deans plugs getting hot wat to do?
gday all i have a problem ive always used deans plugs from battery to esc but now they seem to be getting very hot only the plug. 14.8v 40c bias battery tekin rx8 esc rc8.2e really speaking im just not sure of amp ratings so id like to no what plug to use or do i have a problem im not sure thanx all
Since you're only seeing the plugs get hot I'd unsolder and resolder them because something about the connection is causing resistance. I'd then look at the ESC programming and reduce the current limiter. In my experience if you have it set high (80 - 100) you do run the risk of have it draw too much current and causing the solder to melt at the connector or motor or else where. my 2 cents.
You can also try using a 10 guage wire ever since i put that on my car everything felt cooler than a 12 guage
deans
thanx tlrunner your 2cents is good info as recently i did fiddle with the current limiter and i just never thought of it cheers guys my 1st thread getting great answers
Sounds like you may be over geared. What car and gearing do you run?
TLRunner's suggestion is good. Reflow both sides of the connector so you know there aren't any cold solder joints.
If you are running above 60 A regularly, you probably should go to a connector with a higher rating. Google search says 50A continuous and 75A burst.
I have had issues with older deans not getting great contact. That can also lead to hot plugs.
How big is the battery your running? Maybe deans will be OK if your running 2s lipo but if your on 4s then the deans won't last long. I've tried lots of plugs with my 4s set ups and I've found the XT 90 to be the best. Stays cool, easy to pull apart. Deans were good 10 years ago for 6 cell
ni-hd
ni-hd
ni-hd
ni-hd
