    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Like Tree5Likes
Old 10-03-2016, 12:19 PM   #976
What did you not like about the mid motor layout Bob?
stueys is offline   Reply With Quote
Old 10-03-2016, 12:34 PM   #977
Super Moderator
Trader Rating: 17 (100%+)
I was on a fairly small track that had a very tight layout. I felt that I didn't have enough steering. When I made a tire change on the front end (added foams to the tires), I got more steering but severely upset the balance of the car. It was just one of those things where you could feel that car wasn't right.
The locals at the track all run in the low grip setting for just this reason. Bottom line is I just need more track time to figure out what I like. The car has so many options that it's quite easy to tune yourself out.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-03-2016, 01:22 PM   #978
I agree regarding the options. I have tried all 3 positions, and not sure which is best. I was after a bit more drive forwards so thought the mid position would help. Not sure if it did, I raced on medium grip carpet at the weekend and killed the rear minipins in not many runs, where other cars were much better under traction. The weight distribution is very similar for each position too which was a surprise. Sometimes less choice is not a bad thing!
Old 10-04-2016, 06:04 AM   #979
Super Moderator
I'm going to rebuild my car Saturday and put in the low grip layout and probably start with the kit settings and work from there. Just not sure when the next time I'm going to get a chance to run is.
Old 10-04-2016, 06:52 AM   #980
Azzkikin's Avatar
I am running the LG setup with a Super Shorty and ESC next to each other. Having great all around traction on a medium bite clay. Although a little push on throttle exiting the corners.
Azzkikin is offline   Reply With Quote
Old 10-04-2016, 07:35 AM   #981
JsK
JsK's Avatar
You can run the U3997 front tower its 4mm taller. I would prob start with the
shock rod ends unscrewed 2mm and start with 2mm less front droop.
JsK is offline   Reply With Quote
Old 10-04-2016, 07:39 AM   #982
Azzkikin's Avatar
So no limiters in the shocks to limit droop?
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Old 10-04-2016, 07:45 AM   #983
JsK
JsK's Avatar
Are you running any now? The old tower is 4mm taller so that will take up
some droop, but if your already running say 2mm of limiters then I would take
them out and just start with the taller tower.
Old 10-04-2016, 08:35 AM   #984
Azzkikin's Avatar
I am not running any right now. Taller tower is on order but wont get it till after Friday races. So, I'll go with some spacers to get through the races.
Old 10-04-2016, 05:50 PM   #985
I have tried all the motor positions starting with mid and now I ended up back with mid while I don't think the car feels natural in this position it is definitely faster but only with the carbon chassis and super Shorty battery the low grip spec to me was definitely the easiest to drive and most consistent just lacked the steering on exit and speed I was looking for definitely try making a little plate off the rear of the car to attach weight to
Team gizmo USA 🇺🇸 RSD legends barbershop N Control
Larrysraceprep is offline   Reply With Quote
Old 10-04-2016, 05:52 PM   #986
Here is my best setup I have come up with so far
Old 10-05-2016, 01:08 AM   #987
I have noted that in the UK, some people are changing the slipper into a more common 2 pad slipper setup by removing the cage and spare plates. I am trying to work out what effect the quite heavy standard setup has as far as its rotating mass, is it helping transfer weight rearwards like the mid motor setup or forwards? It rotates towards the back of the car.
Cheers
Old 10-05-2016, 02:41 AM   #988
Hi Larry,
There are a fiew things i do not understand at your setup sheet, as you mentioned, that your car has lack of steering at exit corner, but you are running 5* front caster blocks, which are making the steering softer and gives less power on steering at corner exit?
Also, you have rear shocks at the rear of arms and are putting 3/4oz of weight at the very rear end, but running 3* of anti squat and have your rear shocks all the way laying down at the tower, so you stiffen up the rear suspension as much as you can, also running long wheel base at an tight, smoth, high grip indoor clay track, that all is confusing me a little bit?
Could you clarify that to me, why you have set your car like this?
Thanks in advance
Mike
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 10-05-2016, 07:40 AM   #989
Originally Posted by micholix View Post
Hi Larry,
Thanks in advance
Mike
Sorry what I meant was in the low group set up it had steering problems on exit my mm setup is very good I extended the wheelbase to add a little bit of consistency to the car and it was a bit twitchy running it that short
Old 10-05-2016, 07:44 AM   #990
Ah ok, so do i understand right, the lack of steering on exit corner was not with that setup?
YZ-10 '94/'95 WCS/
Spectrum DX3R
