New Schumacher KF2
#992
Do any of you guys mess with the wing angle and notice a difference in rear grip? I have always had my wing pitched up (no spacers on the mounts). Wondering if that's why I have so much rear traction in the LG setup. Racing against guys with the MM setup, I have no more or less traction then they do and they are running weights in the rear too.
#993
Speaking of wings, have any of you found anything other than the Schumacher wings that fit ok? I haven't found any that fit correctly as ours mounts so wide. I love the Shuie wings but it would be nice to have options for when I destroy one at a race and the track doesn't stock them.
#995
Jconcepts Aero Xray XB2 Rear Wing might work as it looks flat, so you can place the holes where we need them.
http://www.jconcepts.net/shop/aero-xray-xb2-rear-wing
Or the Team Durango 1.5mm HD Straight Wing
http://www.team-durango.com/part-inf...artNo=TD480015
#997
#998
Here is the setup I ran at OCRC and it was stuck to the ground.
#999
Ah, just saw you mentioned Rear camber links. By reversed you are talking about being connected on the rear side of the hub? The only reason, is I was trying all sorts of positions on the arms, Flipped and different spacers. In the flipped position, the links need to be reversed to limit the bind. But when I put the arms back to the stock position, the links didn't interfere with the springs or binding. So I just kept them.
As for the MM, I haven't needed to go to that setup in search of more traction. And since I didn't get the SE kit, I don't feel like spending the $80+ on it just yet.
#1002
MM
Hi Bob, always like reading your thoughts and feedback! I just had my scales calibrated (last numbers posted not correct) and running the ESC in the right rear Protek's 2800 XLW/D4 motor. Balance F/R 38/62 -50/50 side total wt. 1298 grs w/o tires. I also have 40 grs wt L/rear. Plenty of side bit and forward grip excellent attitude off jumps. Don't give up on the MM yet!
#1003
Just checking, If my chassis has the holes for the MM, would I only need the Belt (U4796) and Mid Motor Carbon parts (U4797)?
Also running super shorty's, I probably only need the little carbon pieces that tie the tranny to the back shock/diff housing. I'd end up making my own bat hold downs.
#1004
#1005
I'll just make one. done and done. lol
