    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 02-16-2016, 06:01 AM   #3016
Trader Rating: 18 (100%+)
Originally Posted by nmdesertracer View Post
Are the NB48.3 shock towers beefier but the same as 410.3? I know on my sct410 the nb48 shock towers were a direct drop in.
the .3 buggies use the truggy size shocks now, so they probably aren't compatible.
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 02-16-2016, 08:14 AM   #3017
Unfortunately, the buggy shock towers changes the truck geometry vs the 410.3 shock towers.
qstorm777 is offline   Reply With Quote
Old 02-18-2016, 03:59 PM   #3018
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
thanks guys
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 02-21-2016, 02:47 PM   #3019
I'm having an issue with my servo horn and linkage.
I have the single hole 25T Tekno Horn, if I gap my servo linkage to 1mm like instructions say, I cannot get the linkage to be parallel like the manual says to? Page 22 of the manual. I end up having to gap it like 3mm, is this ok?
Also I had to remove the 2 washers above the ball end so my wheels would clear, do I need to remove any other washers to compensate for this?
Also, how are you guys running your antennas, I notice a lot of short tubes, where can I find one? The one that comes in the kit sucks.
I've also read were some people just wrap them and keep them inside the receiver box?
Thank you
Malazan is offline   Reply With Quote
Old 02-21-2016, 05:23 PM   #3020
I've also read were some people just wrap them and keep them inside the antenna box?
Thank you
I wouldn't worry about the servo horn linkage. Just do what you need to do to make it work.
450rdawg is offline   Reply With Quote
Old 02-21-2016, 05:26 PM   #3021
Thank you
Oh, and as for the antenna, I don't run one. Not really a need for it with today's 2.4 technology.
Old 02-21-2016, 07:15 PM   #3022
Dan.J's Avatar
Trader Rating: 21 (100%+)
Thank you
I run antennaless receivers so I don't use them but what do you mean about "The one that comes is the kit sucks" ? Cause its long? Just cut it to the length you need. And yes you can wrap most of them and still be ok for most situations if you decide to go that route.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 02-21-2016, 07:18 PM   #3023
It doesn't fit tight in its mounting hole, it's like the hole is a little too big for the antenna tube. I was going to cut it to about 3-4"
Who makes a antenna less receiver?
That is good to know that it can just be wrapped
Old 02-21-2016, 07:30 PM   #3024
This had me too, see how there is 2 holes where the antenna tube goes? 1 is for the tube and the other is for the little grub screw that hopefully you didn't throw away. It tightens the tube right up and it won't go anywhere.
Oh and I just rap the antenna up in the receiver box now with no side effects on coverage.
mikeinsocal is offline   Reply With Quote
Old 02-21-2016, 07:34 PM   #3025
Thank you
I was trying to transfer a picture of my steering link, but I'm having problems. Anyway, I would say as long as the line drawn between the screws on the servo horn are pretty close to parallel to the line drawn between the screws on the servo saver, u r good to go. I just do that visually...i don't actually measure.
I use a button head screw on my steering linkage at the wheels. You get a little more clearance that way. Removing washers won't hurt. It's just there for storage until u need it to change bump steering.
I run a shorter antenna. I cut the antenna tubing to the length I want. Only the very end of my antenna is in the tube. The rest is rolled up in the box.
Old 02-21-2016, 08:07 PM   #3026
Right on, thanks, I am using button head screws but I still needed to remove the upper washers. Rolling the antenna up in the box sounds like the way to go
Old 02-21-2016, 08:08 PM   #3027
LOL, I don't know if I can find that screw
The manual doesn't say anyrthing about that screw or antenna mounting,
But the NB48.3 shows what you are talking about. I might have a extra set screw.
Old 02-22-2016, 02:56 AM   #3028
Dan.J's Avatar
Futaba makes antennaless, not sure about the other makers.
Old 02-22-2016, 04:03 AM   #3029
celt's Avatar
As does Airtronics...
http://www.amainhobbies.com/rc-cars-...r92081/p450391
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 02-22-2016, 09:26 AM   #3030
King DORK's Avatar
Trader Rating: 31 (100%+)
I cut the antenna tube the length that the antenna stick out of the box then use a heat gun and put a 90 degree bend in it so it's well under the body.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
