    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 02-06-2016, 05:29 PM   #2956
[QtUOTE=King DORK;14379554]Lol. I had a Copperhead system (louder than most) in an Axial EXO buggy which has a very loud drivetrain. Thing was hilarious running down the street. Sounded similar to a kid putting playing cards in the spokes of his bike rims. Motor was actually very ballsy and plenty fast in the EXO, which was a heavy pig.[/QUOTE]
mastark is offline   Reply With Quote
Old 02-07-2016, 05:20 AM   #2957
celt's Avatar
Default center drive shaft
Anyone aware of the physical differences between these two drive shafts? Clearly one is for the lighter SC and light buggy and the others for the 4S powered chassis. Wondering if it's just weight and durability.
TKR5579
Tekno RC EB48SL
Tekno RC SCT410
Tekno RC SCT410.3
http://www.amainhobbies.com/rc-cars-...kr5579/p417088
TKR5191
Tekno RC EB48
Tekno RC EB48.2
Tekno RC EB48.3
Tekno RC ET48
Tekno RC ET48.3
http://www.amainhobbies.com/rc-cars-...kr5191/p417089
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 02-07-2016, 06:29 AM   #2958
The buggy/truggy models have bigger pins that wouldn't fit into the truck input/output shafts. I tried it by mistake.
shanondink is offline   Reply With Quote
Old 02-07-2016, 01:36 PM   #2959
Dan.J's Avatar
Trader Rating: 21 (100%+)
TKR5579
Tekno RC EB48SL
Tekno RC SCT410
Tekno RC SCT410.3
TKR5191
Tekno RC EB48
Tekno RC EB48.2
Tekno RC EB48.3
Tekno RC ET48
Tekno RC ET48.3
SCT410/410.3 and EB48SL all share the same driveline with the same size outdrives, The EB48/48.2/48.3/ET48 and ET48.3 all share the larger outdrives so larger pins as said above.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 02-08-2016, 07:18 AM   #2960
Midway through the build at the servo install part. I'm using an Airtronics 94915 servo and it will not fit in the plastic sleeve provided. I've been trying to file down the walls of the stock opening provided in TKR5511 Radio Tray / Mud Guard however its taking forever..
Is there a quick way to make the 94915 Servo fit? This is not any bigger than the full size servo's I've used in the past but it is a lot bigger than some of the Savox and Hitec servos I've used. Thanks!
twistedneck is offline   Reply With Quote
Old 02-08-2016, 06:59 PM   #2961
i just dremeled the back side wall out to fit a heavy duty futaba servo in there. it doesnt need it to hold servo strong.
After replacing the cheapy A block,the car has been much more durable,I removed the center brace and bent the front alum driveshaft in a crash that cart wheeled it. to bad the above HD one wont work in the SL model
ResultsRC is offline   Reply With Quote
Old 02-09-2016, 02:54 AM   #2962
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Default The same servos by Sanwa
...so did i...
the Sanwa servo was not just 0,5mm to thick, but 1mm to high also. I had to mill out the chassis, too.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 02-09-2016, 06:46 AM   #2963
Thanks to a post on here with the Ford 60's truck body, I had to get one with a flamed hotrod paint job.
cutting42 is offline   Reply With Quote
Old 02-09-2016, 08:28 AM   #2964
Josh L's Avatar
Originally Posted by FAO View Post
...so did i...
Had to shave some on the side plate myself to get the Futaba HV-9352 to fit as well. This is going to be a part that needs revised on Tekno's future models.
You can see the swell bow still there between the servo and ESC.
That was probably my girlfriend and I! We both run those 66 Ford shells and love em! They have a definitive presence about them and just look way cool making hot laps around the tracks!
Anyhow looks good man! You'll end up owning more than one before it's over with, once you drive it a little bit you'll start to like the way it handles!
Josh L is offline   Reply With Quote
Old 02-09-2016, 10:15 AM   #2965
Trader Rating: 32 (100%+)
Talking
I love that body had in my tekno too it handle great and got a lot of flip but it marshall by itself
raved007 is offline   Reply With Quote
Old 02-09-2016, 04:49 PM   #2966
Yup it was your truck I saw. Just loved the body and can't wait to run on Sunday.
Old 02-09-2016, 05:01 PM   #2967
Anyone know of a good place to get a good quality pre painted body? I'd like a truck body as I purchased the mounts for it but honestly I'd settle for an SCT body if the price was right. I'm not looking to spent another $90 on a body I'm only going to beat up in a month or so.
fidelity101 is offline   Reply With Quote
Old 02-09-2016, 05:40 PM   #2968
Josh L's Avatar
Take some pics of it on the track! I want to see it burning with the cookie cutters!
Old 02-09-2016, 05:55 PM   #2969
King DORK's Avatar
Trader Rating: 31 (100%+)
That is friggin sweet! Now you got me wanting one.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 02-09-2016, 08:24 PM   #2970
justpoet's Avatar
Trader Rating: 16 (100%+)
Diggin' it. I might have to do this with my old classic colors at some point, though they were always 1 color jobs, so to put them together, black with blue flame.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
ezlight
