    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 07-12-2015, 04:42 PM   #1576
Trader Rating: 36 (100%+)
I'm pretty new to 4wd what is the best way to set up my droop?
mxturd is offline   Reply With Quote
Old 07-12-2015, 05:42 PM   #1577
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Originally Posted by PLUH View Post
Evening Gents, i'm looking for a bit of advice. I took my truck to a outdoor carpet track to practice for an upcoming race and the truck suffered from SEVERE snap oversteer.
Im running box setup and only changed out shock oils and centre diff (40/30 WT and 30000 cts on centre diff) on Proline pinpoints front and rear.
I tried running non carpet tyres front, but that just created excessive ondersteer and reduced acceleration. I dont have different springs or pistons to swop out.
What other changes can I attempt to curb this. Track is fairly smooth with only small jumps.
Any help would be appreciated.
Go all the way down on the A block and all the way up on the B block to give yourself the least amount of kickup - less dive into the turn and all of our cars seem to drive better with less kickup. Go all the way down on the C block to have less antisquat - more rear "side" traction into a turn. Lesson your front toe out - less off power steering and more on power push. Move your ackermann all the way forward - less sensitive steering off center and more high speed on power steering. Try using your steering limiters on the spindles - you might have more steering than you need. Move the rear shocks out on the tower - should give a little more rear traction into corners.
There's definitely more to try but these are the first things I think of. You may also try a lower RC in the rear.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 07-12-2015, 06:22 PM   #1578
Default Sct410v1 vs. Sct410v3
Hey guys I have been following this tread for a while and was hoping to see some comparisons between the sct410v1 vs the new sct410v3 from someone that either has them both or made the upgrade to the new truck. I have not seen any reviews, if i missed them please point me in the right direction. So my question is how much better is the new truck than the original? If so what improvements are noticeable.
red100076 is offline   Reply With Quote
Old 07-12-2015, 07:05 PM   #1579
Tekno says to measure the center of the upper and lower shock mounting screws, the rear should be about 118 mm if I recall correctly. I'm not in love with that method. I like the wat the Hudy set up guide shows, so after I have it at the recommended Tekno setting, I use small blocks under the chassis and measure the axle heigth.
Riflebuilder is offline   Reply With Quote
Old 07-12-2015, 07:37 PM   #1580
So should I set ride height then droop, or droop then ride height, or does it matter
Old 07-12-2015, 08:05 PM   #1581
It won't matter for those 2. But do set your ride height before you set your camber. And anytime you change your camber or front toe check the other one. Also check your bumpsteer any time you make RC, ackermann, or front arm sweep adjustments.
Tekno RC
Old 07-13-2015, 03:41 AM   #1582
Default electric question
I am new to electric got my 410.3 almost built tekin rx8 pro4hd 4300 motor I have 2 2s 4600 mah 90c shorty packs will the shorty packs work or do I need a regular length battery?
TeamTerribles,Agama A8 savox alpha a872 and picco edo mod evo3 &w fuel
toofless is offline   Reply With Quote
Old 07-13-2015, 03:54 AM   #1583
The battery trey are not set up for those
Aswild is offline   Reply With Quote
Old 07-13-2015, 04:25 AM   #1584
Default re
I didnt say saddle packs not worried about battery moving just wondering run time
Old 07-13-2015, 04:48 AM   #1585
Dan.J's Avatar
Trader Rating: 21 (100%+)
Run time wont be all that great with the 4300hd and 4600mah unless you are real light on throttle/brakes and have current limiter etc turned down in esc. Most run 6500-7200 mah packs (for racing anyway)Just have to try them and see what you can get out of them .
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 07-13-2015, 05:54 AM   #1586
I have the same set up, but I have some Eco Power 4000 mah shorty's for my buggy that I play with. I was impressed with the run time. I was getting around 5 minutes which is enough to check set up changes and warm up with out messing with race batteries. I will time mine next time if it ever drys up in Ohio.....
Old 07-13-2015, 09:09 AM   #1587
Is there a front bumper that will stick out in front of the body like slash 4x4? I really like the look and durability of having the bumper out in front of the body.
Dragonfueled is offline   Reply With Quote
Old 07-13-2015, 09:49 AM   #1588
Default re
thanx guys
Old 07-13-2015, 10:10 AM   #1589
Default Motor/Esc Connection
I always solder my motor directly to the esc. Anybody use bullets between motor and esc? Just wondering how well it works? Saw this setup this wkend and thought that would make changing out motor and/or esc easy.
qstorm777 is offline   Reply With Quote
Old 07-13-2015, 11:10 AM   #1590
I think T-Bone Racing's bumper may stick out past the body but I'm not sure. The stock bumper was designed to not go past the front of the body. When trucks that have the bumper in front of the body take a big hit the body often flexes up and over the bumper which then puts stress on the body mounts and the body.
Tekno RC
Tags
sct410, sct410.3, short course, short course 4x4, tekno
