    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree69Likes
Old 03-31-2016, 05:23 AM   #3331
Originally Posted by SerpJimmy View Post
Pretty much what I did. Just no lock tite. Don't like using lock tite between steel& alum. Got a luv hate relationship with that stuff.. Build is still going on & on & on ..
I use the buku purple loctite on those small grub screws. Still holds them in, but lets u loosen them with less risk of stripping the head.
qstorm777 is offline   Reply With Quote
Old 04-01-2016, 01:03 PM   #3332
More ? On build .. I'm coming up with a lot of tolerance between a,b,c & d block and all 4 a arms . How much is standard ?Also are there tekno shims that are machined for hinge pin ?
SerpJimmy is offline   Reply With Quote
Old 04-04-2016, 10:18 AM   #3333
I've decided to build one of these kits. It will be my first build, I'm looking at tower hobbies and what they suggest, I need a servo suggestion and anything else I might need. Here's what I have so far
Tekin Pro4 Heavy-Duty Brushless 2S 4300kV Motor-$136
Tekin 1/8 RX8 Gen2 Brushless Sensored/Sensorless ESC-$189
Any other motors or Esc's that might be cheaper ?
weedsnager is offline   Reply With Quote
Old 04-04-2016, 10:26 AM   #3334
Trader Rating: 18 (100%+)
the hobbywin sct pro esc and the hobbywing xeron 3656 4000kv is an excellent option
http://www.amainhobbies.com/rc-cars-...040201/p279179
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-04-2016, 10:31 AM   #3335
ryan432greening's Avatar
I love my Savox 2274 servo in that kit.
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 04-04-2016, 10:32 AM   #3336
Grab the Tekno aluminum servo horn as well.
B-Main Racing
GFRP M1
Old 04-04-2016, 10:32 AM   #3337
And if you do go with the Hobbywing ESC, be sure to get their programmer box so you can jack er up a bit
B-Main Racing
GFRP M1
Old 04-04-2016, 10:41 AM   #3338
Any other servo options ? Or anything else I need ?
Old 04-04-2016, 10:48 AM   #3339
Just don't cheap out on the servo. It's a heavy kit.
B-Main Racing
GFRP M1
Old 04-04-2016, 10:52 AM   #3340
Trader Rating: 42 (100%+)
+1 on HW SCT Pro and 4000 KV.
The Savox 2274 is awesome and fast too.
I'm currently using a Savox 1268SG and its plenty for me.
I recommend running a Glitch Buster Capacitor in your empty receiver slot as well!
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 04-04-2016, 11:36 AM   #3341
the weakness of sct pro is the bec. therefore, you need to use an external bec to benefit more from servo like sg2274 which will increase the cost. if you wanna go for cheaper option compared to pro4hd rx8 combo. buy the rx8 from tower with 40 dollars discount coupon from 170 dollars and buy an hw 4000kv motor or smc 4500kv motor.
murat61 is offline   Reply With Quote
Old 04-04-2016, 02:52 PM   #3342
I've been running the savox 1256th for almost two years and its been flawless. As for electronics...I'm not sold on hobbyking stuff yet. I have it in my eb48.3 and so far it's been ok. Not many runs on it yet though. On the other hand my tekin stuff has been ran hard with no issues.
4s losi is offline   Reply With Quote
Old 04-04-2016, 03:25 PM   #3343
Thanks for all your help so far. I ordered the kit along with the
Hobbywing SCT ESC/Motor Combo.... Is there a limit to battery size with this motor/esc ? Pinion gear suggestions ?
Old 04-04-2016, 03:30 PM   #3344
I run a 2s 7200mah and 16t pinion
Old 04-04-2016, 05:59 PM   #3345
Dan.J's Avatar
Trader Rating: 21 (100%+)
As said above 7000mah+, I usually run 18T with Hobbywing 4000.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
