    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 08-04-2015, 04:19 PM   #1816
Trader Rating: 23 (100%+)
Hey guys, whats the best way to build the shocks for a 1/8 track with large jumps?
Standard, Vented or Emulsion?
hawks is offline   Reply With Quote
Old 08-04-2015, 04:26 PM   #1817
Hoese37's Avatar
Originally Posted by Aswild View Post
Nobody notice the rear dogs rubing
I have noticed they are close, but no rubbing on mine. Id suggest just getting out a sanding drum on a dremel and slowly grind away till you have clearance.
Standard buid, no vent.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 08-06-2015, 04:55 AM   #1818
Originally Posted by FAO View Post
Solved the nose down problem with small motor can (450 size, -100g, light controller in the back left , -60g and shorty lipo-100g. Car is about 2650g without body. The first race (Clay, getting dry and dusty) was much better than the others before, but need more practice. Next test will be on astro turf.
What motor, esc, and battery are you running now?(I've been running a 1410 castle and the sidewinder sct esc and still suffering from the problem)
theboss13 is offline   Reply With Quote
Old 08-06-2015, 06:42 AM   #1819
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Have someone take a vid of your truck on the jump face you are having a problem with. I'd be willing to bet you are blowing through the travel in the rear. Essentially what FAO did was remove weight from the rear of the truck.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-06-2015, 06:58 AM   #1820
AccessRacer's Avatar
Here is my sct410.3 ready for saturday.
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
AE RC8B3E TEKNO SCT410.3 JRC JET EDM & LATEMODEL
AccessRacer is offline   Reply With Quote
Old 08-06-2015, 08:46 PM   #1821
Barillms's Avatar
Looks good bud. Try running it as is. Then after a couple races, remove the rear & center chassis braces. See if it makes a difference. It made a big difference for me, more than I expected.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 08-06-2015, 08:47 PM   #1822
Barillms's Avatar
Anybody try running heavier oil in the rear than the front? I notice everybody runs heavier in the front? Why is this? Thinking about going with 32.5F/35R this weekend.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 08-07-2015, 05:01 AM   #1823
Moderator
bds81175's Avatar
I don't tune my truck unless there are handling issues. Barillms, I'm assuming you have a handling issue that is causing you to want to make this change. What is the issue? Generally, when I start with a new vehicle, I spring balance first (no oil in the shocks) and then oil balance. This gives me a really good starting point and I've had a number of people tell me that my shock packages feel perfect (always awesome getting positive comments about your package).
Tekno RC
Old 08-07-2015, 05:57 AM   #1824
How do you go about spring balancing and oil balancing? Thanks.
qstorm777 is offline   Reply With Quote
Old 08-07-2015, 06:04 AM   #1825
FRONTI3R's Avatar
Check out the 4th post from "fredswain" here for that information:
Tune With Camber Links
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 08-07-2015, 06:14 AM   #1826
Hoese37's Avatar
The reason the front is usually set heavier than the rear is because the front end gets the brunt of the force first. When you approach a jump or bump, all the weight and force of the car that hits the jump first is the front, the rear just follows what the front does, but has less energy pushing it.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 08-07-2015, 08:02 AM   #1827
I noticed it at first and then checked my drop and it was at max or almost max. Once adjusted to 120mm give or take 1-2 mm, it did not rub/bind up.
Sponsored by Tekno
Tekno SCT410.3 - Hobbywing 4000k, RX8Gen2, Savox 1258, Vant Batterys
Tekno EB48.3 - Hobbywing 1800k, RX8Gen2, Savox 2274SG-TE, ProMatch Batterys
B5M - Tekin Gen 2 8.5/Express Motorsports 17.5, RS Gen2, Savox 1257, ProMatch Batterys
s14det is offline   Reply With Quote
Old 08-07-2015, 08:22 AM   #1828
So, what springs/oils did you end up with using that method?
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 08-07-2015, 06:33 PM   #1829
Barillms's Avatar
You don't tune your truck? Why? Lol
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 08-08-2015, 09:21 AM   #1830
Backyard RC's Avatar
Will Tekno truggy A-arms fit on the SCT 410.3? If so it might make a cool monster truck option.
Here's mine doing a parking lot run.
+ YouTube Video
Backyard RC is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
