Tekno RC SCT410.3 Thread
#1591
This weekend my rear differential failed. Two planet gears broke. I am quited sure that i can blame it on the pit crew as i rebuilt the diff right before the race. Has anyone ever had an issue with the diff on the SCT410 or am i just a little bit clumsy?
#1594
Location: Germany near famous clay track of RCRT Duisburg
I´m testing a lot of different ESC/motor setups, so this worked best for me.
#1595
TBR front bumper
I think T-Bone Racing's bumper may stick out past the body but I'm not sure. The stock bumper was designed to not go past the front of the body. When trucks that have the bumper in front of the body take a big hit the body often flexes up and over the bumper which then puts stress on the body mounts and the body.
#1596
sct410.3 vs. eb48.3 shock towers?
So are the shock towers interchangeable between the 2 still and are the eb48.3 towers stamped or cnc? Thanx
#1597
#1598
I contacted tekno and asked the same question. Won't work!
I did buy the carbon tower for the rear and it's really thick. Hopefully it's stong also lol
#1599
Ok thanx guys
#1600
[QUOTE=qstorm777;14086523]
You can do a 5.4mm lens conversion and that will make the gopro more like a standard aspect camera without the wide angle fish eye and edge distortion.
Sorta defeats the purpose of a gopro IMO, but it does work well. A lot of the drone guys are doing this for better filming shots.
#1601
[QUOTE=Josh L;14096791]
Thanks. Probably would help me see my car far away. I didn't realize I could change the lens.
#1602
So I was setting my droop today and my front is 105mm with the truck on a stand suspension uncompressed, but the droop screws aren't even close to touching the chassis. Is this correct or have I done something wrong? I had to adjust the rear to get it to the box settings
#1604
Droop
All I am seeing is 105mm for recommended front droop
