    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 03-13-2016, 06:46 AM   #3226
celt's Avatar
Default carpet racing?
Anyone seeing any indoor carpet racing with these heavier SC's?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 03-13-2016, 08:17 AM   #3227
Originally Posted by Cuebulon View Post
What buggy body do you use ken?
Used both the OEM and JC Concepts Finnisher.
Prefer the JC body because it is taller and should cool better.
2x SCT410.3 one for each son
KenPosney is offline   Reply With Quote
Old 03-13-2016, 08:33 AM   #3228
Trader Rating: 44 (100%+)
Originally Posted by fidelity101 View Post
Thank you. Do you have a link to the specific type you're talking about. I purchased these a while ago and still have a few left, but I'll have to buy more if I'm going to redo all of my batteries for the SCT.
http://www.motionrc.com/ec5-connectors-pair/
appear to be the same as these
http://www.hobbyking.com/hobbyking/s...e_Female_.html
These seem to be the best option:
http://www.ebay.com/itm/5-Pair-EC5-B...QAAOSwmUdUXHh9
Last batch of hobbyking ones I tried were garbage. None of the pins would press into the connectors even with a hammer.
Invest in the original ones. They are worth it.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 03-13-2016, 11:43 AM   #3229
King DORK's Avatar
Trader Rating: 31 (100%+)
Originally Posted by justpoet View Post
As for connectors, we pull silly amps through these things because of the 2s limit, which creates heat much faster. I would avoid the XT60s for this application. While great connectors, the XT90s or EC5s are a much better fit.
Many higher end pro drivers also still use Traxxas connectors, because they hold up well and handle the loads pretty well too.
I switched from Deans to Traxxas plugs years ago and have been very happy with them. Used them in my first gen SCT410 as well. Went to the bullets soldered on the esc wires for my 10th scale 2wd stuff but staying with plugs for my sc. Ended up going with the XT90 plugs, so nice to see your endorsement of them.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 03-13-2016, 12:54 PM   #3230
My Tekin RS8 Gen 2 (that's now dead) came installed on the vehicle already as I purchased it from someone on this forum. I was told the ESC was in like new condition and the top looked perfect upon arrival so I never bothered to look any closer. In fact, the entire Tekno SCT410.3 looked like it was almost fresh out of the box so I was very excited about the deal.
But now it looks like I'm screwed. There is no way Tekin is going to look at this ESC and say it's new. The case has been opened and then CA'd back together. The 4 screws on the bottom have been stripped and pressed together. I'm guessing it's going to be $120ish to repair???
Official Tekno RC SCT410.3 Thread-img_1630.jpg   Official Tekno RC SCT410.3 Thread-img_1631.jpg
fidelity101 is offline   Reply With Quote
Old 03-13-2016, 01:14 PM   #3231
King DORK's Avatar
fidelity, that esc definitely was abused by someone. By no means "like new condition" and the seller should compensate you for feeding you a line of crap. That's a shame and I wish you luck fixing your situation.
Old 03-13-2016, 01:19 PM   #3232
Thank you for the information and kind words. I always try to give people the benefit of the doubt so I hope he returns my text messages in the next day or two. I bought it from him in January 2016. Either way, I'm optimistic that Tekin will get me up and running again and I really hope it's going to be under the $100 mark. It's going out USPS Priority mail tomorrow so I'll report back on what they're able to do for me.
Old 03-13-2016, 01:34 PM   #3233
King DORK's Avatar
Keep us posted bud. An honest seller will by no means avoid contact from a buyer so good luck. I had a RX8 in my old Tekno but switched to a Viper VTX8 to take advantage of their program box and it's an awesome esc. Now that Viper is no more as a company I have to consider other options for my Tekno in the event that my VTX8 dies. Must say the new Hobbywing looks great with an amazing bec
Old 03-13-2016, 04:22 PM   #3234
Thanks guys. I think I'm going to go with 5mm Gold Plated bullets and cut them to length so I can't accidentally short them out. Thanks for the thought shanondink. It works well on my TLR 22SCT 2.0 but the leads are extremely short. For some reason, I didn't even think about doing that with my Tekno SCT410.
I'll have to work on it when the RX8 comes back from repair. Hopefully it doesn't cost more than $100 to repair the internal BEC.
I blew one rx8 gen2 and it cost me about 130 shipped for a new one thru tekin. Seems like the cost was on the return form.
qstorm777 is offline   Reply With Quote
Old 03-13-2016, 05:21 PM   #3235
The shipping costs are there as well as "Minimum Repair Cost" and replacement costs. But since I have no idea whats wrong, the case is cracked and CA'd together and the screws are fubard...I'm not optimistic. Hopefully it's just the cost of a new case and a replacement BEC as the ESC portion still works.
Old 03-13-2016, 05:59 PM   #3236
Josh L's Avatar
Just bypass the BEC all together with an external unit, like a castle adjustable 10amp BEC.
Then you don't need to run anything but the signal wire from the ESC's BEC.
Those RX8's are notorious for burning out on 2S systems. Once again I believe this is because of the lack of enough caps on the input side.
I don't mean to brand bash in saying this, but I would not even consider running Tekin stuff till they get their stuff working like it should.
For the money, I cannot believe the junk they ship out.
I was heckled for buying hobbywing stuff back when I first got into the SCT racing scene, and honestly they are by far a superior set than the Tekin stuff.
I run cooler by a good bit and never have problems, while I watch those $200 ESC and expensive motors go up in smoke on a regular basis, yet people keep on buying it...
I am all about an American company, but I can't support over priced equipment that only has a good warranty going for it, when I can get a set for half the price that performs just as well and never actually needs any customer service. Just my two cents.
Josh L is offline   Reply With Quote
Old 03-13-2016, 06:05 PM   #3237
Cuebulon's Avatar
8th scale correct?
Cuebulon is offline   Reply With Quote
Old 03-13-2016, 06:58 PM   #3238
Interesting...I've been running tekin rx8 gen 1 and 2 on 2s and 4s with zero issues. The gen2 is over 2 years old now.
4s losi is offline   Reply With Quote
Old 03-14-2016, 12:37 AM   #3239
justpoet's Avatar
Trader Rating: 16 (100%+)
Same. My wife and I each run them in our SCT410's and I also run it in my eBuggy Lite, all 3 on 2s. I also run 4s in our full eBuggies and my eTruggy on it without issue. I've tried the other brands and I keep switching back to Tekin so far.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 03-14-2016, 02:22 AM   #3240
gticlay's Avatar
Hey - went to put my Spektrum S6290 in my 410.3 and it won't slide into the servo box. Are you guys just cutting the box off the back side to make 1/8th scale servos fit or
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
mkl
