    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Like Tree5Likes
Old 10-28-2016, 06:29 AM   #1051
Azzkikin's Avatar
Originally Posted by charvel74 View Post
Nice job on the body
Thanks dude. It fits all motor positions too.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 11-01-2016, 03:47 PM   #1052
303slowdown's Avatar
Trader Rating: 21 (100%+)
Trying to find a slipper eliminator. Rc madness use to make one but i have not been able to find one. Anyone now if one from another car will work ? Thanks
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-01-2016, 06:12 PM   #1053
Super Moderator
Trader Rating: 17 (100%+)
I haven't seen on myself but would be interested.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-02-2016, 03:49 PM   #1054
Jpdanger's Avatar
The holes on the outside slipper plate line up with the holes on a Kimbrough (sp?) spur gear. Screwed in three button head screws and this is how I made my eliminator.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 11-02-2016, 04:36 PM   #1055
Good idea, ill give that a try. Thanks
Ryan Borgheiinck
Old 11-02-2016, 07:56 PM   #1056
Super Moderator
My goal is to also cut the rotating mass out. If I can't find something, I'll likely do the same. What are you doing on the other side of the spur? Just running it normal? I know it's not slipping, but I am thinking weight reduction = quicker acceleration.
I'll get the carbon fiber chassis and I'll probably grab a set of Acer Ceramic bearings too just because.
Looks like I'm building a 17.5 car after all
Old 11-03-2016, 07:56 AM   #1057
Azzkikin's Avatar
I have used the JConcepts spur gear and the holes line up perfect with the vent holes on the disc. But currently I am just clamping down on the spur with one pad on each side and a plastic standoff to take up the gap between the nut and disc. This way works great and allows for easy gear changes.
If ya go back to pg.69 you can see my set up.
Old 11-06-2016, 05:21 AM   #1058
PsycoB4's Avatar
Trader Rating: 41 (96%+)
hey how is it going? I been researching and such and been wanting a new kit to get back into racing after 5 years. I love this kf2 Build.
I used to run a cougar.
this kit I got in trade, has some upgraded parts and I also am going to be purchasing a few. Im not too sure what it may have missing or would need.
What option parts do you recommend???
Do you also run the Carbon chassis or the Alloy??
What setup do you run? Or do you have a link to a setup? High Bite Indoor Clay Dirt Track? Running Slicks?
Also whats the diff between the KF2 and the KF2 SE?
thanks again and If you need pix or anything more of the buggy let me know. Thanks again guys.
PsyCo_Chris
WWW.FinalTechniqueCustoModz.Com
Custom Metal Fabrications // LED Lighting // Jeep Specialist
PsycoB4 is offline   Reply With Quote
Old 11-06-2016, 06:30 PM   #1059
Super Moderator
I have alum caster blocks, spindles, front camber mount, Ackerman plate, and Read upper bulk head (so you can run the shocks on the back of the arms).
My car is the SE, so I can run all 3 motor positions. I talked to Michal the other day and we were discussing the different positions and we both feel that MM (motor all the way back with battery in front) is the best all around layout. I'm currently running Tom Yardy's Telford setup but with a gear diff. It's pretty good. The only changes I made were to shorten the wheelbase some (run it middle) and remove the anti-squat.
Right now I run on Astro and Ozite. I haven't run it on clay yet but will probably try it at Bumps and Jumps soon.
http://www.racing-cars.com/images/Te...TY_telford.pdf
I'm going to also try Michal's Reedy Race setup on clay. In order to run that, you need the 4mm toe blocks.
http://www.racing-cars.com/images/Te...Reedy_OCRC.pdf
Hope this helps.
Old 11-09-2016, 02:04 AM   #1060
Disturbed1's Avatar
Trader Rating: 20 (100%+)
Default Cougar KM
Hi all,
Couldn't wait any longer for schumacher to release a new buggy running a standup midmount tranny,so i made this.
cheers,
David
Schumacher-K2,k1,Cougar-KD,KC,KF2,KF,KR,SV2,SVR,2000,CLUB 10,Cougar 2,Cougar,Storm Truck,Cat xls,Fabiix mid mount cougar 2000,MI2
KO EX1 KIY
Disturbed1 is offline   Reply With Quote
Old 11-09-2016, 02:29 AM   #1061
Hey David,
That looks great, what transmission did you us for that conversion?
Any body off pictures possible?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-09-2016, 04:01 AM   #1062
Disturbed1's Avatar
Default KM
Hi,
Here's some body off photos,Please excuse the messy wiring!!
transmission-XB2 DE 3 Gear,I have the 4 gear transmission also so that will be tested in due time.
Chassis-based on a KF2 +7MM Chassis,this was made up for me by Paul at Bezerk RC here in Australia
Hope you like,
Cheers,
David
KO EX1 KIY
Old 11-09-2016, 06:20 AM   #1063
That looks great David, well done!
Did you use the compl. Rear end from the xb2, exapt the shocks?
Is the lenght of the rear arms the same between the xray and the kf, also the high of the shock tower too?
Also the distance between the inner hinge pins?
Quit interested in some more detailed pictures, if you dont mind!?
Thx in advance
Mike
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-09-2016, 06:22 AM   #1064
PsycoB4's Avatar
so why the change to the Xray tranny?
PsyCo_Chris
Old 11-09-2016, 06:31 AM   #1065
Trader Rating: 9 (91%+)
What is most important...how does it run?
leongkc is offline   Reply With Quote
