    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 09-07-2015, 07:04 PM   #2131
Originally Posted by PetRock View Post
What type of battery connector are you using?
4mm bullets, inboard SMC batteries. Low resistance, Not the bird cage style.
MitchCraft is offline   Reply With Quote
Old 09-07-2015, 07:28 PM   #2132
Dan.J's Avatar
Trader Rating: 21 (100%+)
Originally Posted by MitchCraft View Post
I have been having trouble with my 3656 4700 and sct pro combo in my new 410.3. Esc cuts out after a few mins, restarts and runs for 30 seconds, then cuts out again. Tried all the typical troubleshooting below, conclusion is that the esc is overloaded somehow (with help from hobbywing tech support). I suspect I could have a weak esc, maybe components out of spec. I know others have tried this combo on this truck. If it is working well, what is your setup?
Tried:
Re-calibrated radio
LVC off
Multiple different batteries of different brands (high quality, high C and capacity that work fine in other vehicle)
Updated firmware
Unplugged sensor wire
Different radio system (completely different brand)
Put radio/steering servo direct to battery
Checked all connections
14t and 16t pinion
Hard wired switch
Confirmed no binding in drivetrain
Punch set to min, no drag brake, no timing
Temps all ok, except caps on esc get hot with 16t pinion.
Side note: tech support (Angelo) has been extremely fast responding, and great support in the tech support thread here on rctech (Slotmachine, lewis110).
Sounds like LVC is kicking in but you said you tested with it off so......
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 09-07-2015, 08:03 PM   #2133
Guch's Avatar
Originally Posted by Matthew_Armeni View Post
Are you asking what the max rear toe is if you're running the old aluminum C and D block on the .3 truck?
Yes. I'm actually running .3 arms and hubs on a .1 truck with .1 C & D blocks.
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 09-07-2015, 08:34 PM   #2134
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Ok, got it The max toe with what you have is 3 degrees.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 09-08-2015, 04:48 AM   #2135
I have exactly the same problem. I think that motor has problems and it takes too much current. Maybe some short circuit inside motor?
Bigbearfin is offline   Reply With Quote
Old 09-08-2015, 05:36 AM   #2136
Trader Rating: 19 (100%+)
Did you try (re)flashing the latest firmware to your esc?
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 09-08-2015, 09:35 AM   #2137
oops, double
RC10GT (LRP), T-Maxx, LSP (P5), SC10RS, SC10.2 (Reedy), 8ight-T 2.0 (Maxy's Cinco), 8ight-E 2.0 (Castle), MBX6Eco (Tekin)
vlamimc is offline   Reply With Quote
Old 09-08-2015, 09:41 AM   #2138
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by vlamimc View Post
I thought about this as well, but figured the motor temp would be high if this was the case.
Yes, I've been seeking help with Hobbywing and the the HW tech support forum here as well.
I was hoping to see if anyone else was having trouble with this combo in this truck, or if others are having success.
I'll probably put an RX8 in, going off the only theory I have now that the 3656 4700kv is too much in this truck for the SCT Pro ESC (might switch motor as well, but I enjoy being over-powered).
There are plenty of people that run that combo in this truck with no issues. I ran it with a 16 pinion in my original 410 for many months and it ran fine.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 09-08-2015, 09:41 AM   #2139
Old 09-08-2015, 09:44 AM   #2140
Trader Rating: 36 (100%+)
I've got a .3 that is set up mostly stock, with the addition of green rear springs, 6x1.5 pistons. I'm having a lot of trouble traction rolling. Should I go up in shock fluid or stiffer sway bars maybe? Thank you
mxturd is offline   Reply With Quote
Old 09-08-2015, 10:45 AM   #2141
FRONTI3R's Avatar
go up one location on your shock tower camber links. This will lower your roll centre. Don't forget to reset your camber after you have moved the links up on the tower.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 09-08-2015, 12:00 PM   #2142
I had the same problem with my hobbywing, I just did not have the time and energy to do any more troubleshooting, I just bought the Tekin RX8 and never looked back. I have been using the push control feature on the Tekin, the Hobbywing does not have that, so its another reason I switched.
Riflebuilder is offline   Reply With Quote
Old 09-08-2015, 02:40 PM   #2143
Hoese37's Avatar
Play with the shock tower location.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 09-08-2015, 03:41 PM   #2144
Im about to make my second order to complete my 410.3, is there any spare parts or screws that i should purchase. I dont think my local track stocks much tekno stuff.
TRoy9696 is offline   Reply With Quote
Old 09-08-2015, 04:11 PM   #2145
Ruffdog1's Avatar
How often do you guys change your diff oil? I think Ryan Lutz changes his every hour of driving. Is it necessary to change it that often? What do you guys do? Thanks!!
Ruffdog1 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
