Like Tree17Likes
Old 11-08-2016, 03:52 PM   #1276
Trader Rating: 30 (100%+)
Originally Posted by John Myall View Post
I do try
Jonny I definitely believe so and more as you always provide dialed in info.
+1 and more my friend
Norse is offline   Reply With Quote
Old 11-08-2016, 03:54 PM   #1277
Originally Posted by asalas View Post
They do. Down Under in Melbourne. They are actually trying to make Yokomo more popular here, not that it doesn't already have a solid fanbase.
So, I went to my LHS, got the pulley and flanges. I'm now waiting for the weekend to go and have fun at the racing track. Thanks again Norse and Johnmyall.
No problem Asaias. That's great your local hobby shop carries Yokomo. Have a blast my friend.
Old 11-08-2016, 06:45 PM   #1278
Ladies and Gents, just got some info per running 13.5. Fella racer whom has tested a lot of spur pinion combos per 13.5, has found that 84t spur with 30t pinion is working really good. Good acceleration, good top end and minimal fade.
Old 11-09-2016, 09:06 AM   #1279
I have tested 78t/29 and 81t/29,30 with good results. Will test 84t/30 and report back.
Old 11-11-2016, 01:34 PM   #1280
Trader Rating: 21 (100%+)
84/30 is the ticket for mine using the Reedy m3 13.5 standard stack motor.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 11-11-2016, 02:02 PM   #1281
Originally Posted by Aussie RC View Post
I asked Bezerk to modify the YZ4 battery stays. I wanted to be able to hold the battery in position and achieve flex for extra traction...I found that the exisiting hold down battery strap kept the rear of the buggy ridge....so I came up with this mod.
This really does seem like a great idea, I wish I'd seen this before I made my Bezerk order! (battery stays and superflex deck).
What I have done with the standard Bezerk carbon stays though, is to shim them up 1mm. This lets me run touring car style thin hook-and-loop straps, which clear the rear belt tensioner just fine, and eliminate the Y-shaped battery stay. It does seem to add a fair amount of flex to the car.
Zarathrustra is offline   Reply With Quote
Old 11-12-2016, 09:29 PM   #1282
Post some pics when you install as I would love to see.
Old 11-12-2016, 09:31 PM   #1283
Kerby,
Thanks for the info my friend. You are the 2nd fella whom has advised that 84/30 works excellent per 13.5. Going to try myself hopefully tomorrow.
Old 11-13-2016, 08:18 AM   #1284
In case anyone is looking at buying a YZ4, here is a link that has them on sale. And no, I have no associations with them. Just passing on a good deal.
http://banzaihobby.com/Yokomo-YZ-4
RB6.6/YZ-2 DT/'17 XB2 CE/22 4.0
YZ-4/B64D/22-4 2.0/D413
EB410 on order
YMMV is offline   Reply With Quote
Old 11-13-2016, 11:07 AM   #1285
LOW ET's Avatar
Trader Rating: 96 (100%+)
I use the McKune pads in mine ever since I had the kit ones overheat, no problems since
any different tricks to setting the slipper when using the mckune pads? being they are of different material and just a tad thicker than stock.
LOW ET is offline   Reply With Quote
Old 11-13-2016, 02:06 PM   #1286
I found the spur gears from Yok a little strange after ordering these. They fit my Yz-2 80tooth spur, but wont fit inside of my YZ-4 87tooth spur. Crazy!
Piles is offline   Reply With Quote
Old 11-13-2016, 04:31 PM   #1287
LOW ET's Avatar
i had a different outcome. they fit inside my yz-4 spur perfect (a little snug) but are loose inside my t5m spur. also had some other findings measuring the thickness of the pads using my calipers:
mckune pads= 0.98mm
yokomo pads= 0.78mm
associated pads= 1.02mm
Old 11-13-2016, 05:15 PM   #1288
The MCkune pads are advertised for high bite however they work great on everything from super low bite to super high and everywhere in between. Consistency is great on these pads. I found I can set these looser than stock pads.
Old 11-13-2016, 11:11 PM   #1289
Not really, you just set them in the same way you would've took to set the kit Ines.
I'm maybe a little looser on the setting then before, but the pads make up the difference.
I'm running RDRP spurs on mine & find the McKune pads fit nice and snug.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 11-14-2016, 02:22 PM   #1290
+1 on the RDRP spur gears. McKune pads fit great as u mention as well as the RDRP Spurs being nice and true. They are a tad pricey compared to Kimborough, AE, J Con, and Yok but they are worth the extra coin.
