    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 01-02-2016, 11:01 AM   #2791
Lowe's48's Avatar
Originally Posted by 450rdawg View Post
A good less expensive option would be the Hobbywing SCT pro esc (about $80 on ebay) and the SMC 4500kv motor ($67 shipped on SMCs website. SMC also has good batteries at a good price. Just stick with a hard pack battery with at least 6000mah and you should be fine. Some tracks run 10 minute mains and you'll use the majority of that 6000. I have the products referred to above so this isn't a suggestion based on regurgitated stuff I've read. It's from experience. Just my $.02.
Great suggestion
I run the SMC battery and they are great. the 7200 mah is around 45 bucks !!
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 01-02-2016, 11:32 AM   #2792
Originally Posted by Lowe's48 View Post
Great suggestion
I run that 4500 in my 410.3, along with the 6500 packs and it's plenty of juice. Gets me through 10 minutes with juice to spare. Had a problem with a cracked case on a pack and Danny at SMC made it right. Great service from my experience.
450rdawg is offline   Reply With Quote
Old 01-02-2016, 01:10 PM   #2793
This 100%
mikeinsocal is offline   Reply With Quote
Old 01-02-2016, 02:51 PM   #2794
Appreciate it guys👍🏼 That's just the info/price I was looking for. I may have to move a little quicker on this. He got spanked today in his race (5th novice). Everybody that beat him had super fast 2/4wd buggies. He was the highest placed Slash. I dont want him to get discouraged. There are not enough Slashs for their own class. So it's kinda had to compete against some of these faster guys turning 2 seconds a lap quicker consistently.
JonnyW is offline   Reply With Quote
Old 01-02-2016, 05:15 PM   #2795
You are always going to get slaughtered by a buggy 2WD or 4WD on carpet, they are much faster, lighter and agile. I can beat buggies on a bumpy astro track as the SC soaks up the bumps much better but on my local Carpet track I would be at least 1 final lower than driving a buggy.
cutting42 is offline   Reply With Quote
Old 01-03-2016, 01:58 AM   #2796
Yeah that's what I have been telling him. I have been explaining COG and other physics to him. And I showed some of the other cars with the lid off. So he could see how low these things are. I told him he would be much smoother on the bigger outdoor tracks. I'm not a big fan on the indoor carpet scene anyhow. But it was a good way to get him some races under his belt. It seems like it's been raining two months here in the SE. So it's all we got until we dry out.
Old 01-03-2016, 09:39 AM   #2797
extremely good advice! SMC batteries in particular should be the only place you look.
Hungryarch is offline   Reply With Quote
Old 01-03-2016, 06:45 PM   #2798
celt's Avatar
Default Calling all Brits!
You guys have a ton of experience running the SCt410 on carpet and astro...
What do you like in tires for carpet/ozite?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 01-04-2016, 12:21 PM   #2799
Default Tekno SCT battery question
Have a question for anyone...my son runs the Tekno SCT 410 truck in our big block mod class at our local track. The heats are 5 minute qualifiers and sometimes 6 minute mains. Currently he is using the standard full size 2s packs that fit right into the tray. This past weekend we had issues with one of the packs and I need to know if I can use shorty packs in there without issues. I recently grabbed a bunch of the MaxAmps 150c packs and would love for him to be able to use them but I need to know if there is any advice on staying away from doing so.
Thanks...Scott
scraff33 is offline   Reply With Quote
Old 01-04-2016, 12:32 PM   #2800
justpoet's Avatar
Trader Rating: 16 (100%+)
As mentioned, the SMC motor is great, on a budget or not. The Hobbywing Xerun 4000 and 4700 motors are also nice, and come as a combo with the SCT Pro. One thing to be wary of is that HobbyWing only provides their warranty when purchased from in country authorized resellers. So if you buy from ebay and it comes from overseas, don't expect warranty work if something goes wrong. Most local hobby shops can order the HW stuff as well even if they don't stock it, or you can get it direct from falconsekido.com which is the official HobbyWing North America direct distributor.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 01-04-2016, 09:22 PM   #2801
I have been getting much faster with this .3 model. its really very capable sc,the positives being all metal parts have very good long term wear.I just think its really cheesy to not include metal king pin holders,shock caps,diff pins,carbon towers. these plastic king pin holders are a egg shell joke,the A block snaps everytime a front wheel touches the pipe at all. Its actually muchhhh more expensive than the losi scte after you buy what comes in the scte kit stock and should have been included in the 410.3 couple hundred bucks extra for stock parts to be durable is pathetic imho
ResultsRC is offline   Reply With Quote
Old 01-05-2016, 01:17 AM   #2802
Thanks...Scott
It could be a problem if the capacity of the battery is not enough for 5 min run. What is the capacity of the battery that fits right into the tray. You can find shorter packs that is easier to remove from tray but also handle 6 mins run (7200 mah vs 6000mah). What is the motor on sct. Some motors use more juice.
Btw, a bunch of maxamps batteries means dozens of smc batteries and you would get nothing less in terms of price and reliability.
murat61 is offline   Reply With Quote
Old 01-05-2016, 06:49 AM   #2803
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I've owned both trucks and there is no comparison in reliability if you replace the A block. I've been running the stock shock caps and towers with no issues on two trucks for months. A plastic hinge A block is kind of lame but the rest of it certainly isn't necessary to beat the tar out of a Losi and still be running the same axles and rod ends well after the Losi is on to it's third set. Not being a fan boy here....but there really is no comparison between the two trucks. Then again, I prefer the original SCT410 to the 410.3....
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-05-2016, 07:10 AM   #2804
I'm almost with you on this. First off, for Tekno to build a truck this beastly and leave that crap on the front A block in the kit is just an insult. LOL Everyone at our track is breaking them left and right...until you plop another $24 bucks down for the aluminum. Lose a hinge pin in the process....grab another $10. LOL
The kit, plus pink springs (most of us at our track are running), aluminum A block, metal diff cross pins, and some shock parts are the minimum to get this kit off the ground for race day. Next thing you know you are out a minimum of $400 even if you get a screaming deal.
That being said, it's worth every penny thus far! HA!
Tekno 410.3, Associated T4.2 team+
Chuch is offline   Reply With Quote
Old 01-05-2016, 08:45 AM   #2805
Has anyone actually had a composite diff cross pin fail yet?
Tags
sct410, sct410.3, short course, short course 4x4, tekno
