    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 09-09-2015, 07:48 PM   #2161
Originally Posted by Hoese37 View Post
I did use them at first. They stayed plenty tight. I ended up removing the motor one time, and lost 2 of the screws, so I just ended up soldering wires direct to the motor.
Hoese, the motor temps you got with this motor, was it via a temp gun or datalog? I'm getting about a 70 degF discrepancy between the two.
qstorm777 is offline   Reply With Quote
Old 09-09-2015, 07:53 PM   #2162
Hoese37's Avatar
Mine was via temp gun on the can. Datalogging temps will be a it higher due to the sensors being inside the can.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 09-09-2015, 07:55 PM   #2163
Barillms's Avatar
Play with the shock tower location.
I run 2nd from bottom hole on towers. Inner hole on rear arm. Outer hole on front arm. Start around 35 weight oil, fine tune from there. Green rear. Black & Pink Fronts. The Jeremy McGuigan pill & link set up. Ride height around 27 front 26 rear. 106 front droop, 122 rear droop. 2 degree front camber, 3 degree rear camber. Tires have A LOT to do with traction rolling. A less aggressive tread will slide more predictable.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 09-09-2015, 08:17 PM   #2164
Default Shock Pistons
What is the performance difference in the 4x1.8 piston vs the 6x1.5 piston?
Old 09-09-2015, 08:28 PM   #2165
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I have a 410 only have 6 laps on it before my esc started to act up but I figured that problem out went back to the default program and it started to work again but I haven't gotten back to the track. My problem really was in the flying and landing the truck want to nose over what is the trick to get this truck to land level or nose up slightly?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 09-09-2015, 09:43 PM   #2166
rcgod's Avatar
Trader Rating: 27 (100%+)
What's your setup including motor and gearing?
rcgod is offline   Reply With Quote
Old 09-09-2015, 10:53 PM   #2167
That is a good question I bought it useď and I haven't had @ chance or the knowledge of the truck to kn ow what the base set up. I know I have a Tekin 4600 kv geared With a stock spur gear. I hate to be so ignorant of what I should know. I went to Petit rc and downloaded a setup for a loamy track to give myself a baseline setup. One thing i did notice the amount weight in the front of the truck battery esc and no weight in the rear of the truck.
thank you ahead of time for helping a off road neoflight.
Old 09-09-2015, 11:37 PM   #2168
rcgod's Avatar
You really should go through the truck and check everything. Either go back to the stock setup or there are some good setups on the tekno website. You may be chasing your tail if there's something mechanically wrong or it just has a funky setup. If it is still nose diving then we can go from there. A lot of guys here have experience getting rid of that so someone will be able to help. Also make sure your gearing is right. For a 4600 tekin I would run a 15 or 16 pinion nothing smaller. Gearing too low can cause nose down issues too.
Old 09-10-2015, 05:30 AM   #2169
Trader Rating: 32 (100%+)
If you have nose dive issue check Daniel Lewis set up at Tekno website. Also try less kick up in the rear.
raved007 is offline   Reply With Quote
Old 09-10-2015, 05:37 AM   #2170
Hoese37's Avatar
Most of the time its the rear shocks are too light by either oil, or springs, or both.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 09-10-2015, 08:39 AM   #2171
Trader Rating: 75 (100%+)
+1,000,000,000,000
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 09-10-2015, 05:41 PM   #2172
Dan.J's Avatar
Trader Rating: 21 (100%+)
Kit springs/oils? Going from the kit rear black springs to say pink and a touch heavier on the oil may be all you need, sometimes a slight change is all it takes. The setup that Tekno posted a couple pages back is pretty solid for a kind of "do it all" setup IMO, you may want to give that a try.
http://www.teknorc.com/tekno5/wp-con...Lewis_SDRC.pdf
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 09-10-2015, 06:48 PM   #2173
Default Ads
Off subject, but very irritating, anybody know how i keep all these ads etc. from popping up while in the forums here? I'm using my phone 99% of the time.
Old 09-10-2015, 07:14 PM   #2174
Dan.J's Avatar
I don't even bother with this site on my phone much as the redirects kicking me off the site piss me off in the worst way Very frustrating when you are trying to do something on the site from your mobile and it takes 5 attempts to do a single thing
Old 09-10-2015, 09:18 PM   #2175
Barillms's Avatar
All you have to do is go to your settings on your phone, and click "Block pop ups".
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Tags
sct410, sct410.3, short course, short course 4x4, tekno
