    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 03-24-2016, 07:07 AM   #3316
Pistons taper up is what everyone's running for bumpy conditions? Asking cause on Lutz video he says for the most part face'em down . But then there's a pop up that says face up . Idk ..
SerpJimmy is offline   Reply With Quote
Old 03-24-2016, 10:02 AM   #3317
I'm sure this has been discussed but I don't want to read 222 pages.. Are people having problems with the plastic diff cross pins? I see they sell a lot of different options for these. I have had no problems just curious if it's a future issue. One other question. I'm currently running a Tacon 4800kv motor that is great except for the stiff wires that come out of it.. I have a Reedy 410r Black box on order. I've ran the Tekin Pro4 HD 4300kv is the regular Tekin Pro4 4600kv powerful enough for a Truck of this weight.. Is there a big difference in power?
tommyii77 is offline   Reply With Quote
Old 03-24-2016, 01:18 PM   #3318
Trader Rating: 32 (100%+)
Yes i have a problem with plastic crosspin also my buddy better to upgrade aluminum crosspin. The 4800kv thats a lot of power to your truck.
raved007 is offline   Reply With Quote
Old 03-24-2016, 02:30 PM   #3319
Thanks.. I'll get those cross pins ordered.. Yeah that motor screams.. It's only $50 too..
Old 03-24-2016, 07:51 PM   #3320
roger206's Avatar
Mikey Martin the pro flat track racer?
roger206 is offline   Reply With Quote
Old 03-25-2016, 05:25 AM   #3321
Haha yep
HPI Trophy Truggy, Tekno 410.3 sct, TLR 8ight e 3.0, Associated B5M, Tlr 8ight 4.0, tlr 8ight e 4.0, tlr scte 2.0, associated rc8t3e
mikey91martin is offline   Reply With Quote
Old 03-27-2016, 08:29 PM   #3322
Which type wheel hubs are the ones that are week? I did some research and it looked like the oem that were plastic were a week /breaking or stripping out . But In my new kit there aluminum . At this point im not sure If they need upgrading ? And if so to what part #?
Old 03-27-2016, 09:12 PM   #3323
Originally Posted by celt View Post
Has anyone tried this package:
Front
oil: 800 (65wt)
piston: 4x1.8 taper up
spring: Tekno pink
rebound: min.
vented
Rear
oil: 500 (40wt)
spring: Tekno pink
rebound: min.
vented
http://www.teknorc.com/tekno5/wp-con...Lewis_SDRC.pdf
Just looks odd on paper.
I've tried 4x1.8 taper up 500f/450r pink front/green rear on outdoor type track (Rocck racing knoxville) and it was too soft oil wise. Rear would donkey kick. I probably should have tried taper down. I usually run 6x1.5 pistons with 400f/350r at this track, but wanted to try something diff. Keep in mind the high temp was maybe upper 50s.
The setup u are looking at seems to be for indoor clay track. They tend have more grip, be smoother and have smaller jumps. If thats is the case, you want harder shocks.
qstorm777 is offline   Reply With Quote
Old 03-30-2016, 07:00 AM   #3324
Trader Rating: 42 (100%+)
Apparently some folks had the .3 wheel hexes break- seems like it was from over tightening the hexes and cause the aluminum to crack.
As long as you use some blue thread lock on the grubsrews and snug them down but not overly tight you won't have an issue.
Mine have been perfect thus far.
No upgrade needed.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 03-30-2016, 07:22 AM   #3325
Pretty much what I did. Just no lock tite. Don't like using lock tite between steel& alum. Got a luv hate relationship with that stuff.. Build is still going on & on & on ..
Old 03-30-2016, 07:35 AM   #3326
Default Loc tite alternative
I use this stuff on every metal to metal thread on every Rc car I own, it even keeps screws in gas buggys. Best stuff ever made. Basically turns every connection into a nylock situation. In the rare occasion something does come loose, they do not just vibrate out.
https://www.vibra-tite.com/products/threadlockers/vibra-tite-vc-3-threadmate/?gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzTd56Cn T6GCcM-7zKWoYJKPZQH-2vy0A-W3QKwbOgh0aAggQ8P8HAQ
Danger Dietrich is offline   Reply With Quote
Old 03-30-2016, 02:37 PM   #3327
Just a report regarding my problem getting zero rebound and uneven rebound. I got alu and delrin parts for my shocks, seems like it did the trick! Now I'm able to build my shocks perfectly
Snorkel54 is offline   Reply With Quote
Old 03-30-2016, 05:33 PM   #3328
lowspark's Avatar
7 months and a half dozen set-up changes later and my Tekno is hooked up !!!
Thanks to all of the suggestions, set-up tips, and other items noted in the previous 200+ pages!!!
New track layout at our local track, fast and low profile (26 second laps) vs our previous track layouts that had big jumps and technical sections (33 second laps) and my current set up just rocked... I'm not the fast guy at the track, but taking a second place against my buds made my night last Friday!!!
Keep Trying New Things... Sometimes Go Back to Old Things... you will find what works for you.
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen2 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 03-30-2016, 05:42 PM   #3329
What is your set up
Old 03-30-2016, 09:07 PM   #3330
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Originally Posted by mikey91martin View Post
What is your set up
Ya! WHats his setup!
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
