    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 07-25-2015, 11:14 AM   #1696
Originally Posted by raved007 View Post
Everyone have already that. Someone posted in here before I'm glad i have a copy 😀
I can't say that I've seen it. Do you have a link?
red100076 is offline   Reply With Quote
Old 07-25-2015, 11:25 AM   #1697
Trader Rating: 32 (100%+)
Sorry not lasted the link when posted here.They deleted the link.
raved007 is offline   Reply With Quote
Old 07-25-2015, 11:33 AM   #1698
Can you upload it?
theboss13 is offline   Reply With Quote
Old 07-25-2015, 04:33 PM   #1699
Originally Posted by Uhudler View Post
I assume you are using an Apple device. Neither Safari nor iBooks will show the setup sheets properly. I am using the Adobe Reader App and it works fine.
Thanks u b rit,,,I will try kindle or on my lappy
Aswild is offline   Reply With Quote
Old 07-25-2015, 04:40 PM   #1700
Originally Posted by theboss13 View Post
Can you upload it?
Yea good luck,lol no one has posted it up i cant find it either an it was up for like 1 min ,an a few got it before it was taken down ,it's like men in black came to there house an told them don't say a word. I googled it an still could not find it.
Old 07-25-2015, 06:54 PM   #1701
Barillms's Avatar
Originally Posted by qstorm777 View Post
Anybody used the Jconcepts Illuzion Hi Flow body? I'm wondering how it handles especially compared to the Titan? Thanks.
I have the Illuzion SCT High Flow. It's a nice body, I like it. My last body was the Titan. Also a good body. I think I like this SCT High Flow better. Just stay away from the Manta. It cracks really badly.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 07-25-2015, 06:57 PM   #1702
Barillms's Avatar
Originally Posted by Dan.J View Post
Me too
I've had the Tekno set up guide for well over a month.
It's a PDF file on their site.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 07-25-2015, 07:19 PM   #1703
mkl
link please. I don't see it anywhere on their site.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 07-25-2015, 07:38 PM   #1704
Originally Posted by advpball View Post
pro 6272-00 proline body mount for sct410.3...Was a little confused this am...lol
Yes, I have it currently installed on my SCT410.3 and love it.
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 07-26-2015, 05:08 AM   #1705
Niicccceeee, so why are they being so secretive about it? Is it gonna cost money or something when it comes out?
Old 07-26-2015, 05:29 AM   #1706
Default ..
Who knows, i guess its like a a taboo,lol
Old 07-26-2015, 06:06 AM   #1707
They said it wasn't complete and they didn't want to release it until it was done.
qstorm777 is offline   Reply With Quote
Old 07-26-2015, 08:36 AM   #1708
Dan.J's Avatar
Trader Rating: 21 (100%+)
Liking this truck alot, been running it on indoor high bite clay. I have the truck working VERY well but I am running into the nose down jumping if I don't hit the jumps perfect every time, it makes it where I am timid to push the truck too hard in certain sections of the track. I am wining and placing well with it but I have to get this sorted. I hate to go stiff on the rear springs because it will upset other areas of the truck that are perfect. I may try the battery mod like alot of people did on the gen1, anyone try that on the .3 yet? This truck does EVERYTHING else so well, I just got to find a "good" fix for its jumping attitude.I am running a 550 can motor in the truck, what does going to a lighter 540 can motor usually do on these trucks as far as balance and jumping etc?
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 07-26-2015, 12:15 PM   #1709
I am running the castle 1410 motor and still have it nose down ALOT.... Sometimes to where I can't save it- I changed my setup to follow a pro who races at my track frequently and it seemed to help........ I am running greens up front and pinks in the rear
Old 07-26-2015, 01:42 PM   #1710
teknorc's Avatar
Try stiffer front springs and thicker front oil.
Tekno RC
www.teknorc.com
teknorc is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
