    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Like Tree7Likes
Old 03-29-2016, 10:30 AM   #781
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by the big rc View Post
What does mounting the shocks on the rear do for you? I've bought the conversion because everyone is doing it here for carpet, just wondering what it does.
thanks
When you mount the shocks on the rear, you're adding stability and rear grip. You in essence shift a little more weight over the rear axle. I did it on my car and it was very noticeable. If you're on high bite carpet, this may allow you to shift your motor forward one step (from mid to low or low to forward). You'll have to see how much more grip you get.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-29-2016, 12:13 PM   #782
Very interesting, but makes sense that even a small amount of weight that far away from the c of g makes a big difference. I had previously thought about a brass version of the rear hinge pin retainer (U4686) for similar effect.
oldernoob is offline   Reply With Quote
Old 03-29-2016, 12:22 PM   #783
Super Moderator
I personally try to refrain from adding weight unless I have to. That's a tuning thing for me though. My car's heavy enough so I don't really want to add more.
Old 03-29-2016, 12:54 PM   #784
100% agree, I hate the thought of superfluous weight but that's also what I thought when I saw the 'Factory Team' lead weight in the RC10B4.1 FT WC Kit, surprised that it wasn't blue...
Old 03-29-2016, 01:27 PM   #785
Super Moderator
Well that's different. The B4 platform was designed around round cells, which were considerably heavier. You had to add some weight to get the car back to the proper weight.
A lot of people forget how old that car is. Billy Easton won the worlds with it in 2003
Old 03-30-2016, 03:26 AM   #786
Saturn V's Avatar
I hate adding weight but I've slowly gotten used to it. Lower grip simply requires a ball diff and a certain amount of rear weight bias. I now have 25g in and around the lower transmission housing. It bothers me because the KF2 is already quite heavy but at least it's all low and within the wheelbase. I should scale it again to see if I'm up to 60%. I'd like to try a carbon chassis and make up the difference with ballast... Probably not going to happen.
Oh well. It's all worth it when I pull the body off and people lose their minds.
Saturn V is offline   Reply With Quote
Old 03-30-2016, 06:13 AM   #787
Super Moderator
Exactly...or my favorite is when I put the car down and guys tell me I'm in the wrong heat because 'this isn't 4wd buggy'. Love the sound that car makes screaming down the straights
I'm not going to get much 2wd wheel time for the next few months, but come this fall I'll grab scales and work on the weight bias. I have a feeling my KF2SE is never going to touch dirt or clay again. I'll probably piece together a SV2 for that, but who knows
Old 03-30-2016, 01:17 PM   #788
Default Weight
I have put a lot of time with the MM package from high bite clay to loose dirt! My running weight is around 1513-15 grs. With 65 grs. on the rear W/ carbon chassis! Love this buggy took more time to get the buggy to perform on high bite tracks than loose one's for me! Balance is 39/61 & 50/50 side. However with a more precise scale ie..half measurements .50 it is close to 38.5/61.5 balance as my SkyRC scale fluctuates between 39/61-38/62.
MelKF2 is offline   Reply With Quote
Old 03-30-2016, 09:11 PM   #789
Super Moderator
Hey Mel, Can you post pics of your car and list the option parts you're using? I may try just building a 2nd KF2 for dirt and it sounds like you have a nice starting point.
Old 03-31-2016, 07:27 AM   #790
Will send setup sheet in a few! Cool
Old 03-31-2016, 07:44 AM   #791
Old 03-31-2016, 09:55 AM   #792
MelKF2 - pictures not working, is it just me?
Old 03-31-2016, 10:51 AM   #793
Super Moderator
not working for me either
Old 04-01-2016, 10:46 AM   #794
DiscountRCStore's Avatar
Posting pix and setup for Mel .. you can download the setup in .PDF here: MelsKF2
.. p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 04-01-2016, 05:24 PM   #795
Wow, liking that. Thanks for the pics and set up sheet too. Are there spacers behind the front outer ball joints enabling straight ball joint cups?
Someone mentioned 'Tyre Slap' when i visited SRS i could hear some cars making a cracking sound-i thought it was a drivetrain thing. Some dude told me it was the tyres, is that true? what makes that sound?
