    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Like Tree7Likes
Old 05-22-2015, 01:52 PM   #301
Originally Posted by Jpdanger View Post
Yes. Race ready box stock with aluminum camber mounts and CF chassis weighed in at 1540g without a body. I believe if you remove the side rails and stiffeners you'll drop about 40g if memory serves???
My car ready to race, is 1599 right now with the side rails off. I wanted to try small bore shocks, titanium turnbuckles, and CF chassis to cut some more weight.
The best Price in RC At Powerhobby.com
maizer is offline   Reply With Quote
Old 05-23-2015, 08:56 AM   #302
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Carbon chassis is 60g lighter than alum if Im remebering correctly...
It add grip with more flex and raising cg slightly.. I didnt like the alum even on high bite
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 05-29-2015, 07:32 PM   #303
hanulec's Avatar
Trader Rating: 27 (100%+)
did a little weight balance measurements on Wednesday night with Maizer. the results might surprise you.
first my KF2
now the maizer-KF2
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-30-2015, 07:21 AM   #304
Its tough to get accurate reading on those scales unless you replace the shocks with turnbuckles.. preload can change the numbers alot
Old 05-30-2015, 07:24 AM   #305
Suspended
Trader Rating: 61 (100%+)
As well as dirty tires. Remember, the rears will retain more dirt than the fronts, and throwing the numbers off.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-30-2015, 08:34 AM   #306
hanulec's Avatar
left to right "tweak" can be impacted for sure, but not front to rear balance --- which was my only analysis goal.
i can see this being impactful. maybe more impactful is that we have different tires.
Old 05-30-2015, 01:09 PM   #307
I disagree... scales dont know which tire is on them
Old 05-30-2015, 01:11 PM   #308
I always weighed my cars on the chassis.... tires are irrelvant for a weight distribution comparison since they are unsprung weight
Old 05-30-2015, 04:29 PM   #309
You don't race your car with turnbuckles instead of shocks, why weigh it that way? Stop cheating the scales to get certain percentages and focus on how the changes you make effect handling. Yes preload effects scale readings, it's called weight transfer... one big reason for tuning your suspension and the whole reason to use scales.
Banshee8530 is offline   Reply With Quote
Old 05-30-2015, 04:52 PM   #310
UNSTABLE's Avatar
Valid point if you already have your electronics/chassis layout balanced, but trying to do that with the variable of shock pre-load is not the best idea.
Some R.C. stuff.
UNSTABLE is offline   Reply With Quote
Old 05-30-2015, 05:02 PM   #311
Preload is unrelated to weight transfer, maybe you meant weight distribution? Anyhow... doesn't matter to me how you take the info I supply. Sounds like you guys have it all figured out, I'll leave you guys to the engineering.
Old 05-31-2015, 03:54 AM   #312
UNSTABLE's Avatar
Hmmm, I was actually agreeing with you but I guess you could read that either way.
Some R.C. stuff.
Old 05-31-2015, 07:35 AM   #313
Default The scale Photo
Let me just say this, that will explain the front to rear weight readings. The yellow buggy has a small servo and all stock front running gear. The white car, my car has a full size servo, aluminum steering rack, and front link mount. Also I have removed a lot of weight from the transmission and moved it back on the chassis as fare as I could. The battery is now in the center. Overall I feel the car is better on wet clay running slicks or treaded tires, at Critters. At Cruzzin I well the same. Now that I have the transmission/motor were I feel is best, I will work on my setup, as I have been running 1.8 rear springs and 4.0 fronts and all the other adjustments to cause less steering and more rear grip. Im sorry for not answering questions or posting photos on how to do what im doing with this car. I cant give away to much information, and would not even be talking about it if that photo did not get posted.
Old 05-31-2015, 10:56 AM   #314
Jpdanger's Avatar
Why the secrecy?
Jpdanger is offline   Reply With Quote
Old 06-01-2015, 09:31 PM   #315
motorcitymatt's Avatar
Interesting. This is why I was very curious to see an actual measurement of this layout as eyeballing it does not always end up agreeing with the measured results, which in this case were counterintuitive (at least to me). But based on what Maizer is saying I do not think it was his intent for this design/experiment to be made public let alone scrutinized so I digress.
With regards to the comments about the method of measuring used my question to anyone is: What are you trying to measure? If you want to determine where the center of mass is on the car then the best way to do that is how Tony has been suggesting. Remove and/or account for all the unsprung mass and take the spring pre-load out of the equation by using struts to set the suspension level at ride height. Once you can see where the center of mass moves as you make changes then you can start answering questions about dynamic weight transfer and handling.
This is not to say that scaling a car on tires has no value. It is just not as accurate in determining the car's center of mass, which is the key element affecting the car's handling.
Schumacher Cougar KC, KF2 SE
RC Clubhouse in Warren, MI
DiscountRCStore.com (The best online hobby shop)
motorcitymatt is offline   Reply With Quote
