    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 04-08-2015, 06:11 PM   #211
Trader Rating: 32 (100%+)
Originally Posted by rjohn929 View Post
Got one preordered. Think I'm going to give the LRP 10L 4700 a shot and see how it hangs with the 4300HD.
I am running revtech 4800KV with TS160 the best combo that i have. I tried sct hobbywing with 4000KV, Tekin GEN2 with 4300KV, Revtech 4800KV with Orion Votex 8.1 but im not happy with the speed but Revetech 4800KV with TS160/TS120 with same pinion gear i feel like need a wheelie lol.
raved007 is offline   Reply With Quote
Old 04-08-2015, 06:13 PM   #212
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
the TS160 looks just like the G-Force ESC being sold by that new viper site
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 04-08-2015, 06:34 PM   #213
Yes G-Force and Skyrc i think they are same.
Old 04-08-2015, 06:56 PM   #214
Hoese37's Avatar
Bunch of new parts added! http://www.teknorc.com/shop/
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 04-08-2015, 06:59 PM   #215
rjohn929's Avatar
Aluminum brace A, B, C and D ordered!
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 04-08-2015, 10:43 PM   #216
dirtbikekid33's Avatar
Looks to me the new towers are stamped are they going to offer cnc milled ones, I bent my original ones pretty fast.
Tekno Eb48.2 tekin Rx8 tekin 1900 savox
Tekno SCT410 tekin Rx8 HW 4700 savox
RC10 b44.2 Tekin RS PRO tekin 6.5 savox
Rc10 b4.2 Tekin RS trinity 17.5 savox
dirtbikekid33 is offline   Reply With Quote
Old 04-08-2015, 11:26 PM   #217
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Hey guys, the new rod ends use 4mm thread, not 5mm like the previous kit. I'm going to get the correct lengths up on the first page soon along with a lot of other info, I've just been really busy lately.
As for the towers there will eventually be CNC versions available and most likely carbon fiber as well.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 04-09-2015, 07:41 AM   #218
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Still waiting for the kit to become available in Germany...
I decided to switch from SC10 4x4 because of the missing center diff to: Tekno... -.3 .
What rims do the Durango- Boys want to use (17mm SC ???)
Next week 2 races take place at exibition in Dortmund, Germany...
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 04-09-2015, 07:45 AM   #219
Tech Legend
Cain's Avatar
durango guys will be using 17mm rims. part of may be due to the compatiblity of parts between the SCT and the buggy it appears from pics.
Tekno does have that option too, though not sure if it will work on the axle threads of the bigger size from M2C. You will want to ask them if you want 17mm rims.
Old 04-09-2015, 08:04 AM   #220
FastPete's Avatar
Trader Rating: 44 (100%+)
Pete post anything about parts availability?
Whats available so far is up on our site. Will be here in 3 days. Might offer a bundle price to, for the four toe blocks.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 04-09-2015, 08:53 AM   #221
Tech Legend
Cain's Avatar
Cool, don't forget to throw in the inserts
If you can offer the same but say a front block and a rear block could be cool to upgrade to at least alloy on part of the ends.
Old 04-09-2015, 08:36 PM   #222
I sent them an email this morning asking if there were plans for beefier towers (I run the buggy towers on my V1) and they said not yet. I too bent one of my original towers early on. I was looking into purchasing the parts needed to create the new geometry, but I may wait to see if anything happens with the shock towers.
qstorm777 is offline   Reply With Quote
Old 04-09-2015, 09:59 PM   #223
Ya i would really like to see stronger towers as well. I have a few sets of the originals that are bent, no problem though once i went to the cnc towers, and yes i am a bit abusive at times, like when i just have to hit a 30 foot quad section!
mikeinsocal is offline   Reply With Quote
Old 04-10-2015, 02:41 AM   #224
FAO
FAO's Avatar
Thumbs up
Ok, i only knew rims with 17mm for Buggy 1/8, but Associated has them for their SCT 1/8.
Good news:
Preorderd my kit, ETA: end of next week!!!
The former seastar:
Old 04-10-2015, 12:07 PM   #225
RockStew's Avatar
I was on A main to order something and it said I have a shippable backorder, lo and behold it was the 410.3!! whoohoo,,,should have next Wednesday.
B5M,TEKNO SCT 410,T5M,HB D413,TEKIN,DE WHEELS,TRINITY,PROLINE,JCONCEPTS,SDRC,IERC, EclipseRC.com, AIRTRONICS,
RockStew is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
