    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree69Likes
Old 04-14-2015, 07:42 AM   #301
rjohn929's Avatar
I ordered a set of these to try out.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Looks like they are in stock in the west coast warehouse.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 04-14-2015, 07:53 AM   #302
wreckya's Avatar
Originally Posted by Nemaris View Post
I have finished the build, you can expect all the same great things Tekno is known for! The kit went together great, and the parts quality is superb. I am planning on running it with the bone stock setup tomorrow on a tight high traction clay track! I will report my findings.
I have put all the pictures with remarks on building the shocks in a story format on photobucket in the name of not photo bombing the whole page! Click the link, and scroll to the right. If you have any questions on how the build went, ask away!
http://s1366.photobucket.com/user/ne...20Shocks/story
Thanks to Tekno for a great kit, and true passion for the racing scene.
What pistons and springs came w the kit? Thanks.
wreckya is offline   Reply With Quote
Old 04-14-2015, 08:14 AM   #303
Trader Rating: 18 (100%+)
green front, black rear
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-14-2015, 09:24 AM   #304
FastPete's Avatar
Trader Rating: 44 (100%+)
And black pistons.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 04-14-2015, 10:02 AM   #305
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Originally Posted by ba4ma View Post
Nemaris,what weight diff and shock oils are Tekno calling for in the stock setup?
7000/7000/5000
Link to instruktion manual is at the bottom of the car΄s page, highlighted in blue
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 04-14-2015, 10:17 AM   #306
Originally Posted by Jakesterama View Post
"Order Now Being Picked and Packed in Warehouse" Wooooo Hoooooo!
Tower has been showing mine that way for about 4 days now
Sponsored by Tekno
Tekno SCT410.3 - Hobbywing 4000k, RX8Gen2, Savox 1258, Vant Batterys
Tekno EB48.3 - Hobbywing 1800k, RX8Gen2, Savox 2274SG-TE, ProMatch Batterys
B5M - Tekin Gen 2 8.5/Express Motorsports 17.5, RS Gen2, Savox 1257, ProMatch Batterys
s14det is offline   Reply With Quote
Old 04-14-2015, 11:12 AM   #307
Mikeand22's Avatar
Trader Rating: 23 (100%+)
Better than mine, mine has moved from early April to mid april and now it says late April.
Mikeand22 is offline   Reply With Quote
Old 04-14-2015, 11:28 AM   #308
me too
Old 04-14-2015, 11:59 AM   #309
Orion_2kTC's Avatar
Same...and I have a summer series race on May 2nd I don't want to miss.
Orion_2kTC is offline   Reply With Quote
Old 04-14-2015, 12:19 PM   #310
Trader Rating: 16 (100%+)
stormer has a few in stock
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 04-14-2015, 12:27 PM   #311
Orion_2kTC's Avatar
They don't take Paypal credit which is the only way I can pay.
Old 04-14-2015, 12:39 PM   #312
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
honestly not sure how the status goes with Tower, as I think it may be that what we see is actually the status for the vehicle overall, not just for us who preordered.
Just guessing here but wouldn't be surprised if that is the case.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 04-14-2015, 12:42 PM   #313
Orion_2kTC's Avatar
Well I ordered on April 6th and asked for a status update today. When I get an answer I'll post it here. Probably going to be a generic "it gets here when it gets here" response but you never know. I guess I can glue my tires and wire my ESC in the mean time...
Old 04-14-2015, 12:45 PM   #314
Tech Legend
Cain's Avatar
heck, back with the first Tekno SCT410 people were getting there orders filled who ordered after me, like a week after lol.
You don't order from tower to get it shipped fast, you order for the price savings.
My order date is March 29th, previous was March 19th but got a better coupon so went with that.
So if you get it before me, will be like before
Old 04-14-2015, 12:50 PM   #315
Orion_2kTC's Avatar
Had I known this would have been a problem I would have ordered from Fierce Solutions when they had some in stock.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
