    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 04-24-2016, 07:31 AM   #3466
DirkW's Avatar
If you are really sure that everything is centered and zeroed, and that much difference occurs even with no steering links actually connected, than something appears to be damaged, maybe the servo?
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 04-24-2016, 07:38 AM   #3467
Josh L's Avatar
Seems like a bad servo from what your saying and what I'm seeing from your pic.
If you have another transmitter and Rx, I would plug that servo into the other one and retest. That will determine if it's something else for sure.
Josh L is offline   Reply With Quote
Old 04-24-2016, 07:40 AM   #3468
I'll have to buy another servo and try it. This is all I have at the moment. Thanks for all your help guys.
weedsnager is offline   Reply With Quote
Old 04-24-2016, 08:19 AM   #3469
Originally Posted by weedsnager View Post
Here is a picture of my servo, I marked how far the servo with turn in each direction. It turns a lot farther in one direction then the other.
What is your trim setting for your steering in the radio? That whole range looks limited to me.
qstorm777 is offline   Reply With Quote
Old 04-24-2016, 08:24 AM   #3470
I have the steering travel set to 125 %
Old 04-24-2016, 10:14 AM   #3471
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
As a quick test, plug the servo into the throttle channel and test the travel. If it's still limited then it's most likely a bad servo. If it's fine then it's the radio. It's unlikely the radio has limited travel on both channels.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 04-24-2016, 12:35 PM   #3472
Jordan Anderson's Avatar
Does your radio have sub-trim in addition to trim? Check that both sub-trim and trim are set to 0 when installing the servo horn.
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-24-2016, 05:08 PM   #3473
Lowe's48's Avatar
I've been working on my Tekno for a little over a year trying to get it as good or better than my previous truck(scte). It has been a challenge to say the least but i do love the challenge and i do love this truck.
I've always feel that the truck lacking on a right turn layout and have spend a lot of time chasing setups,tires,springs etc. Finally ....as i scale the truck and to my surprise the truck isn't balance from left to right.(heavier on right side) Battery mod only move the weight slightly back but not side to side. I knew what i have to do but dragging my feet knowing the the esc wires are too short to relocate to the left rear of the truck. But one night after taking a podium on a Saturday night race in most of the time but never the 1st place, i came home and get busy on the job in hand.
Anyway,the Hobbywing fit perfectly on the left rear and since i was in a cutting mode i also eliminated the radio box to loose 26 more grams .
I thought i would share this with you guys because i know i'm tired of chasing those Losi guys lol
and happy to say i podium in 1st this wkd with only a few laps on this new change.
A short video of on track practice(white/yellow car)on a very high traction indoor track.
https://www.youtube.com/watch?v=E3TGTug73lE
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 04-24-2016, 08:09 PM   #3474
What was the left to right difference before your mod?
Battery weight ?
SerpJimmy is offline   Reply With Quote
Old 04-24-2016, 10:04 PM   #3475
Lowe's48's Avatar
Battery weight ?
It was around 60% right and 40% left. My battery is 331 grams.After the mod the weight bias is now almost 50/50 front to rear and left to right.
Old 04-25-2016, 05:16 AM   #3476
So i'm now wondering what Weight battery tekno used to balance ?
Also, To eliminate some inconsistency, did you also balance without shocks & Wheels attached ?
Was Car coming in contact with scale in exact same location on all scales?
Switch scales around?
I noticed you removed the mud guards from earlier photo . Reason for that ?
Old 04-25-2016, 08:57 AM   #3477
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Default Weight balance
Tekno RC created this layout for a 1/8 scale buggy with 4 cells at the left side. So that´s nearly double the weight of our batteries with 2 cells.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 04-25-2016, 09:00 AM   #3478
FAO
FAO's Avatar
Thumbs up ESC mod
You are on the right way, see what i did. Nice to see, that this ESC fits, too.
The former seastar:
Old 04-25-2016, 09:11 AM   #3479
FAO
FAO's Avatar
Had the first race this year on carpet.
The car was outstandig, it seems to suck to the ground. Reduced ride hight and used stiffer oils in the shocks, maybe around 450, green front and grey springs in the back. Pistons: MIP. Jumping is still difficult, had to stay on the throttle in the air, but with some more practice it is perfekt to control the landing on the back face of the jumps. I just should get a much more faster left finger...
This is my 2. jear with the truck, the track was very "jumpy" and i became 5. of 7 starters with much more experince.
The former seastar:
Old 04-25-2016, 09:59 AM   #3480
But the buggy motors are heavier as well
Snorkel54 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
