    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Like Tree7Likes
Old 12-08-2015, 09:13 PM   #646
Jpdanger's Avatar
Originally Posted by Mike_OBrien View Post
What's the best motor position for a medium to high byte carpet track ???
Mikael Orlowski (sp?) has been extremely successful with the LG setup. You could start there and it would be an easy transition to the forward position if you still need more steering.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 12-11-2015, 08:33 PM   #647
I must be missing something here have the KF2 se. With the low grip option on it and I cannot get my shorty pack in there without taking the side rail off any ideas
Mike_OBrien is offline   Reply With Quote
Old 12-11-2015, 09:26 PM   #648
303slowdown's Avatar
Trader Rating: 24 (100%+)
I had the same problem and couldn't figure out a way around it.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-12-2015, 04:46 AM   #649
I)arkness's Avatar
looks the same as Orlowski's car, its nothing specific to the lipos being used?
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 12-12-2015, 07:11 PM   #650
You need to trim the right side skirt down to the shelve and a little wider than the battery. See kf2 setup at petitrc.com there are picture of this modification. Sorry I'm not sure how to post pictures or I could show you! See above site look up indoor setups Orlowski EOS (Wels) KF2 Nice picture of mod!
MelKF2 is offline   Reply With Quote
Old 12-22-2015, 01:40 AM   #651
I)arkness's Avatar
so was building my new kf2 and wondered about the shock piston size? the book said 1.5 and 1.6, but during measuring it was more like 1.4 and 1.5
B.Portelli
Old 12-22-2015, 02:28 AM   #652
alport78's Avatar
Here is the area you have to cut to fit the shorty battery.
Schumacher KF2
alport78 is offline   Reply With Quote
Old 12-22-2015, 06:35 AM   #653
Default KF2
Thank you sir for supplying the picture for them!
Old 12-22-2015, 07:01 AM   #654
Can this car be made to work on a low grip dirt/clay track? I see the SE has the mid motor option which I believe is supposed to be best on low grip?
Schumacher K1 Aero, Custom Works SE4
cwalsh is offline   Reply With Quote
Old 12-22-2015, 12:30 PM   #655
Default KF2
Sure! There are some very good setup's on petitrc.com Schumacher KF2
Old 12-23-2015, 04:39 AM   #656
Another question I had was how much of a difference do the emulsion style caps make. Most every set up requires emulsion caps but Schumacher still sends volume caps with the kit. When I had my K1 I never ran it without the bleeder caps so I was just curious to see if anyone runs regular caps on low grip surfaces?
Old 12-23-2015, 06:20 AM   #657
Emulsion lets the oil and air mix together! With the bladder the oil and air are separated. Emulsion I feel needs to bleed often but has a better feel to the car. The bladder feels more consistent less bleeding involed, but to me doesn't feel as planted on the ground as does emulsion to me! Hope this helps out some.
Old 12-23-2015, 07:14 AM   #658
Yes that does help. Thanks for the advice. Just wish Schumacher would just put them in the kit, not crazy about the fact you are adding $30 to the price of the kit before you even start building.
Old 12-23-2015, 07:28 AM   #659
Super Moderator
Trader Rating: 17 (100%+)
I posted this on the KF thread too.... anyone know if the KF2 bodies fit on the original KF?
Also, are there any other options for spur gears? Can I run AE?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-23-2015, 10:07 AM   #660
Default KF2
From what I here they will! On the spurs RW Racing has them for Schuie! Check with Phil at DRC.
