    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree69Likes
Old 10-06-2015, 12:02 AM   #2341
Josh L's Avatar
Originally Posted by ryan432greening View Post
Hi folks,
I've read through a lot of this thread and I'd like to thank everyone for their helpful tips.
I just got my 410.3 fired up last night and I noticed it seems a lot noisier than my other cars( 2 sc10 FTs) is that a byproduct of the coarser pitched gears or something else? My other trucks use 48p gears.
Also, when individually spinning my wheels on the work stand, spinning individual tires produces noticeable spin in the other three tires except when I spin the right rear individually it barely spins the other three. Thoughts?
Thanks for your time!
Give the diff some time to break in. Sometimes I have noticed this to after a fresh build, but it tend to go away once you have some time on the drive train. I guess it could be that one side is slightly tighter than the other in regard to the out-drive seals or seat. If the problem persist after about 10 packs, then you might consider tearing things down to have a better look at everything's alignment, checking for witness marks that might indicated wear. But most likely it will work it's self out.
As for the noise, this is normal for mod1 pitch gears. I remember the first time I ran my SC truck and heard it. It freaked me out to the point I was ready to tear it down and kept checking the pinion, because I just knew it was toast!
But they quiet down a bit after some running and like a person who builds a house near a train track, you will just get used to it and won't notice it at all.
Also, what does one do when the truck steers much tighter and sharper to the right than the left? What needs to be adjusted?
Assuming your servo has an alloy horn that is well centered and the EPA is dialed as close to the other as possible. Make sure your servo saver is tightened down really good.
Also, you will want to make sure all your links are dialed in length wise the same from side to side.
Also take note of where your inner wheel might hit the arm or shock at full deflection from any witness marks on the front or back of the A-arms/shocks, or by eye if you haven't put much time on the chassis yet.
Push your suspension up and down while at full deflection left and right to see if any contact is being made at any point through the action. It is logical for folks to want everything it can give you in total deflection, but with nothing else considered and that being said, doesn't always give you the best "overall" optimal results.
One side may drag against an arm/shock more or less than the other and will cause this sort of inconsistency. If the bind is extreme enough it can produce a false turn radius, as it will actually create enough drag force against the inside of a rim that it will act more or less as a wheel brake and potentially force the truck around it. This can cause false push and will drag your truck to the outside of the turn if it is binding against the front of the arm on the outside wheel through a turn, or alternately can cause over steer if it binds against the back of the arm on the inside wheel around a turn.
It will obviously depend on which side (front or back) of the arm your are getting bind against as to what it will do.
You must also realize that if one side is off in camber (more lean in) a bit from the other, one will have less clearance than the other because it will bind sooner than the other due to the mechanical angles being indifferent.
These things are easy to over look due to the fact that many folks tend to set and forget EPA after their initial build. But fact is every time you make mechanical adjustments, you will indirectly be changing where the optimal EPA setting should be for clean clearance to both side.
Now with all that stuff being considered and all the first mentioned steps addressed, if it still turns one way better, (but only slightly) then you should consider bringing the steering EPA back a hair on the side that turns the tightest, until it matches the side that has the least turn in.
I know that sounds a bit counter productive in regard to getting the most out of your turn geometry, but it is far better to have a consistent vehicle that turns equally from left to right than it is to have one that turns harder one way than it does the other.
If you don't get this dialed out equally, then you will inevitably set yourself up toward creating a bad habit of over shooting your turn angles in the direction that turns less than the other and it will kill your lap times overall and make your truck unpredictable and a hassle to maintain within any sort of chicane.
Just like the methodology of how "slow is fast", maybe even more so is consistency in handling characteristics from side to side, even if you have to shave a little off of one to help the other out.
To cap this reply out, if you are not getting the overall tuning desired, you might consider playing with your ackerman position and reducing some angle from your kickup once you have things equaled out. More ackerman produces more predictable, but less on-power steering, which will help off-power smoothness around the turns, while less akerman will give you a more aggressive traction bite for forceful on-power steering.
Reducing kick-up has a sweet effect that is like having more toe-out in the front, without the stability loss down the straights.
You will notice more responsiveness with steering, but the flip side is it will take away a bit of the bump/rut smoothing. If your track isn't totally blown out, this is a great thing to try instead of just relying on more toe out in the front.
The last resort is trying a wheel with a bit more offset if possible. Sometimes they will clear slightly more than a 0 offset will, but not always.
Josh L is offline   Reply With Quote
Old 10-06-2015, 05:47 AM   #2342
Hoese37's Avatar
Originally Posted by tfrankito View Post
Check your steering end points on the radio. You may not be getting full through from right.
When you need to center the horn on the truck, do that with sub trim, not trim.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 10-07-2015, 08:20 AM   #2343
I'm just putting my kit together and wondering what wheels everyone is using for the wheel hexes that come in the new kit. http://www.teknorc.com/shop/tkr5571m...12mm-sct410sl/
My old 410 had the old short course style hexes. I think this is a better design, but none of my old wheels work.
jb19 is offline   Reply With Quote
Old 10-07-2015, 08:25 AM   #2344
Same wheels fit, you just need to ream the center hole out on the wheel because the .3 axle is bigger. The hex is still 12mm it's just shaped different for weight savings since they are steel.
Tijuana_Taxi is offline   Reply With Quote
Old 10-07-2015, 05:40 PM   #2345
lol. Man do I feel stupid.
Old 10-07-2015, 05:47 PM   #2346
Josh L's Avatar
I can see where this would be easy to confuse. The new design shape doesn't appear to still be a hex at first glance. I'm not sold on them to be honest. I am sure they work ok for many, but I would just put the alloy clamping set on anyhow.
Old 10-07-2015, 10:46 PM   #2347
Barillms's Avatar
The DE Speedline wheels fit over the axle without reaming. But the Borregos require reaming, just a tiny bit. Just don't overtighten the stock hex. Barely snug the set screw down, you youll feel them crack. Ive cracked 4 already in 6 months.
SC 10 4x4 wheel hexs will fit also.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 10-08-2015, 09:07 AM   #2348
Trader Rating: 25 (100%+)
are the aluminum blocks really that necessary? I was thinking of upgrading my .2 to a .3. I currently run the plastic blocks now except for the rear.
LRP America
My RC Depot - myrcdepot.com
tfrankito is offline   Reply With Quote
Old 10-08-2015, 09:45 AM   #2349
edonsohc's Avatar
[QUOTE=tfrankito;14214730]are the aluminum blocks really that necessary? I was thinking of upgrading my .2 to a .3. I currently run the plastic blocks now except for the rear.[/QtheUOTE]
I would say no. I've broken 2 "a" blocks. the one was definitely gonna break. I found a steel spike holding the pipe down. it was sticking up and I landed and slid into it. the other time I don't know if it was me or a weak part. either way, the blocks are cheaper than arms and hubs.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
Old 10-08-2015, 10:18 AM   #2350
Ruffdog1's Avatar
I am running 6 X 1.5 pistons all around with black springs 32.5 wt oil front, green springs 27.5 wt oil rear on outdoor blown out bumpy track. 65 degrees Fahrenheit air temperature. Track gets watered so there is decent traction but lots of bumps and rocks. Truck feels pretty good with emulsion setup but wondering if bladder setup with more rebound or less rebound would handle the rough track better. Should I stay with emulsion? Thoughts?
Ruffdog1 is offline   Reply With Quote
Old 10-08-2015, 10:21 PM   #2351
Trader Rating: 82 (100%+)
Bladder is typically for rough/outdoor tracks since you get a faster/springy feel. I run emulsion for both indoor and outdoor on Kyosho springs (feels more linear).
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 10-09-2015, 01:33 AM   #2352
Talking
Ruffdog, try heavier weight oil. Like 100 wt front 15wt rear.Proline prime tires works good for me, got first place last night. Also I spit on my tires for traction compound ,then pray you can beat me.............
Tekno sct410 Tekno 410.3 Tekin 4300hd Tekin gen2 RX8 Losi 22SCT Futaba Tekin gen2 rs Tekin 13.5 gen2 Proline, sponsored by my wifes purse.
Snarf450r is offline   Reply With Quote
Old 10-09-2015, 07:35 AM   #2353
Ruffdog1's Avatar
HAHA. I always pray I can beat you. See you tonight.
Old 10-09-2015, 08:48 AM   #2354
I run same spring and pistons, but run 450cst/350cst, and shocks all the way out on the arms. The truck handles great IMHO, and i've been running that setup on 7 different tracks all summer, with just camber adjustments track to track.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-09-2015, 05:56 PM   #2355
Trader Rating: 36 (100%+)
For playing with the ackerman, is it just using more or less washers?
mxturd is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
