[QUOTE=SerpJimmy;14504985]So i'm now wondering what Weight battery tekno used to balance ?
Also, To eliminate some inconsistency, did you also balance without shocks & Wheels attached ?
Was Car coming in contact with scale in exact same location on all scales?
Switch scales around?
I noticed you removed the mud guards from earlier photo . Reason for that ? [QUOTE]
I think the only way to have the original configuration balance is to use the heaviest 2s you can find,low profile servo,lightest esc like Orion r10 and a 540 can motor. And maybe it might be close but the choice of those components are limited!!
I would never run my car without shocks/wheels so....no i didn't weight the car without those , unless i'm missing your point.
I did weigh it several times and the results are the same. The first 3 pics are my friend's car i was working on . I do not run mud guards.
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 04-25-2016, 08:04 PM   #3488
Lowe's48's Avatar
To be honest,I don't think that the stock configuration have any thing to do with the nose down issues that a lot of people are complaining about.To me its more the set up such as springs,oil and perhaps the anti-squat that would have more influence with an attitude of the car in the air.
Here's a video of my truck(yellow/white) on a very good size triple without holding on to the throttle or using brake.
https://www.youtube.com/watch?v=E3TGTug73lE
Old 04-25-2016, 08:20 PM   #3489
Lowe's48's Avatar
Hey taz
Regarding to the rear,I'm running the same setup as I did prior but I actually lighten the oil up front to help the weight transfer while going through turn.
Our clay is very very very tacky and will traction roll anything including stock,mod and 4x4 buggy with 15mm ride height. I run short link in the rear because I want a lot of camber gain when I'm going in the turn. Same reason why I run the shocks that way.I'm just trying to loose the rear end so it doesn't grab going in to the turn and traction roll. So,I lean the front shocks in for more bite and stand up the rear for less bite.
I hope that help.
Old 04-25-2016, 10:10 PM   #3490
[QUOTE=Lowe's48;14506040][QUOTE=SerpJimmy;14504985]So i'm now wondering what Weight battery tekno used to balance ?
Unbalanced wheels need to removed when balancing entire truck due inconsistencies. Or weigh & balance them ..
Shocks need to removed due to variable shock oil fill level/weight. *More importantly , Inconsistent / variable spring rates can influence down pressure on wheels.
Old 04-25-2016, 10:40 PM   #3491
Lowe's48's Avatar
[QUOTE=SerpJimmy;14506193][QUOTE=Lowe's48;14506040]
Got it.
I'm happy with where I'm at . All I know is the car was way off balance with the components I have installed and now it balanced both on scale and how it handle on the track.If you're running a 3s set up you should have it very close.
Old 04-26-2016, 07:39 AM   #3492
Trader Rating: 44 (100%+)
I've been working on my Tekno for a little over a year trying to get it as good or better than my previous truck(scte). It has been a challenge to say the least but i do love the challenge and i do love this truck.
I've always feel that the truck lacking on a right turn layout and have spend a lot of time chasing setups,tires,springs etc. Finally ....as i scale the truck and to my surprise the truck isn't balance from left to right.(heavier on right side) Battery mod only move the weight slightly back but not side to side. I knew what i have to do but dragging my feet knowing the the esc wires are too short to relocate to the left rear of the truck. But one night after taking a podium on a Saturday night race in most of the time but never the 1st place, i came home and get busy on the job in hand.
Anyway,the Hobbywing fit perfectly on the left rear and since i was in a cutting mode i also eliminated the radio box to loose 26 more grams .
I thought i would share this with you guys because i know i'm tired of chasing those Losi guys lol
and happy to say i podium in 1st this wkd with only a few laps on this new change.
A short video of on track practice(white/yellow car)on a very high traction indoor track.
Very nice! I'm reconfiguring my electronics layout the same as yours to test it out except I'm leaving the receiver in the stock location.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is online now   Reply With Quote
Old 04-26-2016, 02:15 PM   #3493
Lowe's48's Avatar
Good luck bud.
I don't run my cars outdoor so the receiver box isn't necessary for me.
Old 04-27-2016, 04:24 PM   #3494
Has anyone tried VRP game changer Pistons yet ?
Scottysspeedsho is offline   Reply With Quote
Old 04-27-2016, 04:53 PM   #3495
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I talked to the owner of VRP and he said there is design work going on with the game changers for the Tekno. He's apparently working directly with Ryan Lutz on coming up with a package. I'm going to give them a shot as soon as I hear that they have found something that works well.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Cain
