New Schumacher KF2
#916
#917
It's also not the HRC kit spacer that was rubbing. It was the rear caster spacer that was. I bet if I reversed the order and had the caster spacer under the HRC spacer, I'd have no problem. I know in the front the HRC spacer is supposed to be on bottom.
At any rate, I have shaved down the dust shield and it clears now. Did not effect how the shield works either. And if flipping the spacers is the answer and even more clearance.
I just realized that the read hinge pin mount is whats being raised, so spacer orientation has nothing to do with anything. It's the hinge pin mount that is applying pressure on the dust cover pushing it ever so slightly into the pulley.
#920
Under weight
What weight are you guys coming in at? I'm at 1486. The only thing I can think I am missing is the timing chip.
#921
So you're running the HRC kit on clay with treads? I'm curious to know how this works out for you because I would think this would remove a lot of grip. I also haven't seen anyone run anything other than Mid Motor position when trying to run on clay. I'm currently in MM position but I'm going to move to low grip. And my car is very heavy. last time I checked was last year with different electronics and it was around 1650. That was out of the box with the Pulse V2 esc (which was huge) and MM configuration.
#922
Well, I've yet to try it with the HRC kit. So we shall see come Friday. I currently don't have the MM kit, so LG is what i have to play with so far. I can't see spending $90+ on a belt and a few braces. I have the CF with the 3 positions already.
#923
#924
HRC setup I found on clay did not work well! Bob's right on that. My buggy weight's around 1499-1502 grs. MM conversion set up now. Have tit and aluminum screws, C/F chassis RCM lockout, small bore shocks. Attachment 1383949
Is the small bore shocks just for weight savings or are there more tuning options available?
#926
#927
I don't have the instructions with me, but I thought it said to put the kit spacers under the caster spacers. If I am wrong, then that is where the problem is.
#928
Tech Legend
Trader Rating: 51 (100%+)
You just have to have a stock and mod car. I'm trying to get a stock at least that way I can run both at Bumps or where ever I go if they offer both classes. Normally I like one class but sometimes I will run a 2nd if I have enough time.
#929
Although it was fun as hell to make half the mod field mad running 17.5 in mod and still finishing mid pack
