Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-02-2005, 10:22 AM   #1
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
Default XXXNT AD 1 questions
I just picked this thing up, and I am new to nitro. It has a OS 12 CV in it right now, but came with a new not even broken in Fantom FR12. They are both bumpstart and i have the starter box.
Now, for the wuestions. What hopups or parts shold i uy for it right away? DO i need to change any gearing(or should I) for the Fantom? What else do i need to make this thing hardcore? I am used to racing top o da line off road electric modified, so i know I may have to spend some money, but what extra parts, back up parts, etc do i HAVE to have...
thanks
losirunner is offline   Reply With Quote
Old 10-02-2005, 12:53 PM   #2
No need to change gearing..the only aftermarket parts I ran on the old truck were the Trinity front pivot block (for weight..part number TK5009) and the rear hubs (TK5071 for the one degree aluminum ones).
If/when you break a few things, I'd start trying to convert the truck over to AD2 status. The front end is easy..arms and caster blocks. But as it is, no worries about making the truck better, it's great out of the box.
Aaron Waldron
Associate Editor, RC Car Magazine
25233 Anza Dr.
Valencia, California 91355
aaron@hi-torque.com
Aaron Waldron is offline   Reply With Quote
Old 01-24-2006, 08:11 PM   #3
nwilcox88's Avatar
Aaron
I just picked up a new XXXNT Sport RTRII from a friend. Is this the same truck you are talking about when you say change to AD2 status when I start breaking parts?
Sorry for the dumb question, I am new to Nitro
nwilcox88 is offline   Reply With Quote
Old 01-25-2006, 04:04 AM   #4
Default xxx-nt
I have a xxx-nt and when I put a o.s. 15 in it it smoked the gear in the tranny....so I replaced it with the robinson racing alum gear....you need to do that...the plastic gear in the tranny is not equipped to handle the power an aftermarket engine puts out.....so...replace the gear with the robinson racing gear...cost about 20 bucks......
Also replaced the o.s. with an tt evo 12....best engine I ever owned
oginct is offline   Reply With Quote
Old 01-25-2006, 11:05 AM   #5
the diff gear should last a long time with any motor if its adjusted right. One thing that eats them up is having your slipped too tight, having too much drag brakes(heats evrything up and the tranny case get warped around top shaft bearings), or having diff too loose. If you follow the diff rebuild directions to a TEE you shouldnt have any probs. I know alot of the seasoned Losi gas truck racers will get a couple gallons out of a diff and not ever strip it, it just gets gritty and needs a rebuild, flip diff washers and often use the same diff gear for many more races. IMO the best hop ups are the 4 degree rear hinge pin block by Rock Concepts, and the alu rear hubs so you can stack washers for more or less body roll. I love the OS CV with aftermarket head. The most driveable and raceable motor out there. The new Draked Edition Tinity/Sirio motor is the bomb too, but twice the price of the old CV red head.
riverrevo is offline   Reply With Quote
Old 01-25-2006, 01:40 PM   #6
rusty-racing's Avatar
The only problem with running this gear is whats gonna stop the middle gear from stripping because its plastic also. If your stripping out the diff gear then your slipper is too tight
rusty-racing is offline   Reply With Quote
Old 01-25-2006, 04:03 PM   #7
Trader Rating: 15 (100%+)
personally I'd stick with the o.s. cv. You dont need a alot of power in 2wd nitro. i think the fantom would be overkill. I agree You shouldnt need steel gears in the tranny if your diff is adjusted right. Also Aaron is right just get the trinity front bulkhead and i would highly recommend a trinity aluminum rear piviot plate, thats what I broke the most on mine
mugen mbx6, mtx4r, both ninja powered
tony montana is online now   Reply With Quote
Forum Jump
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-10-2008 11:03 PM
O.S. .12 TR setup for Losi XXXNT and other XXXNT Parts GroffBall R/C Items: For Sale/Trade 4 09-30-2006 07:06 AM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 01:19 PM
XXXNT goneRVing R/C Items: For Sale/Trade 0 11-25-2005 10:21 AM
New Xxxnt DAN_THE_MAN Electric Off-Road 1 09-24-2003 03:17 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
