    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree79Likes
Old 07-24-2015, 03:06 AM   #1681
Dan.J's Avatar
Trader Rating: 21 (100%+)
Originally Posted by albertv78 View Post
I'm building a SCT410.3 for my kid to mess with and for some limited track time for me at OCRC (practice only, not worried about class rules). I've decided to try out the 4S route and go with a Tekin Pro 4HD 1850KV motor, HW SCT-Pro ESC, and low-profile 4S battery. What pinion gear do you guys recommend I start with? I used to run a 15 tooth pinion with a HW3656 4000KV 4 pole motor 2S setup on a previous SCT410 I had. I don't know what to start with.
-Al
I have the 1850 in my superlight buggy, I would start with a 18T and adjust from there. Its a very smooth/fast setup.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 07-24-2015, 03:16 AM   #1682
Dan.J's Avatar
Originally Posted by Ruffdog1 View Post
Thanks for the link Matt. I looked at all of those. I guess I will try some thinner oils with my 6x1.5 pistons and see how it runs. Do you know how PT racing oil converts to associated? Ryan Lutz is running 550 front and 450 rear. From the charts I have seen that equates to about 35 wt front and 30 wt rear for associated oil. Does that sound right?
Thank you!!!
Several conversion charts on google images, even PT racing oils chart to Losi oil I think.
https://www.google.com/search?q=shoc...MMoO7A#imgrc=_
Old 07-24-2015, 06:51 PM   #1683
Originally Posted by MattDub View Post
Most of our setups are for indoor but we are starting to get some outdoor setups too. Our site has a few, the link below might be a good starting point. Since the truck is new, our setups are limited. Check our site every week or so as we are trying to post new setups from our drivers and customers on a regular basis.
http://www.teknorc.com/tekno5/wp-con...se_lowbite.pdf
This is extremely close to my truck. I'm running on a 100 x 200 foot outdoor, hard packed and dusty track and it is really good!!!
Riflebuilder is offline   Reply With Quote
Old 07-24-2015, 08:04 PM   #1684
Ruffdog, I recommend taking a look at the setups on our site. They will give you an idea of changes to make to better suit your track conditions.
http://www.teknorc.com/tekno5/wp-con...eets/SCT410_3/
When I try to load the setup sheets all I'm getting is blank sheets, what am I missing?
Horby32 is offline   Reply With Quote
Old 07-24-2015, 08:58 PM   #1685
Barillms's Avatar
There's filled out sheets. And there's blank sheets. The filled out sheets are PDF files that auto download to your phone when you click on them. There's only 3 set up sheets posted.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 07-24-2015, 09:02 PM   #1686
Barillms's Avatar
I got my 6x1.5 pistons installed. Wow, alot faster action. The suspension moves alot more and seems way more sensitive. I'm thinking it may be too fast, I put 30 weight AE oil in front & back with Black/Green. Im thinking I need heavier oil. I guess I'll find out Sunday!!
30w AE is 350 CST
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 07-24-2015, 09:04 PM   #1687
Barillms's Avatar
Originally Posted by Sofa King View Post
550 cst is about 40(L) - 42.5(A) wt, 450 cst is about 35(L) - 37.5(A).
This is taken straight from the oil weight conversion chart:
550 CST = 45 (AE) and 47.5 (L)
Losi is 2.5 lighter that AE.
So 30 AE is equivalent to 32.5 Losi & so on.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 07-24-2015, 10:11 PM   #1688
Default Bodies
Anybody used the Jconcepts Illuzion Hi Flow body? I'm wondering how it handles especially compared to the Titan? Thanks.
qstorm777 is offline   Reply With Quote
Old 07-25-2015, 03:12 AM   #1689
Anybody know when the Tekno setup guide is coming out. Really looking forward to that.
Snarf450r is offline   Reply With Quote
Old 07-25-2015, 04:48 AM   #1690
Dan.J's Avatar
Me too
Old 07-25-2015, 04:49 AM   #1691
Trader Rating: 32 (100%+)
Everyone have already that. Someone posted in here before I'm glad i have a copy 😀
raved007 is offline   Reply With Quote
Old 07-25-2015, 05:15 AM   #1692
advpball's Avatar
Trader Rating: 27 (100%+)
Any one use rpm body mount system , I thought they make one but it's not listed?
or is it the slash one? Also in a pinch the slash body fits pretty close to tekno's hole pattern..
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 07-25-2015, 05:39 AM   #1693
Yea i am having same issuie all it does is open a blank sheet an no option i can only see the last one ?.
Aswild is offline   Reply With Quote
Old 07-25-2015, 06:08 AM   #1694
I assume you are using an Apple device. Neither Safari nor iBooks will show the setup sheets properly. I am using the Adobe Reader App and it works fine.
T5M / B6 / F6 / RC8B3e
Uhudler is offline   Reply With Quote
Old 07-25-2015, 06:10 AM   #1695
advpball's Avatar
pro 6272-00 proline body mount for sct410.3...Was a little confused this am...lol
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Cain
