    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 04-06-2016, 11:39 PM   #3361
Originally Posted by weedsnager View Post
With the Hobbywing 4000, running on 2s...7200, with the 16t, outdoors, is there anything I need to tweak with the esc program card or just run it as is out of the box ?
I have the HW4000 and HW xerun sct pro, running 18T . The only thing I changed was the low voltage cut-off value. I changed it to the highest value
Snorkel54 is offline   Reply With Quote
Old 04-07-2016, 03:09 AM   #3362
Dan.J's Avatar
Trader Rating: 21 (100%+)
Unless your outdoor track is SUPER tiny I would gear the 4000 at 18T, doesn't really need any timing added and as far a specific settings in the ESC goes it really depends on what ESC you are running?
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 04-07-2016, 04:56 AM   #3363
Trader Rating: 19 (100%+)
sounds like I should bump my gearing up to 18t also
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-07-2016, 05:28 AM   #3364
Hobbywing Xerun SCT Pro
weedsnager is offline   Reply With Quote
Old 04-07-2016, 07:34 AM   #3365
Originally Posted by Slotmachine View Post
How long is your track laptime wise? I run on a 100ft straight track with 18sec laptimes with a 17 pinion with no heat problems in a 6 minute race. My boost is 8 and timing is 7.
About 23 seconds. Long straight but a bunch of tight turns
HPI Trophy Truggy, Tekno 410.3 sct, TLR 8ight e 3.0, Associated B5M, Tlr 8ight 4.0, tlr 8ight e 4.0, tlr scte 2.0, associated rc8t3e
mikey91martin is offline   Reply With Quote
Old 04-07-2016, 03:28 PM   #3366
Dan.J's Avatar
I don't run that ESC but I would start with 18T on the 4000, Zero timing in the ESC and punch setting in the 5-7 range and then what ever brake % you need. Going to have to play with your punch and brake% to find what you need/like.
Old 04-07-2016, 03:58 PM   #3367
Is it true the Hobbywing xerun sct pro can't handle a Hv servo ? I ordered the savox 1268 servo
http://www.amainhobbies.com/rc-cars-...1268sg/p183318
Old 04-07-2016, 04:25 PM   #3368
bashslash1971's Avatar
Trader Rating: 18 (100%+)
Default Hey
Ok Im sure this is back some pages who knows where , but Im thinking of swapping out to 17mm wheels what are some of the Pros and Cons ????
All the rest before dont count now !! It is TEKNO 410.3 !!!!
bashslash1971 is offline   Reply With Quote
Old 04-07-2016, 05:14 PM   #3369
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
About the only con I can think of is there are limited manufacturers making the wheels.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-07-2016, 05:19 PM   #3370
mkl
I would agree, only con is limited choices of wheels. But the DE Racing Borrego wheels are quite nice.
I have only had once chance to race since I got my MIP 17mm conversion but I really liked the solid connection. I did break two axles but they were the original style from the SCT410 and 2-3 years old. So I am not sure what broke them, age, or the conversion. I should be able to race next weekend to get another race on them.
If I break another axle I am going to use the 48SL axles and Traxxas 17mm hex. I see no reason to stay with 12mm hex.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is online now   Reply With Quote
Old 04-07-2016, 05:48 PM   #3371
Moderator
bds81175's Avatar
What MIP conversion are you talking about? Or did you mean to type "M2C"?
Tekno RC
Old 04-07-2016, 06:04 PM   #3372
Trader Rating: 44 (100%+)
No I run the exact servo with the sct pro and 4000kv combo with no timing and full punch. No issues here. Runs fine.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 04-07-2016, 06:46 PM   #3373
mkl
Yes, I did, thanks for the correction.
Old 04-07-2016, 07:55 PM   #3374
Josh L's Avatar
You should start the 4700 with no more than a punch of 3 and timing set at 0. You can play with it from there, but not much. The largest thing you can do is add a cap pack to keep things cooler.
Cap Pack
Also if your going to run a fan, you should look no farther than the WTF fans.>
wild turbo fan
Josh L is offline   Reply With Quote
Old 04-08-2016, 05:58 PM   #3375
I just got the aluminum shock caps and wanted to try the standard bladder method. When the cap was screwed all the way down I noticed oil was still leaking from the vent hole. My worry is that air is going to get in when I run it.
Anyone else have this issue?
AE
TeamOSG is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
